02-10-2011, 08:42 PM | #1 |
Loading.....
Like I needed another one of these things....
Picked this Hefty Smurf next to the border in Texas yesterday.... (Border Patrol was highly confused)
Mostly rust free, orig color. Needs rockers and some kick panel work. I may pop the 6.0 from my 2002 2500HD in it and make a shop truck. Here it is before any cleaning or repairs have been done. Wish me luck.
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 K20 LWB GMC '72 K5 1-ton gear 468BB ‘79 K20 LWB GMC ‘86 K30 GMC High Sierra C&C Single Cab ‘94 LWB GMC 2500 4x4 '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '01 K2500 Yukon Safari 6.0 ‘06 1500 LWB 4x4 5.3 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 2500HD x-cab duramax 4x4 '11 2500HD Single Cab Duramax 4x4 |
02-10-2011, 09:02 PM | #2 |
Man of Mini-Talents
Re: Like I needed another one of these things....
Doesn't look too bad. Good luck!
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-10-2011, 10:10 PM | #3 |
yes, i do
hey thanks for getting me that front clip i need. awesome looking truck. i prefer the gmc looks to the chevy looks on these
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
02-10-2011, 10:50 PM | #4 |
Eat, Sleep, Drive a Chevy
Looks like it has a future! Whats the story with the truck in the garage?
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
02-11-2011, 12:12 PM | #5 | |
Loading.....
http://austin.craigslist.org/pts/2208587760.html
02-11-2011, 12:14 PM | #6 |
Loading.....
Truck in the Garage is my roommate's '68 SWB - we are currently in a race to see who's driving daily first. He's currently battling a rusty interior roof panel and needs someone to weld in a replacement panel.... Suggestions?
02-12-2011, 09:55 PM | #7 |
Loading.....
Spent the day farting around on the Smurf. Located some parts laying around, Pressure washed the engine bay and underneath, wet sanded some of the oxidation off, swapped to some less crappy wheels, changed the oil.
Anyone near Austin have a gently used front bumper and driver's eyebrow for a GMC? Lookin' better!
02-20-2011, 01:39 AM | #8 |
Loading.....
Picked up some parts from a "cut to bits mid 70's 2x4 blazer" this week - Today I dropped the rear with a 2" shackle, re-welded some exhaust parts, scrapped the front suspension and replaced it with my new parts - disc brakes, stainless lines, new shocks, 2" drop shackles, (i cut the springs one coil also) and a few other odds and ends. It was along day. Things are looking a little more hotrod. This week I'll have some rotors drilled 6 lug to get back to my turbines.
Next up, sway bar, steering stabilizer, remove leafs to match front and then get some rust repair panels patched in.
02-20-2011, 02:12 AM | #9 |
VA72C10
Looking good! Love the new stance!
Looking for a 67-72 swb or blazer project in or around VA. |
02-21-2011, 12:31 AM | #10 |
Loading.....
Thanks VA72C10.
I'm digging the temporary 295s up front...
02-21-2011, 12:35 AM | #11 |
VA72C10
That looks tough!!!
02-21-2011, 12:51 AM | #12 |
Loading.....
Heh, too bad it can't backup the look right now.... We'll get there but the current th350 is a real piece of caca. I remembered today that I have a Edelbrock EFI system sitting in a crate next to a built 700r4 that also lost it's home. Maybe I'll skip the 6.0L swap, add some Vortec heads, that 700r4 and injection system. Keep it simple(ish).
02-21-2011, 07:40 AM | #13 |
Nice ride, looks cool.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
02-21-2011, 01:50 PM | #14 |
Gearhead
Looking good, you work fast! I would say the 700r4, heads and EFI sounds good.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
02-25-2011, 10:00 PM | #15 |
Loading.....
More parts acquired but not yet installed. Here are my 2 Smurfs.
03-05-2011, 01:48 PM | #16 |
Loading.....
Last night I swapped the rear axle and pulled out the bottom 3 leafs. I needed the 5-lug and wanted to lower the rear few inches. To my dismay, even with shorter tires, removing the bottom 3 leaves only gave me 1" drop (31" at the top of the wheel well before and 30" after). Looks a little better but it just doesn't add up. I expected more from all that friggin' work.....
03-06-2011, 01:50 PM | #17 |
laying low
Good lookin Smurf. It was way too tall. Did that 2wd blazer front end have dropped spindles by chance? That's a lot of drop for 1 coil cut. I like the slight rake it has now.
If you haven't already you should check out Dieselarmy13's build thread. His 72 GMC started out looking much like yours. He also has a leaf spring rear.
03-06-2011, 04:59 PM | #18 |
Not bad,looking good
03-06-2011, 05:15 PM | #19 |
Happy Camper
That is a looker for sure!
RIP El Jay! Love you brother! |
03-06-2011, 06:12 PM | #20 |
Big Red - Now its a SWB!
Looks good! You could always put the leaves back in and do an axle flip to get some more drop out of the rear...either that or swap to coils like I'm in the process of doing now.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
03-06-2011, 09:10 PM | #21 |
Loading.....
Thanks for the support guys. I'm having fun with this project - trying to get it done quick and dirty.
Other progress this weekend included tearing all of the wiring apart and undoing the hacks POs had done over the years. Good thing I pulled the driver fenderwell because the main lead was melted the entire way up to the firewall. Took the better part of the day to get that done but now I can say the headlights work! WooHoo! I happened to have a blue automatic column sitting around so I slapped that in there along with the "chevette" steering wheel I recovered from the trash. I kinda dig it after I pulled apart the horn button and covered the chevette emblem with some aluminum tape - see sideways pic. I have another 5 days sitting in my padded cell waiting for truck time. Who knows what I'll have delivered in time for next week! I'm not sure the raked stance is for me. I might have to do a flip and airbags in the rear at some point.
03-06-2011, 09:15 PM | #22 | |
Loading.....
Yeah, Boog - they are 2.5 drop spindles but unfortunately the 1" rotor version so I had to convert the whole friggin thing to 5 lug and ditch my sweet western turbines. GRRR!
I can tell you that the gopher mounds in the pasture out here are tagging the lower A-Arms and making a big mess in under the hood without fenderwells. Any lower and it wouldn't even make it out to the road. #trapped Quote:
03-10-2011, 05:46 PM | #23 |
Loading.....
I can get a set of these wheels in 16" for about $350 - Anyone think they'd look good? (centerline mojave)
03-10-2011, 06:24 PM | #24 |
I have some twenties with tires you could slap on it for cheap.
www.tomthetruck.blogspot.com <-- Aka build thread. |
03-10-2011, 08:54 PM | #25 |
Ilike both the centerlines and the steel wheels. Looks real good.
Posted via Mobile Device |
