Old 11-27-2011, 10:17 PM   #1
cb1965
cb1965's Avatar
fan shroud ?
i just installed a champion radiator and still have a belt driven fan. i dont
have a fan shroud and was wondering if that would be a big issue with
cooling. i did a test drive and held between 180 and 200.
anyone running with no shroud and no issue with overheating?
is there a bolt on shroud that i can swap in? thanks
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 11-27-2011, 10:21 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: fan shroud ?
If it turns out you need one they sell them at Brothers and ecklers.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-27-2011, 10:44 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: fan shroud ?
I have a 400 smallblock with an aluminum radiator in my shortbed. No shroud and it never ran hot with a belt driven fan. In the same range as you describe.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-27-2011, 11:05 PM   #4
cb1965
cb1965's Avatar
Re: fan shroud ?
cool. ill give it a go and see how she performes. if i have any issue ill get a shroud. thanks
'66 chevy lwb c10
'65 chevy lwb c20
Old 11-28-2011, 12:21 AM   #5
LT1 Burb
LT1 Burb's Avatar
Re: fan shroud ?
My truck has never had a shroud and it came from Arizona.
LT1 Burb is offline   Reply With Quote
Old 11-28-2011, 09:58 AM   #6
badriand
badriand's Avatar
Re: fan shroud ?
Live in Texas, stayed around 105-115 all summer and mine never got over 200 without a shroud.
badriand is offline   Reply With Quote
Old 11-28-2011, 11:00 AM   #7
tomfg
Re: fan shroud ?
Just wondering....... My truck didn't come with a fan shroud, but I'm wondering if an original would fit my 64 truck? It has a later 350 Chevy small block. The radiator appears to fit as original, but would the fan on a 350 engine be centered in the same spot as the original 283?
Haven't had the chance to see what it's going to do in warm temps, as I just recently got it on the road after restoration...... highs are now in the 30's.
Thanks.
tomfg is offline   Reply With Quote
Old 11-28-2011, 07:31 PM   #8
protrash64
protrash64's Avatar
Re: fan shroud ?
Thanks.
ALL smallblocks are the same size physically. The only difference would be if the engine location was moved front/rear or if you have a short or long waterpump; or a combination of these options with original engine perches. I would guess an original shroud would work as long as the gap between the engine and radiator were relatively the same.
Old 11-28-2011, 07:37 PM   #9
tomfg
Re: fan shroud ?
Thanks, Good to know!
Old 11-28-2011, 11:06 PM   #10
Rich 5150 69
Re: fan shroud ?
Two questions arise are you using short or long water pump, and are you using rear engine mount holes in crossmember will dictate where your fan resides. In other words how far is your fan from radiator?
Mine is rear mount holes short water pump three inch fan extension, 6 blade fixed fan.
