06-25-2018, 05:44 PM | #1 |
Is this really the original hood?
Saw this 1984 C20 in an ad, lister says it's "original two-tone paint" but I don't remember ever seeing a hood that didn't match the top of the side panels… but it does also seem to match the top/back of cab and the lower panel color… was there ever a two-tone option like this?
I only knew this options shown in this post: http://67-72chevytrucks.com/vboard/s...87&postcount=6 I was sure at first this was a replacement hood, but the more I looked the less sure I was, so I thought I'd check with the pros… Ad with more pictures is here: https://portland.craigslist.org/clk/...624535618.html |
06-25-2018, 06:26 PM | #2 |
Re: Is this really the original hood?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
06-25-2018, 06:58 PM | #3 |
Thanks Bandit130!
Here's one example of a special edition from '78 with a non-matching hood, but that's the only thing like this I've found so far… https://autowise.com/wp-content/uplo...beau-james.jpg |
06-25-2018, 07:27 PM | #4 |
welcome....
if the spid is still there it should show it
06-25-2018, 09:13 PM | #5 |
STILL PLAYS WITH TRUX
Keith Seymore probably know the answer to this. Maybe he'll chime in.
06-26-2018, 07:13 AM | #6 |
Not from the factory that way.
The hood and cowl panel are the primary body color in all of the two tones in your attachment. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-29-2018, 04:30 PM | #7 |
Could it originally have had the sport stripes that were removed? It seems like I've seen those with a secondary color on the hood.
06-29-2018, 05:49 PM | #8 |
Still worth 1500.00 even with all the AC stuff missing
07-02-2018, 04:14 PM | #9 |
Thanks for the info everyone.
07-04-2018, 12:05 AM | #10 |
When you open the hood look @ the reinforcement on the aftermarket hoods you see that the reinforcement is much thinner then factory (and lighter)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
