Guys will a 33" tire fit on the factory spare tire carrier bolted behind the seat in these Blazers?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Re: Max tire size for spare tire carrier?
I think a 31 is about as big as you can put in there.
Carpe manana
![]() ![]() Join Date: Dec 2010
Jeff - I can try to check some measurements on mine. Prob won't have time to unbolt the spare from the swing away and try it in the OEM carrier until the K5 (and myself) are up in Montana (Kalispell) in just about three weeks....
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I have a 33 in mine and it fits
Posted via Mobile Device |
If you get a chance some time could you post a couple pics ?
I appreciate the input from everyone. I am debating about buying a 5th tire. I'm going with 33 x 10.5 BFG's and I wasn't going to bother with the spare if it wouldn't fit the factory mount. This is a gathering info thread. Just starting tear down so tire purchase won't be until the winter.
I will try and get you some pics this weekend...
33x10.5 on factory spare rack
Awesome. Thanks. Truck looks great from that angle. Is that Hugger Orange?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 09-27-2013 at 10:49 PM. |
Thank. Yup, Hugger orange. My spare tire rack is the one ith the single hole with welded bolt and had to bend a threaded rod upward to fit and attach the taller tire
So modified for height but clearance to bed side to the left was ok?
Yes, plenty of room
