Cab Clearance Lights
Hi. Bought a decent set of original cab clearance lights for my ’68 GMC. How do the wires run from the lights so they are hidden? My truck doesn't have a headliner. Thanks!
Re: Cab Clearance Lights
There are threads on this topic, look up in the search area. I hope you got the correct Yankee 77 cab lights, They look the best, besides the factory fireman in 69 -72. One of those threads has the measurements for drilling and mounting, and harness routing. I'm almost certain there is a 6" on center rule stated by dot at the time. I've seen a lot of pictures of these trucks with cab lights on them not measured out properly and they look like real crap. Take your time do it right.
#3 | |
Yep, those are the Yankee 77 style
I'll dig through my shop manuals to check for the illustration of install. I believe these are downloadable now also
The Niner
![]() Join Date: Nov 2010
Not to split hairs, but these are the factory cab lights for our trucks.
https://swclassics.com/cab-marker-li...40ZzaNQToNEoZc
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
I found this one, looks like maybe from LMC or Golden State pick up. Definitely double check with another factory image from a GM manual before committing to drill
#9 | |
The Older Generation
Check some of the threads here: https://www.google.com/search?domain...SggQAhgCIAIoAg Everything you ever wanted to know about cab lights. Here is a picture of the wiring channel hole you are looking for.... .
.[/QUOTE] So I am not restoring my truck. Is there a trick to running the wires between the roof panel and the headliner panel? Does it then run down the A-pillar? Here is my truck. |
#12 | |
Read some of the threads in the link I posted above, your answers are there. Short answers are yes, and yes....
My '69 came with lights - the roof panel has elevated flat spots where the lights go so the gasket is sealed better. Not sure if previous years came like that from factory - just something to think about. I removed my outer roof panel to fix all the rust and ran a pull wire through before welding back up. If I hadn't removed the panel, I would have fished an 18/2 solid stat wire cable from the drivers side cab light down the A pillar and then used the same type of cable and formed a hook on the end and stick it through the hole on the side of the dash into the A pillar to hook the wire a pull it through. Hope that all makes sense.
#14 | |
#15 |
![]() Join Date: Oct 2009
Only 69-72 with the U01 RPO came with the raised light pad roof. 69 had the "hockey puck" style lenses and 70-72 had the "fireman's hat" style lenses. 67-68 roof was flat and factory clearance lights were the Yankee 77 style as mentioned above.
#16 | |
What a beautiful truck. Reminds me of my 67. The cab lights will look great with the patina they currently have. I've only seen them in chrome and these look painted silver, they go great. |
#17 |
Active Member
![]() Join Date: Feb 2015
There is going to be three holes drilled for each light. Two are the screw holes for fastening. The third hole, maybe 5/8" to 3/4" diameter, is drilled directly under the light socket for pulling wires. From the large hole on the drivers side you should be able to get a glimpse of the access hole to the A pillar. Whether you fish the wires up or down is up to you.
I would prefer to run two wires, hot and ground, instead of relying on the mounting screws to make the ground. |
#18 |
[QUOTE=What a beautiful truck. Reminds me of my 67. The cab lights will look great with the patina they currently have. I've only seen them in chrome and these look painted silver, they go great.[/QUOTE]
Thanks for the compliment. It's an all original truck I bought out of California 8 years ago. It has an inline 250 with a 3 on the tree, manual steering and manual drum brakes. Great little truck with only 58k miles on it. Still had the build sheet behind the seat. Was built at the Fremont, CA plant and spent it's entire life only 1-2 hours from the plant until I brought it to Ohio. Was originally sold at Dexter Pontiac-GMC in San Rafael, Ca. I turned it into a shop truck with my uncle's Gulf station on the doors that he owned from the 40s through the early 80s. Besides adding the cab clearance lights I'll also be adding a Unity spotlight. |
#19 |
![]() Join Date: Feb 2022
Somewhere I posted about my effort to run wire the factory route. I spent 2 days, walking away a few times so I didn't take a hammer to the roof. Things I learned.
1) The factory route down the A pillar may not always work. Or I just didn't have the touch. The factory mount hole for the visor gives you a little better access. 2) Single wire. Roof and mount screws are the ground. 3) Use a long line of the flat dental floss. A shop vac at your destination point and feed the floss from the visor hole. The air flow will pull the floss through the passage to the vacuum. Sounds crazy but it works very well. 4) I had to abandon the A pillar (both sides) and went the longer route into the B pillar. 2 days on the A pillar with no success. 15 minutes on the B pillar with the floss trick. |
#20 | |
#21 |
Compressed air got me no where. Vacuum worked well. Could not get Vacuum in position for good suction on A piller. Easy to jam vacuum hose up the B pilar and create strong pull. The light weight floss just flutters in the air flow right into the vacuum hose. Then its a simple feed from there. Down B pillar to the path of your dome light wires to your connection point. Good idea to fuse the wire as there are lots of chafing opportunities on the run.
#22 |
Does anyone know what the replacement bulb number is for the teardrop lights? I cleaned up the bulbs but there are no numbers on them. I tested all the lights and they all work. Gonna clean up the contacts and get some new bulbs before installing but can't figure out which ones they are. I see several that look the same size but are different numbers. Not sure which ones are the correct ones.
#23 | |
#24 | |
https://67-72chevytrucks.com/vboard/...=829820&page=6 Post #131. This is what I used for new pigtails and bulbs. They worked good. You might have to cross reference the bulb number.... .
#25 | |
| Bookmarks |
| Tags |
| cab, clearance lights, lights |
| Thread Tools | |
| Display Modes | |
