Old 06-03-2024, 08:14 PM   #101
SeventyOne
Re: Amp Research Powerstep
Originally Posted by Blazerowner View Post
One thing to note the wiring is grounded together for the interior lights. I had to cut the ground from the right side to stop both steps from coming down with one door open.
That's what the diodes are for that HB provides. But I guess you found another way to do it?
SeventyOne is offline   Reply With Quote
Old 06-03-2024, 08:57 PM   #102
Blazerowner
Blazerowner's Avatar
No I used the diodes and still had the issue. I was wondering why that didn’t work. I just eliminated the bridged ground and I think that solved the problem. Edit - I see I installed them wrong now. Oh well not a big deal. I might fix them later.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 06-04-2024, 10:16 PM   #103
Blazerowner
Fixed the wiring. Now it works as it should.
I trimmed my inner fenders. Used an air body saw. Came out pretty good. I just need some touch up paint and see if they clear.
Kirk
66 Nova
Old 06-05-2024, 12:28 PM   #104
SeventyOne
Looks good. I dont have access to an air saw so i'll have to finesse it with my grinder/cut off wheel and maybe use a drill bit to radius the corners.
Old 06-05-2024, 03:24 PM   #105
Blazerowner
Highly recommend the air saw if you can buy one but the cut off wheel and grinder will work. Its hidden so it doesn’t have to be pretty.
Kirk
66 Nova
