Old 01-14-2012, 06:32 PM   #1
70c10lt1
Mc Gaughy's spindles
I have a 71 C10 SWB that I want to put dropped spindles on. I have a set of Mc Gaughy"s #33154 that are for a 73 - 87 , has anyone reamed the tapers and used them on a 71 or 72? I would also like information on the calipers, are they the same on the 71 as the 73? Thanks for your help!
70c10lt1 is offline   Reply With Quote
Old 01-14-2012, 06:34 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Mc Gaughy's spindles
Just change the upper balljoint and outer tie rod on your '71 to the 73-87 version,... and they will be a "bolt-on".
Keith
Convert to disc brakes.
Old 01-14-2012, 06:37 PM   #3
lolife99
lolife99's Avatar
I assume you know that those McGaughy's spindles are for the 73-87 1" light duty rotors?
That means you will have to change rotors, calipers and the bearings.
(the inner or outer bearing is different. I can't remember which)
Keith
Old 01-14-2012, 10:47 PM   #4
70c10lt1
Thanks Keith, I have the 1" rotors with bearings and seals, from your answer I'm assuming it does take a different caliper.
71 c10, calipers, dropped spindles
