Old 03-29-2026, 07:49 PM   #5701
dave6672
dave6672's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by CG View Post
That’s a great look you have going!
Thanks, appreciate it!
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
1972 C10
dave6672 is offline   Reply With Quote
Old 03-30-2026, 01:06 AM   #5702
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by zicc1835 View Post
finally installed these tie down brackets OLD TRUCK FAN offers these.... nice option IMO
I wonder what the shear load is on those two Grade 5 bolts?
Old 03-30-2026, 01:23 AM   #5703
'68OrangeSunshine
Today I extracted the Speedometer from my '67 K/10 Suburban's instrument cluster, and used it to replace the Speedo in my '68 C/10 Stepside.
Mechanically, the operation was OK, but electrically, I failed somewhere.*
I have no Dash Lights. Cab [Dome] Light works OK. Hazard Flashers work.
The Left Turn Indicator bulb is constant ON.
It was dark when I knocked off for the day. With no instrument lights, I did not test run at night. In the daylight, I will test run the Stepside to see if the Speedo reads right. Before, the OEM Speedo was running very slow. 35 MPH indicated when GPS read 50 MPH groundspeed.
A friend offered to recalibrate the unit.
* I believe there is an Open where the rectangular plug for the Cluster Connector meets the copper leads of the Printed Circuit. One of the plastic tabs on the Connerctor side broke off a couple years ago. I got a new one mail order, but now I can't find it. Also about 3 of the copper leads on the PC are loose.
I think the Connector wobbled loose when I had to wiggle the Panel around to get to the six screw holes.
Tomorrow is another day.
Old 03-30-2026, 01:35 AM   #5704
'68OrangeSunshine
Pix of Speedo transplant:
Old 04-01-2026, 09:49 PM   #5705
zicc1835
zicc1835's Avatar
in response to your shear load question
well they say a picture is worth ...how many words
second pic if I ever thought I would tie down something remotely heavy in the back of my sweet little stepper when I remove the bed to fix the POs bed work minus the side angles I would put some reinforcing brackets on the back side of the head board and some grade eights and then I can haul around something more exciting like one of these......just sayin never contemplated heavy hauling but like the option to tie down a cooler or chair for a trip to a show
zicc1835 is offline   Reply With Quote
Old 04-01-2026, 09:53 PM   #5706
zicc1835
zicc1835's Avatar
Originally Posted by Chevys4life View Post
Is the website called Old Truck Fan? I want to get a set for my truck too.
sorry Chevys4life I missed this question .... Old Truck Fan is a board member type him into members list you'll find him he Adam easy to deal with
Old 04-02-2026, 07:21 AM   #5707
Chevys4life
Thanks!!!
Chevys4life is offline   Reply With Quote
Old 04-02-2026, 09:12 AM   #5708
'68OrangeSunshine
Nice placement. Can you reach out of the cab thru the window and grab a cold one?
Old 04-02-2026, 10:25 AM   #5709
70STOVEBOLT
70STOVEBOLT's Avatar
Originally Posted by trapdoor2 View Post
Just a little update, I haven't been here on the forum in a while.
The C10 has been in storage for a while but last month we finally found a good local speed shop and had her rollbacked off for reinstatement, updates and rework.
The job: update distributor to HEI. Update brakes to power discs on all 4 corners. Install 3:53 diff and posi. Install 2" hitch. Modernize A/C. Install upgrade headlight harness with relays, etc. New 15" steering wheel. New "orignal look" instrument panel, added tach.
What happened: all of the above + new wiring harness in cab (found shade-tree household wiring, duct-tape repairs and a general mess). New wiring aft of cab, same issues...+ added hitch wiring. New Holley carb...the original had worn shafts, linkages, etc. New shoes (radial T/As again).
Miz Diane is just back from her test drive in the picture. It's her truck...she just lets me drive it.
That's a nice looking truck Miz Diane has. Do you have a build thread or more pice of the interior and engine bay?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-03-2026, 07:03 PM   #5710
72c20customcamper
72c20customcamper's Avatar
Valve guid seals . Found not one umbrella seal on the drivers side just the little o ring type on the stem . I bought the high temp steel type for replacements. Either they didn’t put on the umbrella seals or they just deteriorated.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-03-2026, 10:50 PM   #5711
Rust_never_sleeps
Rust_never_sleeps's Avatar
Put my gauge cluster back in, hoping I got the polarity right on those LED's. It was too bright to check if they were working
Cheapo bulbs off the River don't come marked for polarity, but there is a visible gap on one side
Pretty damn warm to be under the dash, struggling to get the oil pressure tube connected
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old Yesterday, 12:12 AM   #5712
'68OrangeSunshine
Pretty damn warm to be under the dash, adds to the joys of getting the oil pressure tube connected
One time -- long ago -- I thought I had secured the Oil Pressure Gauge feed nut. I handn't quite -- and hot black oil went gushing all over my buckskin pull-on boots.
Possibly, you can pre-check those LED bulbs with a 9 Volt battery, and then put an ink dot from a Sharpie on the positive side. That will sort out your polarity.
Old Yesterday, 02:32 PM   #5713
Rust_never_sleeps
One of my friends had a Mustang GT(named "DT" for deathtrap) that would spew random fluids on whoever was lucky enough to be riding shotgun at the time
I'm pretty confident I've got the bulbs figured out, there's a visible flag
It's the polarity on the flexible circuit board I'm not dead sure of, forgot to check it after I walked the dogs last night, so the mystery continues.
Old Yesterday, 02:51 PM   #5714
'68OrangeSunshine
You have a VOM? The test leads should tell you, but you will have to bench check it, and feed 12 volts to the circuit so it would simulate working order.
I loved the Mustang. These girls I knew in high school let me borrow their Mustang to take the DMV drivers test when I was 17. I'd tried it with my Dad's 1960 Ford Country Sedan. Big fat Station Wagon. I screwed the pooch trying to parallel park.
But Ford's electrics? Geez!
There's a reason the say FORD = Found On the Road Dead, or Fix, Or Repair Daily.
But I'm a Chevy Guy, so I'm prejudiced.
Old Yesterday, 07:50 PM   #5715
72c20customcamper
Hooked up the gages today in the 68 . Need to get the volt meter and fuel gages mounted . So far I am very happy with the BluePrint 383
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
