Old 02-21-2026, 05:37 PM   #1
68gmcdude
Cab Clearance Lights
Hi. Bought a decent set of original cab clearance lights for my ’68 GMC. How do the wires run from the lights so they are hidden? My truck doesn't have a headliner. Thanks!
68gmcdude is offline   Reply With Quote
Old 02-21-2026, 06:26 PM   #2
68panelman
68panelman's Avatar
Re: Cab Clearance Lights
There are threads on this topic, look up in the search area. I hope you got the correct Yankee 77 cab lights, They look the best, besides the factory fireman in 69 -72. One of those threads has the measurements for drilling and mounting, and harness routing. I'm almost certain there is a 6" on center rule stated by dot at the time. I've seen a lot of pictures of these trucks with cab lights on them not measured out properly and they look like real crap. Take your time do it right.
68panelman is offline   Reply With Quote
Old 02-21-2026, 06:49 PM   #3
68gmcdude
Here are the ones I found. I was told these were the correct ones for 1968.
Old 02-21-2026, 06:51 PM   #4
68panelman
68panelman's Avatar
Yep, those are the Yankee 77 style
Old 02-21-2026, 06:53 PM   #5
68gmcdude
Thanks. I'll search for the previous threads. I definitely want to get the measurements correct.
Old 02-21-2026, 06:59 PM   #6
68panelman
68panelman's Avatar
I'll dig through my shop manuals to check for the illustration of install. I believe these are downloadable now also
Old 02-21-2026, 07:06 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
Not to split hairs, but these are the factory cab lights for our trucks.
https://swclassics.com/cab-marker-li...40ZzaNQToNEoZc
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-21-2026, 07:14 PM   #8
68panelman
68panelman's Avatar
I found this one, looks like maybe from LMC or Golden State pick up. Definitely double check with another factory image from a GM manual before committing to drill
Old 02-21-2026, 07:15 PM   #9
68panelman
68panelman's Avatar
Yes, those are correct for 69-72. The Yankee 77 style was 67-68
Old 02-21-2026, 10:16 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Check some of the threads here:
https://www.google.com/search?domain...SggQAhgCIAIoAg
Everything you ever wanted to know about cab lights.
Here is a picture of the wiring channel hole you are looking for....
Leon
Old 02-21-2026, 10:28 PM   #11
68gmcdude
.[/QUOTE]
So I am not restoring my truck. Is there a trick to running the wires between the roof panel and the headliner panel? Does it then run down the A-pillar? Here is my truck.
Old 02-21-2026, 10:49 PM   #12
LockDoc
LockDoc's Avatar
Read some of the threads in the link I posted above, your answers are there.
Short answers are yes, and yes....
Leon
Old 02-22-2026, 12:07 AM   #13
ryans69chevy
My '69 came with lights - the roof panel has elevated flat spots where the lights go so the gasket is sealed better. Not sure if previous years came like that from factory - just something to think about. I removed my outer roof panel to fix all the rust and ran a pull wire through before welding back up. If I hadn't removed the panel, I would have fished an 18/2 solid stat wire cable from the drivers side cab light down the A pillar and then used the same type of cable and formed a hook on the end and stick it through the hole on the side of the dash into the A pillar to hook the wire a pull it through. Hope that all makes sense.
ryans69chevy is offline   Reply With Quote
Old 02-22-2026, 12:13 AM   #14
68gmcdude
Thanks for the input. From what I'm gathering, years '67 and '68 were flat roofs like mine. Starting in’69 the went to the bump on the roof. Wiring looks to be the same though.
Old 02-22-2026, 01:50 AM   #15
jocko
jocko's Avatar
Only 69-72 with the U01 RPO came with the raised light pad roof. 69 had the "hockey puck" style lenses and 70-72 had the "fireman's hat" style lenses. 67-68 roof was flat and factory clearance lights were the Yankee 77 style as mentioned above.
Old 02-22-2026, 11:30 AM   #16
68panelman
68panelman's Avatar
So I am not restoring my truck. Is there a trick to running the wires between the roof panel and the headliner panel? Does it then run down the A-pillar? Here is my truck.[/QUOTE]
What a beautiful truck. Reminds me of my 67. The cab lights will look great with the patina they currently have. I've only seen them in chrome and these look painted silver, they go great.
Old 02-22-2026, 11:53 AM   #17
c30
Active Member
c30's Avatar
There is going to be three holes drilled for each light. Two are the screw holes for fastening. The third hole, maybe 5/8" to 3/4" diameter, is drilled directly under the light socket for pulling wires. From the large hole on the drivers side you should be able to get a glimpse of the access hole to the A pillar. Whether you fish the wires up or down is up to you.
I would prefer to run two wires, hot and ground, instead of relying on the mounting screws to make the ground.
c30 is offline   Reply With Quote
Old 02-22-2026, 11:53 AM   #18
68gmcdude
[QUOTE=What a beautiful truck. Reminds me of my 67. The cab lights will look great with the patina they currently have. I've only seen them in chrome and these look painted silver, they go great.[/QUOTE]
Thanks for the compliment. It's an all original truck I bought out of California 8 years ago. It has an inline 250 with a 3 on the tree, manual steering and manual drum brakes. Great little truck with only 58k miles on it. Still had the build sheet behind the seat. Was built at the Fremont, CA plant and spent it's entire life only 1-2 hours from the plant until I brought it to Ohio. Was originally sold at Dexter Pontiac-GMC in San Rafael, Ca. I turned it into a shop truck with my uncle's Gulf station on the doors that he owned from the 40s through the early 80s. Besides adding the cab clearance lights I'll also be adding a Unity spotlight.
Old 02-22-2026, 12:09 PM   #19
PbFut
Somewhere I posted about my effort to run wire the factory route. I spent 2 days, walking away a few times so I didn't take a hammer to the roof. Things I learned.
1) The factory route down the A pillar may not always work. Or I just didn't have the touch. The factory mount hole for the visor gives you a little better access.
2) Single wire. Roof and mount screws are the ground.
3) Use a long line of the flat dental floss. A shop vac at your destination point and feed the floss from the visor hole. The air flow will pull the floss through the passage to the vacuum. Sounds crazy but it works very well.
4) I had to abandon the A pillar (both sides) and went the longer route into the B pillar. 2 days on the A pillar with no success. 15 minutes on the B pillar with the floss trick.
PbFut is offline   Reply With Quote
Old 02-22-2026, 12:32 PM   #20
68gmcdude
Thanks for the tips. Greatly appreciated. One of the links a saw showed using an air hose to help blow the feed string down the A pillar.
Old 02-22-2026, 01:21 PM   #21
PbFut
Compressed air got me no where. Vacuum worked well. Could not get Vacuum in position for good suction on A piller. Easy to jam vacuum hose up the B pilar and create strong pull. The light weight floss just flutters in the air flow right into the vacuum hose. Then its a simple feed from there. Down B pillar to the path of your dome light wires to your connection point. Good idea to fuse the wire as there are lots of chafing opportunities on the run.
Old 02-24-2026, 09:57 PM   #22
68gmcdude
Does anyone know what the replacement bulb number is for the teardrop lights? I cleaned up the bulbs but there are no numbers on them. I tested all the lights and they all work. Gonna clean up the contacts and get some new bulbs before installing but can't figure out which ones they are. I see several that look the same size but are different numbers. Not sure which ones are the correct ones.
Old 02-24-2026, 10:25 PM   #23
68panelman
68panelman's Avatar
If my memory serves me correctly, I believe it is a 97 bulb
Old 02-24-2026, 10:34 PM   #24
LockDoc
LockDoc's Avatar
https://67-72chevytrucks.com/vboard/...=829820&page=6 Post #131.
This is what I used for new pigtails and bulbs. They worked good. You might have to cross reference the bulb number....
Leon
Old 02-25-2026, 09:14 AM   #25
68gmcdude
Thanks for the link and info. I ordered the pigtails and bulbs. Better to make sure everything is in good shape before mounting and hooking up.
cab, clearance lights, lights
