Chevy Orange Engine Paint Question????
I am painting my engine with Plastikote Chevy Orange engine enamel. I have spent hours sanding and cleaning the engine so I am ready to paint. I started putting on the first couple of coats and it seems really thin. The paint shop owner told me not to prime the engine because the paint will hold up better without it. I figured I would let it dry for a few days and then apply some more coats. Everyone I have talked to said orange paint is just really transparent. Should I go and buy primer to put on first, or should I let it dry and put some more coats of the enamel on? Please give me some advice.
BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=436046 |
Re: Chevy Orange Engine Paint Question????
I have always just sprayed the engine paint on, no primer. The paint is thin and you have to be carefull not to get runs.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
its all about the +6 inches
no primer.
No reason to wait a couple days either. Wait till the paint is tacky, then give it another light coat. If you let it dry all the way, then you'll need to give it a light sanding to spray over it. |
1969 Custom 30 wrecker
VHT is better. It's not watery like Plasikote.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Here's my 283 with 3 coats of Plasikote with no primer.
#6 | ||
"I ain't nobody, dork."
Plastikote here too... at least 3 coats. Sometimes more. Never used a primer.
Gary
Here's my 427 with 2 coats of POR15 engine paint, everything but the valve covers.
Rick ![]() 69 SWB Project 95 Suburban Daily Driver 47 Flxible Motor Home 427 GMC 4spd Allison 71 C-10 LWB 307/350 (parted out) 64 SWB Custom Cab 283 powerglide (sold) 2000 Yamaha Venture |
What's the application for the 427?? Cool looking, but that pump may not fit under the hood...
Maybe in the also cool looking motorhome/bus in the background? Last edited by 72lb4x4; 05-25-2011 at 10:57 PM. |
Moderator
![]() Join Date: May 2007
POR is the only way to go. I have used it on engines for years, still looks brand new.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Back to square one. The paint shop said I bought a bad batch of paint. I stripped all the paint off with aircraft stripper and a pressure washer. I am down to the bare block now. I ordered the POR 15 kit. I will never use Plastikote again even if I did get a bad batch. It was like spraying on an orange tinted clear coat. I will keep you updated on my progress. I could use some POR 15 tips.
Man of Mini-Talents
Here's the number one POR-15 tip in my experience: wear rubber gloves, that stuff will be on your skin or whatever forever.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
Moderator
I agree. Just follow the instructions that come with the kit, make sure that engine is CLEAN. The marine clean that comes in the kit is like simple green x 100, it works very well. Wear gloves and a respirator mask, even if you brush it on. You will be very happy with the results.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 05-26-2011 at 02:57 AM. |
~Rest In Peace~
i concur
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
~Rest In Peace~
70 gmc 355 supercharged
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 05-26-2011 at 03:08 AM. |
#15 |
72lb4x4, it's going in a 46 Flxible Clipper, the blue one in the background is a 47 and has a 427 with a 4 spd allison automatic in it already.
#16 |
I have never used primer with engine paint.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#17 |
Yep. X2.
#18 |
I finally finished my engine. It turned out great. POR 15 is a little hard to apply, but overall its a great finish.
#19 |
Champagne Taste on Beer Budget
WOW!
Give us some details on that engine. Looks very good. Paint turned out great huh?
Coming Soon: Project 1970 Country Truck |
#20 |
2 coats ppg epoxy primer on a hot tanked block and vht engine enamel and still looks like new 5 years later
Fuzzy |
#21 |
Engine Block Casting Number: 3970010 (1968-1979) 4 Bolt Main
The engine was carefully engineered to be a street-able 375-400 hp The engine was blueprinted and balanced with 9.5:1 compression. The heads were opened up to 2.02 intakes 1.86 exhaust with hard seats installed so that pump fuel can be run. Heads were ported and smoothed. The engine had a high lift cam installed (5/8 race cam) 1:1.5 roller rocker arms installed. The timing chain is a double roller. The oil and fuel pump is a stock Z-28 spec unit. Intake is a Holley 750 double pumper vacuum secondary’s. Edlebrock 600 cfm carb Edlebrock performer manifold Accel GM HEI Distributor PROFORM ORANGE SLANT EDGE VALVE COVERS TAYLOR SPIRO-PRO IGNITION WIRES HOT ORANGE EDLEBROCK PRO-FLO AIR CLEANER CHROME LOGO FRAM AIR HOG AIR FILTER SANDERSON-CC10 HEADERS CHROME PULLEY’S CHROME OIL PAN BILLET DIP STICKS MADE FOR YOU PRODUCTS VERTICAL WIRE LOOM KIT 700R4 TRANSMISSION W/ COAN 3500 STALL TCI 700R4 TV CABLE CORRECTOR KIT AND BRACKET KUGEL KOMPONENTS SHIFT LINKAGE EARLY CLASSIC ENTERPRISES TRANSMISSION CROSSMEMBER
