Old 01-31-2020, 05:45 PM   #226
cornerstone
cornerstone's Avatar
Re: Walter DeWayne...Walt for short
Originally Posted by nlped View Post
I got Walter moved over to the 2-post and broke him apart. But here are a coupe of pictures to show front at approximate ride height and how close the rear bumper gets to the pavement with the biga$$ 29-1/2” tall tire.
How about a side shot showing the stance? Lovin’ what I’m seeing!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 01-31-2020, 06:38 PM   #227
nlped
nlped's Avatar
Unfortunately, it didn’t have the bed on it. And now it’s apart so I can fit the Slosh Tubz, PorterBuilt heater box delete pieces and hood hinges.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-01-2020, 01:34 AM   #228
cornerstone
No problem man. Thanks for that pic. I really like where you have the air tanks mounted, I may change mine to the same location. I've got dual compressors mounted on the side of the frames rail behind the rear wheels with a single air tank that is behind my boyds undermount tank. I made my own brackets, but didn't realize that placement would not let me add a hitch. Those are PB compressor and tank mounts correct?
Brian
Old 02-01-2020, 10:35 AM   #229
nlped
nlped's Avatar
^^^Yes, they are the PB exomounts.
Carter
Old 02-02-2020, 06:44 PM   #230
nlped
nlped's Avatar
I wasn’t feeling well yesterday so I didn’t get anything done. But I’m feeling better today, so I went to work on getting the Slosh Tubz installed. WOW!!! What a PITA, but they are in. And, low and behold...Walter now lays the front PorterBuilt kmember on the ground and the 255/45r20’s are free and clear. I wished the front bumper was on, but I can envision it.
Carter
Old 02-02-2020, 06:56 PM   #231
68bowtie
68bowtie's Avatar
Woah!! Looking good.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 02-02-2020, 08:04 PM   #232
nlped
nlped's Avatar
I’m surprised that I’m not having issue with clearance between the cab and the engine/trans. I haven’t put the high hump in yet and I still have clearance. Which makes me think that after installing the high hump, I should be able to raise the engine another 1/2”, which would allow the passenger side header to clear the lower control arm.
Carter
Old 02-02-2020, 08:08 PM   #233
nlped
nlped's Avatar
Thanks! Long way to go, but I’m really gonna try and stay focused on him this time.
Carter
Old 02-02-2020, 10:24 PM   #234
SCOTI
SCOTI's Avatar
Looks good. I've been curious about clearance for mine as well. I just relocated mine to the shop so I now have the truck & PBC4DM in the same location. Might get a wild hair & find out sooner vs. later 🤓
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-15-2020, 07:53 PM   #235
nlped
nlped's Avatar
I’ve been so busy with real life (flu, flooding, job responsibilities, etc) that I haven’t really had much shop time the last 2 weeks. But today was a productive shop day.
After some more cleaning and removal of pieces/parts that won’t be a part of the final product, I got around to actually working on Walter. I put him up on the lift and threw an angle finder on the tail shaft of the trans to realize I had 8 degrees down...that’s to much! So, I put the pole jack under the trans crossmember and raised the trans up until it hit the cab which only netted me 5-6 degrees. Which just means that the high hump will be used after all. In the process of doing all this, I found out that with the raising of the trans; the passenger side header now clears
Carter
Old 02-16-2020, 08:17 PM   #236
nlped
nlped's Avatar
I got a little bit more done today. Pulled out the front & rear glass. Only bad spot is d/s lower area of windshield.
Carter
Old 02-16-2020, 08:19 PM   #237
nlped
nlped's Avatar
The other 3 notorious spots were just crusty but intact. The back was spotless so no pictures.
Carter
Old 02-16-2020, 08:22 PM   #238
nlped
nlped's Avatar
Oh... & thank goodness that I remembered having this little jewel for removal of the wiper arms.
Carter
Old 02-16-2020, 08:26 PM   #239
nlped
nlped's Avatar
After removal of the cowl panel, I found a huge wasp nest on the d/s and an even bigger mouse nest on the passenger side..
Carter
Old 02-17-2020, 06:42 PM   #240
nlped
nlped's Avatar
Got the transmission crossmember installed with -3 degrees at the output. This also allows me to install the passenger side header without issue. Hell, even the collector is higher than the lowest point of the frame, so I shouldn’t have any problems with boogering them up.
Carter
Old 02-18-2020, 12:28 AM   #241
TA_C10
TA_C10's Avatar
Looking good man, glad to see your new promotion as lead exterminator is going so well too
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-18-2020, 09:12 PM   #242
nlped
nlped's Avatar
I’m very pleased that there weren’t any live critters. Especially the wasps!
Carter
Old 02-23-2020, 09:17 PM   #243
nlped
nlped's Avatar
No pictures, but I got a little bit more done today. Now that I know the cab & frontend fit without issue, I’ll separate them from the chassis. Then I’ll get the chassis and motor finalized and do the firewall and interior on the cab separately. Then I’ll marry them back together and do the wiring & such.
Carter
Old 02-26-2020, 04:24 AM   #244
C10agent
C10agent's Avatar
I really like your build and your choice on the level 1 drop member. Question, when laid out, are the front wheels pretty straight up and down? I ask because I am running PB narrow arms on a factory crossmember and the slant pretty good laid out. Looking to get a new PB drop member but was curious first. Thanks, Neil
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 02-26-2020, 09:26 AM   #245
nlped
nlped's Avatar
Hey Neil,
They are pretty straight up and down considering its still only had a tape measure alignment for toe. I feel like it’ll be much better once the alignment is correct.
Carter
Old 02-26-2020, 11:32 AM   #246
SCOTI
SCOTI's Avatar
What are the header details? I have Sandersons for a BB Chevelle on mine w/the modified stock front set-up. Won't know how the Sandersons work until the C4DM swap. Never hurts to know other possible options.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-26-2020, 12:01 PM   #247
nlped
nlped's Avatar
I’ll get that info this evening. I know they are ceramic coated BBC Chevelle headers, but I can’t remember if they are hooker’s or Flowtech. But they FIT
Carter
Old 02-26-2020, 08:36 PM   #248
C10agent
C10agent's Avatar
Last question, what front version of the PB k member do you have and did you go with the narrowed arms as well? Really like the stance, mine will be very similar, laying pinch isn’t my jam.
Neil...............
TEXAS Y'ALL!!
Old 02-28-2020, 11:08 PM   #249
nlped
nlped's Avatar
I’m not really sure which iteration I have, but it’s the now defunked touring k-member. So, It will lay the k-member on the ground but no need to notch the frame for the r&p. Probably about a 1” to 2” lower than the mild k-member. And I do have the narrower front control arms.
Scoti, they are Flowtech headers for a 68-72 bbc chevelle. Ceramic coated and seem to be very heavy duty construction.
Carter
Old 02-29-2020, 12:10 AM   #250
SCOTI
SCOTI's Avatar
Excellent. Thanks for the info. I'm going to do some Googling 😎👍
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
