Old 05-23-2010, 06:22 PM   #1
pvkj454
Cummins Powered Crew Dually
I am converting my Cummins powered M1008 to a crew cab dually.
I spliced the front section of my frame to a 2wd crew cab frame using a Z splice between the 2nd and 3rd cab mounts. I can leave everything as is on the Cummins conversion that way. I also bought another 2wd frame and cut it apart to use the frame rails to fully box my frame.
Cab is from an Air Force truck from Greenland. It has the common forklift damage on the door like many military trucks that are sent to auction.
I got the 19.5 wheels powder coated, bought some new tires and wheel adapters.
I am using my original bed because it is in better shape and modifying it to accept the dually fenders.
I removed the cab and bed, cut the original frame and the crew cab frame using a Z cut with an 8" long horizontal line. I got a professional welder to weld the splice. He used a stick instead of a mig. I have never had one of my welds fail but I have no formal training.
I fully boxed the frame with the extra frame rails. The crew cab frames use individual mounts at the rear of the cab and the standard cabs have an X-member. I used the X-member since the holes are in the same location. I also built a gooseneck hitch for it.
I had the the cab media blasted and I epoxy primed it and started on the body work. Then we mounted it on the frame and sprayed a coat of black epoxy. Afterward it will be high build urethane and hours of block sanding. The paint will be PPG 9300 black single stage urethane with the last coat 50% clear. I bought 1 gallon and 2 quarts of black. I hope that will be enough with the 2 quarts of clear.
pvkj454 is offline   Reply With Quote
Old 05-23-2010, 08:39 PM   #2
Matt Man
Matt Man's Avatar
Re: Cummins Powered Crew Dually
that looks siiiiiiiick, what kind of tires are those? and how much lift?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-23-2010, 10:10 PM   #3
muddyblazer02
muddyblazer02's Avatar
I've wanted to do this for years!
Ken
truck junkie
muddyblazer02 is offline   Reply With Quote
Old 05-23-2010, 10:36 PM   #4
Stitch
Location: Where I come from, it's cornbread and chicken...
x2 on this and what kind of wheels also...are they semis or something else...I see that they are 10 lug...did you get them off a bread truck?
Stitch is offline   Reply With Quote
Old 05-24-2010, 09:51 AM   #5
palposity
palposity's Avatar
Awesome job man!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 05-24-2010, 07:47 PM   #6
pvkj454
The wheels are 19.5"x7.5" steel Accuride. They are the 10 lug semi pattern and used mostly on large roll backs and delivery trucks. Sometimes on semi trailers.
The tires are P245-70 14 ply.
The front springs are Rancho heavy duty and I think they rate them at 3" lift. The rear lift blocks are 4" tall and there is a 1" body lift to make my intercooler fit.
Thanks for the compliments everyone.
Old 05-24-2010, 08:01 PM   #7
Gemp
Gemp's Avatar
Wow, Nice work....It looks killer just sitting bare frame.
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 05-24-2010, 10:35 PM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thats awesome. I think a Cummins crew cab 4x4 is my next project too! Good job so far.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-06-2010, 01:14 PM   #9
pvkj454
Got the cab and fenders painted. It was too big to fit in my neighbors paint room so we sprayed it in my shop.
Old 06-06-2010, 09:19 PM   #10
STOCKISH
STOCKISH's Avatar
Beautiful. I'm getting jealous!
--Josh
Old 06-07-2010, 09:06 PM   #11
ghettoluxury
ghettoluxury's Avatar
looks great!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 06-07-2010, 09:25 PM   #12
pvkj454
Thanks everyone.
Old 06-07-2010, 09:33 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks really nice! I'm trying to talk my brother into painting his 88 V30 black and silver 2 tone. I love those CC LB DRW trucks in black!
Ryan
1969 Chevy milk truck
Old 07-11-2010, 05:07 PM   #14
pvkj454
Finally got it all painted and working on assembly.
Old 07-12-2010, 03:39 AM   #15
Matt Man
Matt Man's Avatar
sick
Old 07-12-2010, 10:22 AM   #16
Davidmichael
Davidmichael's Avatar
wow, this build is awesome.
Davidmichael is offline   Reply With Quote
Old 07-12-2010, 03:12 PM   #17
Dieselwrencher
It is looking very nice!
Ryan
Old 07-12-2010, 09:42 PM   #18
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That looks awesome dude!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 08-01-2010, 06:16 PM   #19
Stitch
Did you just bolt the adaptera onto the srw front and rear hubs or did you change the hubs to drw hubs?
Old 08-01-2010, 06:23 PM   #20
kSStamp0182
LSX addict
kSStamp0182's Avatar
thats gonna be one helluva sweet ride man!
kSStamp0182 is offline   Reply With Quote
Old 08-01-2010, 07:48 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is a great build... nice work thus far!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-01-2010, 07:54 PM   #22
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Friggin awesome! Thats a great looking truck, and a great powerplant! I love it! Where did you get the 19.5's? What size tires? What transmission?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-02-2010, 05:52 PM   #23
pvkj454
Swapped to dually hubs and a dually Dana 70 rear.
The 19.5 wheels came from a big truck salvage yard. The tires are Michelin P245-70-19.5 and the transmission is a Dodge NV4500 with a Chevy tail housing and output shaft.
Thanks,
Old 08-02-2010, 10:46 PM   #24
thirdstreettito
Resident of Here
Thanks,
Was the truck a manual already? Or did you convert to manual?
~Bradley~
Miss having a truck
Old 08-05-2010, 11:09 PM   #25
pvkj454
It had a 400 turbo.
