Anyone know what holds the E-Brake clevis together?
There's a pin or bolt that goes through the eBrake pedal tab around which the brake cable connects in double-sheer. Oh wait, that's grandma's underpants. I meant double-shear.
Put an other way, the eBrake cable ends in a U with two holes, one on each side of the brake pedal hole. But what goes through the hole? Is it a regular bolt or some kind of special pin? I do not appear to have saved (or can't find) whatever it was...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Re: Anyone know what holds the E-Brake clevis together?
Its a pin with a hole cross drilled at the end for a spring clip
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Aug 2008
![]() Join Date: Oct 2009
yep - has a thin round head on one end, no threads, and the above mentioned hole for a spring clip/cotter pin.
![]() Join Date: May 2010
It's called a clevis pin. Mine measures 3/4" (total length) X 5/16" and has always had a cotter pin through the hole. Here's a link from Fastenal's website showing a 1" X 5/16" pin. You should be able to modify a longer one to stock length.
http://www.fastenal.com/web/products...endingMachine= OR... McMaster-Carr appears to have them in the correct length. Last edited by FirstOwner69; 05-31-2014 at 12:55 AM. |
Thanks! Found mine in the wrong bag. I wonder sometimes if I sleep walk and come out and hide parts on myself. It's the only logical explanation.
