View Poll Results: Which one should i do?
EZ Wiring 14 40.00%
Hot Rod Wiring 1 2.86%
Painless Piring -Pickup 18 51.43%
Painless Piring -Street Rod 0 0%
A Member here has one for sale-+Contact info posted 2 5.71%
Voters: 35. You may not vote on this poll
Old 01-21-2012, 06:47 PM   #1
dukkie
My Spoon Is Too Big
dukkie's Avatar
Complete rewiring
72 C20 LWB, elect fan, elect fuel pump, HEI, 90's serpentine belt system with internal regulated alternator, NON A/C, Cab...
Which one should i get?
ez wiring http://www.ezwiring.com/wiring_harness.html
hotrod wires http://www.hotrodwires.com/12Circuit.html
painless wiring pickup http://www.shopatron.com/products/pr...er=10104/302.0
painless wiring street rod http://www.shopatron.com/products/pr...er=10102/302.0
forum member here has one for sale?
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 01-21-2012, 07:35 PM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Complete rewiring
I used the Painless 18 circuit part # 10206 http://www.shopatron.com/home/search...=10206&x=7&y=7 you will need to do some splicing and soldering, but it comes with extra circuits for power windows. fuel pump, fans etc.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 01-21-2012, 07:41 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I would vote for American Autowire or M and H....but I do not see either in your poll
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-21-2012, 07:44 PM   #4
lil hoodlum
lil hoodlum's Avatar
You really should be looking for a wiring harness that has the circuits for everything you will be needing. A 12 circuit wiring harness is just the bare minimum. You should look it at least an 18 circuit wiring harness. I used the Painless wiring harness made for our trucks. It has the correct connections included. I used the 18 circuit truck wiring system (1967-1972) part # 10206. I installed it close to 10 years ago and have had no issues with it. Jegs has it for $388.00!
http://www.jegs.com/i/Painless-Perfo...d=#moreDetails
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 01-21-2012, 08:00 PM   #5
Tmwoodall
I did a lot of reading/searches on this topic the passed few weeks. I came to the conclusion that AAWire was the way to go.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 01-21-2012, 09:34 PM   #6
54belair
54belair's Avatar
Ive used ez wire twice and painless once. Currently have a new ez wire that will go in the 68 when Im ready.
I think they are all good----and fairly easy to use----ez wire is cheaper and the quality is as good.
54belair is offline   Reply With Quote
Old 01-21-2012, 09:38 PM   #7
workinprogress67
Painless 18 circuit as mentioned by keith. Take Your time and it will turn out great. i got mine from jegs with a 100 dollar rebate from painless. it was well worth it.
workinprogress67 is offline   Reply With Quote
Old 01-21-2012, 09:41 PM   #8
CG
BlahBlahBlah
I vote for American Auto Wire also. Ive never seen such a nice complete kit before.
CG is online now   Reply With Quote
Old 01-21-2012, 10:28 PM   #9
dukkie
My Spoon Is Too Big
dukkie's Avatar
If i knew of them i would include it too
Old 01-21-2012, 10:52 PM   #10
schurg
out of curiosity..do these 'universal' kits come with plugs or pigtails that connect to all the accessories in the truck? like the ignition plug, gauge plug, headlight switch, wiper switch, etc. or do you have to reuse the ones you currently have(which seems kinda useless to have to use old connecters). I know some kits come pre terminated, others are more bulk. just curious what others are doing when it comes to the connecters.
schurg is offline   Reply With Quote
Old 01-21-2012, 11:35 PM   #11
68C10HotRod
68C10HotRod's Avatar
I'm going agree with LedZepp & Tmwoodall on the American Autowire too. I have been installing one of these in my 72 Burb using the truck version & it would be perfect for a truck. Very complete & gives you all the correct sockets to make it a near factory install. Also having each wire labeled every couple inches makes it real easy to install. It assumes HEI setup. Not the cheapest around $450 but well worth it.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 01-22-2012, 12:25 AM   #12
Musclerodz
that is where AAW classic Update shines. No reusing any of you 40 year old connectors or bulb receptacles. All new and included with AAW harness including factory guage connection or Autometer. Wiper switch not included but headlight, dimmer, and ignition (except in column applications) are.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 01-22-2012, 01:57 AM   #13
white 67
I used the painless 18 curcuit on my truck but i wish i had not. It has extra wires for everything which is nice but i dont have any of that stuff so now i just have a bunch of unused wires. The harness was not bad i just didnt get the right one for my use.
white 67 is offline   Reply With Quote
Old 01-22-2012, 02:17 AM   #14
Musclerodz
AAW uses multi plug connections for all those extra circuits, so if you do not use them you do not have 20 feet of wire to cut off or roll up under the dash. I hope you terminated all the unused wires or pulled fuses to kill power to them
Mike Redpath
Old 01-22-2012, 11:05 AM   #15
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
AAW.... period
Tom Vogel is offline   Reply With Quote
Old 01-22-2012, 11:27 AM   #16
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Dukkie, I'd vote AAW too man, it's what i'll use when the time comes...heard only god things about them.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 01-23-2012, 04:17 AM   #17
dukkie
My Spoon Is Too Big
dukkie's Avatar
the poll is tied 5 to 5 EZ Wiring and Painless -Truck with zero votes on the others.. Sounds like had i known of and included American Auto Wire they would be at 7
Old 01-23-2012, 04:27 AM   #18
dukkie
My Spoon Is Too Big
dukkie's Avatar
This is basically what i was trying to figure out.. if some vendors charge 4-500 why than can this vendor sell equivalent product for 180
this is information i am unaware of ez, hotrod, painless all require using for example my existing last 2 inches of every wire connection, bulb socket, ect. their porduct just ends as a cut wire and leave it to me to figure out the rest ie. crimp connector, twist nut, solder, or a potato to complete the new wire to my existing end points
And to understand yall correctly you are saying AAW includes new ones with their kit?? in addition they throw in a headlight and ignition switch as well?
Old 01-23-2012, 10:18 AM   #19
LEX
LEX's Avatar
AAW sounds so complete, neat and easy. I see you're local. Are you doing the install yourself or having someone do it?
This is what sold me on the AAW kit. I don't have it, yet, but will be buying their kit soon.
LEX is offline   Reply With Quote
Old 01-23-2012, 10:39 AM   #20
flatfoot77
flatfoot77's Avatar
I'd also go with American Auto Wire their wiring is superior to all the rest they use haevy duty wire and connectors plus you can buy direct from them and cut out the middle man.
www.americanautowire.com
I used their harness to repair the A/C harness and you can see the difference in quality.
flatfoot77 is offline   Reply With Quote
Old 01-23-2012, 11:30 AM   #21
eurospec1
eurospec1's Avatar
EZ wire is not far from me in Florida, Im working with one of their harnesses now on a different project, when i called the tech line i was actually speaking to the owner, who is also the builder/designer/tech guy from the sound of it. Its a great product, and i believe a very small operation and he gave me a ton of help over the phone, which is probably why the price point is much lower. Im happy with it so far and will be putting one in my 68.
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 01-23-2012, 11:35 AM   #22
Tmwoodall
Buying direct cost an extra $90 FYI. RockAuto has them for 439.
Old 01-23-2012, 12:22 PM   #23
CG
BlahBlahBlah
I bought my AAW kit from a board vendor and saved money over buying it direct. And yes the kit comes with headlight switch and ignition switch (with new keys). So you may to have your doors rekeyed if you want to run the same key on everything.
Cant remember which board vendor I bought it from >=(
Old 01-23-2012, 02:21 PM   #24
dcasalena
dcasalena's Avatar
American Autowire part#510089.
Rockauto usually has the best price.
dcasalena is offline   Reply With Quote
Old 01-23-2012, 03:36 PM   #25
dukkie
My Spoon Is Too Big
dukkie's Avatar
Doing it all myself. Just ordered new cab mounts so id like to tackle both of these at the same time while everythings going back together
thats the most important part CG!!!!!
was it Musclerodz?
circut, fuse, wiring
