Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-30-2024, 10:06 AM   #1
3QTRTONS
3QTRTONS's Avatar
vin ?
I'd like to get an accurate handle on this...
My VIN plate is as follows:
C - Chevrolet (1972 only)
C - 2wd
E - 8 cylinder
6 - 60 series
1 - Conventional Cab?
6 - Check #?
V - Plant location?
104528 - (4,528th unit built)
Any input is welcome. This plate is about it for identifiers.
[btw, the vin is NOT from truck in my avatar]
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 07-30-2024, 10:53 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: vin ?
We used to carry these VIN cards around in our pocket (along with our pocket protector and note cards).
1 = "Conventional Cab" just means a regular two door body style with a long nose (not cabover, and not four door)
6 = "Check digit" - my card doesn't show a check digit; check digits did not come into use until 1981. In any case it is a randomly assigned digit to fill that spot so that one can't arbitrarily re-create a VIN after the fact. (You have to know the specific check digit in order to know the accurate full VIN).
V = Pontiac Michigan (South Blvd, as opposed to Opdyke Rd Light Duty, which started with GMT400, or headquarters at Montcalm/Joslyn, which was passenger car only).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-30-2024, 11:12 AM   #3
3QTRTONS
3QTRTONS's Avatar
Re: vin ?
THAT'S THE TICKET!!!
(I'm from the pocket protector generation as well)
Thanks MUCH
1988 V30 Fire Truck
Old 07-31-2024, 02:31 PM   #4
Bob B.
Re: vin ?
K
Question: Was Opdyke Road sometims called 'Pontiac East'? I thought they built medium duty conventionals there from 1973 to 1984 or so. Thanks!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 07-31-2024, 04:53 PM   #5
Keith Seymore
Re: vin ?
Yes - Opdyke Rd was called Pontiac East.
Maybe I am remembering incorrectly and it was re-fit in order to produce GMT400 trucks.
I've got some charts I made that show when the various plants came and went. I'll take a look at it next time I come across them.
K
1979-1986
1986 - 2019
Old 07-31-2024, 09:46 PM   #6
Bob B.
Re: vin ?
Thanks! I have this brochure in my collection from late 1972, and it mentions a new plant in Pontiac:
Old 08-01-2024, 07:32 AM   #7
Keith Seymore
Re: vin ?
Thanks for posting that!
K
1979-1986
1986 - 2019
Old 08-01-2024, 12:34 PM   #8
Bob B.
Re: vin ?
Looks like that might be Pontiac East, is that Opdyde Road in front? I think GM moved the medium duty trucks back to South Blvd. sometime in the early 80's and retooled Pontiac East for the GMT400's. I believe it was closed for a number of years. I had a good friend that build the medium duty GMT530's at Janesville WI. for years.
Interesting stuff!
Those 1973-1989 medium duty conventionals were sure good trucks, I put a lot of miles on them.
Old 08-01-2024, 01:53 PM   #9
Keith Seymore
Re: vin ?
Yes - right about here:
HQ was on South Blvd; motor homes (and later the Truck Validation Center) were off the map in the upper LH corner where the M-1 Concourse now resides.
K
1979-1986
1986 - 2019
