11-05-2024, 09:11 PM | #5101 |
Re: What did you do to your truck today.The 3rd chapter
Forgot to show the ball joint tool in action . Worked super easily on the lower joints . Had to take off the portioning valve to get some adapters for the lines to work . Trip to NAPPA and it done .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
11-06-2024, 08:02 PM | #5102 |
Got the brakes buttoned up today the brake line adapters worked well. The Duralast brake hoses worked out better than expected . I did have to file the head to fit the brackets . And add some scuff guard wher it just touches the upper control control arm
11-07-2024, 07:50 PM | #5103 |
All back together and driving . Total front drop 5 1/2 inches rear 4 . I’m thinking of going with 1 inch blocks on the rear .
11-08-2024, 10:18 AM | #5104 |
Totally stealing this trick. Thanks for sharing
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
11-08-2024, 12:52 PM | #5105 |
Prepping for pulling the drive train.
Dave R. 1972 K20 1972 C20 Highlander 1967 C10 |
11-08-2024, 01:07 PM | #5106 |
11-08-2024, 01:10 PM | #5107 |
11-08-2024, 04:13 PM | #5108 |
Finally got around to getting the seat new foam and cover. Fixed broken springs. What a difference in the ride.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
11-08-2024, 07:23 PM | #5109 |
Thanks. It's the one you've been giving me help with on the column. Keeping it original, but the 283 is tired and needs some love.
11-08-2024, 07:26 PM | #5110 |
11-08-2024, 11:57 PM | #5111 |
Looks nice.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-08-2024, 11:58 PM | #5112 |
Me too.
11-09-2024, 08:59 PM | #5113 |
Had the alignment done today . While it was on the rack I trimmed the bump stops ride is much nicer now not bottoming out.
11-10-2024, 02:44 PM | #5114 |
Lookin real good
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
11-10-2024, 05:09 PM | #5115 |
Hey the lights even work. On my way back from vacation I stopped at Classic Parts in KC to pick up a new bumper and front grill assembly (saving about $250 on shipping).
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Yesterday, 06:49 PM | #5116 | |
I've never claimed to be a welder -my intent was only to tack the seam together since the "unfinished" theme matches what's left of the box. Also, I quickly sketched the fuel filler housing part in AutoCAD and included dimensions. Feel free to use the attached PDF or modify for your application. A couple disclaimers: 1. Coordinate the length (and bending) or your fuel filler hose with the height of the fuel filler housing and where you would like it mounted. 2. I took the metal sheet to a local machine shop and they charged me $100 to cut the large center hole, so needless to say I did the rest of the cutting and bending myself. Parts used: Blazer style fuel tank: Classic Performance Products Fuel Tank Conversion Kit 21 Gallon OEM-Style Chevrolet C10 1967-1972 Classic Performance Products: 6772FMT-K Filler with Keyless Cap: ISURE MARINE 1-1/2"(38mm) Boat Fuel Deck Fill/Filler with Keyless Cap with Screws, Marine Mirror Polished 316 Stainless Steel Hardware Angled Neck for Boat Yacht Caravan Air breather elbow (I drilled and tapped a hole in the filler): Podavelle 1/4 NPT Male to 3/8 Hose Barb Fitting Adapter 90 Degree Aluminum Black Fuel filler neck: Gates 24702 Flexible Gasoline Fuel Filler Neck Hose-3' Length, Inner Diameter 1 3/8" Tank vent valve: Holley 19-174 Remote Mount Vent Valve
'67 c10 cst farm truck |
