#476 |
![]() Join Date: Jun 2019
Re: 1970 K20 Z62 Full Restoration
#477 |
![]() Join Date: Oct 2013
Small update on a hard to find part. As I've noted on here before, I spent a lot of time looking for the correct two piece exhaust hanger that goes behind the muffler. By the 1970-71 parts book, a couple of numbers get you there:
3948683 Exhaust clamp upper 3820977 Exhaust clamp lower I met a vendor at a show recently who was able to put me on the closest thing so far. He had an earlier version (upper only) and a superseding kit that had an extra bracket. The kit was in much better condition, the strap was the right thickness and ended up being the one I used. I removed the flash rust and the extra bracket and swapped out what I had on there for this two piece. On the assembly line the tailpipe and muffler would have been welded together as one piece. There would be no need for the clamp you see pictured. Even though my muffler and tailpipe are NOS and correct numbers, they are service replacement examples. The reason the factory put a two piece hanger on in that location is so you wouldn't have to fish a single piece clamp/hanger on from the tailpipe end all the way to this mounting position. You connected the muffler to the Y-pipe and throw this hanger right on where is goes. First pic is the hanger I had been running on there. Then a couple of pics of the new parts I located, before and after clean up.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 11-19-2025 at 10:31 PM. |
#478 |
Here's the two piece hanger installed.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#479 |
Love those details. Super sharp!
#480 |
Not as big of a deal, but another part I had been looking for (for about the same amount of time) surfaced too. An NOS transfer case shift knob. Pretty pumped about it. Was never really satisfied with the rehab job I did on the nice original example that I was running.
#481 |
#482 |
![]() Join Date: Dec 2009
It is all in the Details.
![]() Nice work staying persistent in your search. ![]() ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#483 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Very nice!! You have some good luck.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#484 |
![]() Join Date: Apr 2008
NOS shift knob- COOL!
71 C10 72 K20 72 K10 Super Kirk |
#485 | |
#486 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Love the detail - nice!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#487 |
A year ago now I was there and it was a chassis and engine. Now your driving it already. I hope I can make my way back next summer to get a ride in it. Your builds are top notch with good info and rate parts!
#488 | |
Thanks Pete. I learned it from watching you.
![]() Quote:
But I had to pull the seat and the mat and the hump once we got home. I don't understand fully what the cause was. Once I snapped 'em back in phase, it was probably fine. But I went through everything to be sure. No obvious issue. I went ahead and pulled the cover and replaced all the new cover components with newer cover components (just because) and put her back together. I guess a potential positive is that I had a small leak at the back up light switch that I didn't know I had because it had just pooled in the recess. I think that should be resolved. I've run it through the gears about fifty times in the meantime. But I probably did it a hundred times during the build. I couldn't walk by the chassis without shifting the gears. I've got everything back together except the mat and seat. I had some issues with color releasing from a few areas of the mat which was exacerbated by the removal. So Eric is going to prep and re-shoot that for me. But...I would love for you to come back and let's put some more miles on. One of the benefits of the bench being out is that it makes a really nice place to sit and stare at the truck. One of my favorite pastimes.
#489 | |
#490 |
A few little updates. First...I totally whiffed on my parking brake cable spring. I can't believe you guys didn't call me on it! My cable cleared the driveshaft, (though very close) without it. We've started disassembling my brother's 70 which is very complete and original and I realized the omission. Picked up an NOS one and now the cable clears the shaft at a more reasonable distance.
#491 |
Second...As you know, I wasn't super happy with the C10 Nationals experience. Though I had a blast hanging out with board members and friends.
I've got a buddy who is a big AACA guy and he encouraged me to show the truck at one of their events. There was a Winter Nationals show about 2hrs away from me this weekend, so I hauled her up there. An amazing variety of cool cars. My brother and mom drove up and my wife and daughter came. A really fun family weekend. We scored high enough for a first in our class. I'm new to how they dole out awards, but I am anxious to get my score sheet. They don't tell you what you score at the meet. I have to send away for it by mail...and I'm not sure they give you details on the deductions. You guys can probably tell me more than I know. I feel like they could ding me for having a battery topper instead of an actual Delco battery. I am also still running a Wix XP break-in oil filter. Those are the things I can think of. They may ding me for other things. But I got no questions from the judges...and I came loaded with docs to support the build.
#492 | |
![]() ![]() Join Date: Jan 2005
#493 |
Oh, and congratulations on the win. Very much deserved!
#494 | |
#495 |
Carpe manana
Excellent! Well deserved.
#496 |
Congrats on the recognition- well deserved!
#497 |
Thanks guys. It's been fun getting her out. I think I may leave the bench in there a little longer so I can keep showing it as original. At the show on Saturday I met a gentleman that worked the line at the Lakewood Atlanta plant. I had a lot of questions. He was a real sport about it.
#498 |
BlahBlahBlah
Hope you have a big mantel for all the trophy's you're going to be earning.
#499 |
The amount of detail and dedication to your truck build is amazing. Congratulations on your show win
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB Gasser 364"LS and all the goodies 2001 Vette Road/Street 1990 IROCZ Vert |
#500 | |
| Bookmarks |
| Tags |
| 1970, 4x4, factory, k20, restoration |
| Thread Tools | |
| Display Modes | |
