Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-30-2024, 10:06 AM   #1
3QTRTONS
3QTRTONS's Avatar
vin ?
I'd like to get an accurate handle on this...
My VIN plate is as follows:
C - Chevrolet (1972 only)
C - 2wd
E - 8 cylinder
6 - 60 series
1 - Conventional Cab?
6 - Check #?
V - Plant location?
104528 - (4,528th unit built)
Any input is welcome. This plate is about it for identifiers.
[btw, the vin is NOT from truck in my avatar]
1969 ES5500 B E A S T / 1974 K20 / 1976 K20 Suburban / 1983 C10 'farm truck' / 1984 K10 Suburban / 1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 07-30-2024, 10:53 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: vin ?
We used to carry these VIN cards around in our pocket (along with our pocket protector and note cards).
1 = "Conventional Cab" just means a regular two door body style with a long nose (not cabover, and not four door)
6 = "Check digit" - my card doesn't show a check digit; check digits did not come into use until 1981. In any case it is a randomly assigned digit to fill that spot so that one can't arbitrarily re-create a VIN after the fact. (You have to know the specific check digit in order to know the accurate full VIN).
V = Pontiac Michigan (South Blvd, as opposed to Opdyke Rd Light Duty, which started with GMT400, or headquarters at Montcalm/Joslyn, which was passenger car only).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-30-2024, 11:12 AM   #3
3QTRTONS
3QTRTONS's Avatar
Re: vin ?
THAT'S THE TICKET!!!
(I'm from the pocket protector generation as well)
Thanks MUCH
Old 07-31-2024, 02:31 PM   #4
Bob B.
Re: vin ?
K
Question: Was Opdyke Road sometims called 'Pontiac East'? I thought they built medium duty conventionals there from 1973 to 1984 or so. Thanks!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 07-31-2024, 04:53 PM   #5
Keith Seymore
Re: vin ?
Yes - Opdyke Rd was called Pontiac East.
Maybe I am remembering incorrectly and it was re-fit in order to produce GMT400 trucks.
I've got some charts I made that show when the various plants came and went. I'll take a look at it next time I come across them.
K
1979-1986
1986 - 2019
Old 07-31-2024, 09:46 PM   #6
Bob B.
Re: vin ?
Thanks! I have this brochure in my collection from late 1972, and it mentions a new plant in Pontiac:
Old 08-01-2024, 07:32 AM   #7
Keith Seymore
Re: vin ?
Thanks for posting that!
K
1979-1986
1986 - 2019
Old 08-01-2024, 12:34 PM   #8
Bob B.
Re: vin ?
Looks like that might be Pontiac East, is that Opdyde Road in front? I think GM moved the medium duty trucks back to South Blvd. sometime in the early 80's and retooled Pontiac East for the GMT400's. I believe it was closed for a number of years. I had a good friend that build the medium duty GMT530's at Janesville WI. for years.
Interesting stuff!
Those 1973-1989 medium duty conventionals were sure good trucks, I put a lot of miles on them.
Old 08-01-2024, 01:53 PM   #9
Keith Seymore
Re: vin ?
Yes - right about here:
HQ was on South Blvd; motor homes (and later the Truck Validation Center) were off the map in the upper LH corner where the M-1 Concourse now resides.
K
1979-1986
1986 - 2019
