Old 11-05-2024, 09:11 PM   #5101
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Forgot to show the ball joint tool in action . Worked super easily on the lower joints . Had to take off the portioning valve to get some adapters for the lines to work . Trip to NAPPA and it done .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-06-2024, 08:02 PM   #5102
72c20customcamper
Got the brakes buttoned up today the brake line adapters worked well. The Duralast brake hoses worked out better than expected . I did have to file the head to fit the brackets . And add some scuff guard wher it just touches the upper control control arm
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-07-2024, 07:50 PM   #5103
72c20customcamper
All back together and driving . Total front drop 5 1/2 inches rear 4 . I’m thinking of going with 1 inch blocks on the rear .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-08-2024, 10:18 AM   #5104
loudchevy
loudchevy's Avatar
And add some scuff guard where it just touches the upper control arm
Totally stealing this trick. Thanks for sharing
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-08-2024, 12:52 PM   #5105
dave6672
dave6672's Avatar
Prepping for pulling the drive train.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 11-08-2024, 01:07 PM   #5106
Chevys4life
It has a nice stance to it right now.
Chevys4life is offline   Reply With Quote
Old 11-08-2024, 01:10 PM   #5107
pjmoreland
pjmoreland's Avatar
Wow. What a nice original truck.
pjmoreland is online now   Reply With Quote
Old 11-08-2024, 04:13 PM   #5108
TxGary
TxGary's Avatar
Finally got around to getting the seat new foam and cover. Fixed broken springs. What a difference in the ride.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 11-08-2024, 07:23 PM   #5109
dave6672
dave6672's Avatar
Thanks. It's the one you've been giving me help with on the column. Keeping it original, but the 283 is tired and needs some love.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
Old 11-08-2024, 07:26 PM   #5110
pjmoreland
pjmoreland's Avatar
I'm looking forward to seeing updates on your progress.
Old 11-08-2024, 11:57 PM   #5111
3757chevy
3757chevy's Avatar
Looks nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-08-2024, 11:58 PM   #5112
3757chevy
3757chevy's Avatar
Me too.
MIKE
Old 11-09-2024, 08:59 PM   #5113
72c20customcamper
Had the alignment done today . While it was on the rack I trimmed the bump stops ride is much nicer now not bottoming out.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-10-2024, 02:44 PM   #5114
LNP
Lookin real good
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 11-10-2024, 05:09 PM   #5115
Orange Crate
Orange Crate's Avatar
Hey the lights even work. On my way back from vacation I stopped at Classic Parts in KC to pick up a new bumper and front grill assembly (saving about $250 on shipping).
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 11-12-2024, 06:49 PM   #5116
crazyjeenyus
crazyjeenyus's Avatar
Originally Posted by crazyjeenyus View Post
Installed the Blazer style fuel tank in the '65. My box is in really rough shape, and the wood is rotten in spots, so I opted to perform the installation while leaving the box on. I couldn't find any online resources for this, so I documented the installation and posted it on youtube.
Here's the link if anyone cares to watch:
https://www.youtube.com/watch?v=MQ_JNM3lkpA
Cheers!
We took the next step and installed the fuel filler housing and connected the fuel fill tube and air relief tube.
I've never claimed to be a welder -my intent was only to tack the seam together since the "unfinished" theme matches what's left of the box.
Also, I quickly sketched the fuel filler housing part in AutoCAD and included dimensions. Feel free to use the attached PDF or modify for your application. A couple disclaimers:
1. Coordinate the length (and bending) or your fuel filler hose with the height of the fuel filler housing and where you would like it mounted.
2. I took the metal sheet to a local machine shop and they charged me $100 to cut the large center hole, so needless to say I did the rest of the cutting and bending myself.
Parts used:
Blazer style fuel tank: Classic Performance Products Fuel Tank Conversion Kit 21 Gallon OEM-Style Chevrolet C10 1967-1972
Classic Performance Products: 6772FMT-K
Filler with Keyless Cap: ISURE MARINE 1-1/2"(38mm) Boat Fuel Deck Fill/Filler with Keyless Cap with Screws, Marine Mirror Polished 316 Stainless Steel Hardware Angled Neck for Boat Yacht Caravan
Air breather elbow (I drilled and tapped a hole in the filler): Podavelle 1/4 NPT Male to 3/8 Hose Barb Fitting Adapter 90 Degree Aluminum Black
Fuel filler neck: Gates 24702 Flexible Gasoline Fuel Filler Neck Hose-3' Length, Inner Diameter 1 3/8"
Tank vent valve: Holley 19-174 Remote Mount Vent Valve
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old 11-14-2024, 05:12 AM   #5117
ohboy321
ohboy321's Avatar
I installed a new ignition switch this morning. The old one all of a sudden would not engage the starter solenoid. Voltage check showed it was only getting an intermittent 7-8 volts on the purple wire.
Based on a lot of forum comments about the reproduced versions of the switch, I bought a NOS Delco Remy. Glad that the failure happened while the truck was in the garage.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke Lariat
2007 BMW X3
2023 BMW X3 M-Sport
2020 BMW 540xi M-Sport
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
Old 11-14-2024, 11:17 AM   #5118
72c20customcamper
Driving the 68 home last night and it started to buck and stumble . I removed some plugs and found this on number 1 and 3 rest were great little stumped . I put two new plugs in checked the timing which was dead on . Truck burns oil but that shouldn’t cause this .
Plugs have about 1000 miles
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-14-2024, 11:37 AM   #5119
hdrolling
hdrolling's Avatar
That was a hard 1000 miles, they look about 30 years old. I bet the truck is running great with new plugs!
Do you keep your truck parked outside?
1972 C10 Step Side short bed
hdrolling is offline   Reply With Quote
Old 11-14-2024, 12:37 PM   #5120
72c20customcamper
Truck is inside . I put them in this spring and haven’t really driven it much but everything flash rusts here almost immediately.
Runs good now but I’m a little concerned if it happens again . They don’t look overheated or like they ran lean
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-14-2024, 01:48 PM   #5121
Steeveedee
Who Changed This?
Steeveedee's Avatar
Do you have a bore scope? I'd be for checking all cylinders for detonation damage. But it could just be poorly manufactured spark plugs?
~Steven
Simi Valley, CA
Old 11-14-2024, 02:48 PM   #5122
72c20customcamper
The ol 327 is real tired I’m getting ready to bring the 350 that came out of my 72 to be rebuilt looking for some double hump heads to rebuild if not I’ll just buy a set of Edelbrock heads I will definitely be doing the roller cam retrofit . I do have a cheap bore scope I will check the piston tops .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-15-2024, 05:37 PM   #5123
72c20customcamper
Changed out the fuel pump on my 72 . It was a new unit when I put the new engine in the truck this spring . Going to change the oil tomorrow just for insurance.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-16-2024, 01:23 AM   #5124
PowerdbyChevy79
PowerdbyChevy79's Avatar
This is so nice...
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 11-17-2024, 06:15 PM   #5125
72c20customcamper
New headlight switch on the stepside. The dash lights went out and no amount fiddling with the knob made them work
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
