06-13-2013, 09:17 PM | #1 |
Trailing arm differences? '60-'62, '63-'66?
Are there any differences in the '60-'62 versus the '63-'66 trailing arms? Length, angle, etc.?
Thanks, -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
06-13-2013, 09:43 PM | #2 |
Re: Trailing arm differences? '60-'62, '63-'66?
I'm gonna say no MAJOR differences. I just sold a set of 1966 trailing arms with springs to a guy who installed them on his 1962. No problems with fitment at all. The 66 trucks had a different e-brake configuration and the trailing arms have a bracket riveted along the side, but functionally the trailing arms are the same. Also, LMC lists new trailing arms for 60-66 as the same part number, so that means you get the same part no matter for any 60-66.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
06-14-2013, 12:58 AM | #3 |
There is a difference in the trailing arms when it comes to c20 and c10 the c20 have an extra steel plate at the rear of the arm both at the top and bottom and they are riveted to the arm these are heavy duty and were installed on the camper specials.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
06-14-2013, 08:35 AM | #4 |
IIRC, the trailing arms are the same, but the cross member the arms bolt to are at different angles because the 60-62 TA are bolted to the axle closer to the backing plate than the 63-70's are.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-16-2013, 09:32 AM | #5 | |
-Brad
04-24-2020, 09:43 PM | #6 |
But Found Her 25yrs Later!
Yes, trailing arms are spread further apart because the frames are wider in the rear. I had to weld the perches further apart on the 65 12-bolt to work on my 62 frame.
04-24-2020, 09:46 PM | #7 | |
I'll try and get a pic.
04-29-2020, 05:08 PM | #8 | |
My original Eaton rear end is leaking pretty bad from the pinion seal and rather than fight with it and worry about crush sleeve, etc...I figured I'd just swap it out with the 12 bolt. I see you kept the original perches in place when you installed the new ones, did you have enough room to strike a good weld bead still (cant tell from the pic)? Did you buy your perches from CaptainFab....mind telling me what they ran price wise? Thanks! |
04-30-2020, 09:52 PM | #9 |
60-66 Nut
04-30-2020, 10:39 PM | #10 | |
05-01-2020, 01:03 PM | #11 | |
05-01-2020, 01:03 PM | #12 |
