#101 |
I'm just glad to be here!
Re: 63-87 rack and pinion
Rob
I got your rack and started the install. I have an issue with one of the adapters for the rod ends. One will only thread on about a 1/4 inch onto the rack end. The jam nut goes all the way on fine. I think the internal threads on the adapter are messed up. What is the thread type so I can get a tap and chase the threads? Posted via Mobile Device |
#102 | |
Thanks for a great product. I am looking forward driving this set up with PB Forward Arms.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#103 |
Thought I would post up some pic's of my install on Korbin's '82 C-10. We raised the crossmember up into the frame 1.5" and also used Porterbuilt's new Forward Arms (Lowers only at this point). Here are some pictures from this past weekend:
![]() ![]() ![]() I still need to do the support bearing, but I am waiting on Rob to post up some pictures of the correct set up for a '73-'87 frame rail. I have a PS pump, hoses, and cooler from a 2000 GMC that we are going to use in the final installation. Enjoy!
#104 |
![]() Join Date: Jul 2010
With a raised crossmember, you need to raise the idler bearing also. I would set the cab on, install the column, and then lay out the steering shaft.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 12-05-2012 at 09:23 PM. |
#105 |
Thanks, Rob. I got the adapter yesterday. Tried in on the Passenger side this morning and it fits fine. I need to check the Driver side since that is the side we had issues with. I will do that this afternoon on the way home from work.
I have a bearing like you showed above, once the cab floor is done and under side is painted, we will put it on and set up the rest of the steering system. Thanks again!
#106 |
I finally got the time in the shop to put the new adapter on and get that steering bolted together, just need to mount the cab to finish it off...
With the rod ends and adapters all together and both threaded all the way in, I have a bunch of toe out. What should I do to be able to adjust this down for a range between toe out and toe in? Should I cut a little off the rack ends? How much?
#107 |
Karl, did you ever get this resolved?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#108 |
I got all the parts together and fit to the chassis. I have not heard from Rob on what I should do to fit the extreme toe out issue. I say extreme since it is about 1/4"-3/8" toed out with the adjustments all the way in...
#109 |
I've heard that there is some clearance issues with the tie rod ends and the posi links when using a Ride Tech Musclebar?.....looks like there is lots of room for the steering shaft with the LS with headers?...thats good news...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#110 |
Karl, I will check on an OD rack measurement for you on thursday.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#111 |
Rob
Did you happen to get the measurement of the overall rack width? I appreciate all your help with this project. Happy New Year!
#112 |
good luck. I still want one of these but I hope you get all yours worked out.
#113 |
Rob
here are some pictures of my install I am trying to do. It looks like I can get a single shaft from the column to the Ujoint on the rack without needing the third joint and support bearing. I do not mind cutting the frame rail and I might even weld back in a strip on the engine side of the flange to "capture the shaft in the frame rail flange. Also, should I cut off about 1" of the column shaft to get the Ujoint further away to help with the angles? I am going to try to call you later today. I might have to wait to talk to you if your at GG's in TX this weekend. Anyway here are some pictures: ![]() ![]() ![]()
#114 |
Got my steering shaft hooked up. For what ever reason, I did not get the correct U-Joint for the column to shaft. I have to get the correct one for the final assebly, but this one worked out real well for moch up. Ended up going with a straight shaft from the column to the U-Joint on the rack.
#115 |
Great Karl. glad to see it hooked up.
#116 | |
I really appreciate the work you're doing with C10's to get them to handle better! The "Make it handle" thread, along with a trip to see the Goodguys autoX has completely change the build direction of my '66 C10. I had planned to build my own A-arms but noticed this package deal and figured I'd see what the price was before I went out and bought everything to build my own arm- might not be worth the time and effort if I can just buy them already built like I want (1" forward, added castor, bag plates). I will be going with your R&P kit either way. I searched the suspension marketplace but didn't see the rack/arm combo listed anywhere. Thank you for your time and commitment to the forum!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#117 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#118 | |
I hope to have the truck running and driving by end of next month so I can give a bit of feed back on the steering and linkage.
#119 | |
I know you're not ready to drive it yet but I'd love to hear your comments on how the steering works/feels.
#120 |
x2!
#121 |
Yes I too am wanting to hear some real world thoughts and experiences, that and for Rob to run a sale special again.
#122 |
We are getting closer. I am a bit behind the schedule we planned, but I don't want to cut corners. I hope to have some better updates in about 3 weeks.
#123 |
Yes sir don't rush it this close to the end. It will be a great build.
#124 |
woops, wrong thread.
sorry Thanks.
#125 |
I just installed this. I have CPP tubular arms, sway bar and 3in drop springs and dropped spindles and installed this R&P as part of my 5.3 conversion. I'm having a conflict with the sway bar when turning the wheels. It looks like guys with bags don't use a sway bar... I got to think my truck would sway pretty bad without anything.
Any suggestions on modifying/bending such a large sway bar? |
| Bookmarks |
