Re: 1949 Chevy 3600 into a daily driver
I was able to sneak away from work for a 1/2 day today. Was able to get the drive shaft and torque tube disconnected form the tranny. The unbolted the front motor mounts and some misc stuff that was in the way.
Then out came the motor and tranny. Wow.......that is heavy!! My son and I must have scraped 25lbs of crap off the frame. ![]() ![]() I then hit it with some heavy degreaser and the pressure washer!! ![]() ![]() I cleaned up the SBC as well. ![]() |
are you leaving the straight axle front end or are you clipping it?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Leaving the straight axle. Who knows what the future will bring...but for right now I am rocking the stock axle!!
Are you going to give the engine and frame a fresh coat of paint before re-installing? I think it just gives it that clean finished look.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
That is the big debate right now...........might just leave it as is!!
Since you've already pressure washed it, I'd paint it. If nothing else just to make it cleaner/easier to work on in the future.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#7 | |
Just my 0.02
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
Are you going to offset the engine, or move the steering box over.
I plan on offsetting the motor.
I don't think you can off set the motor due to exhaust manifold clearance on the right side. Ive got rams horn manifolds and they clear the right frame rail by about 1" with the engine centered.
I off set the steering box about 30 years ago & it still works fine. |
Maybe that is the case......I will not know until it is mocked up.
I figured a little bit of both would be needed. Little shuffle of the motor, and a little spacing of the steering box.
Awesome progress today.
Bolted the TH350 to the SBC along with the headers and dropped it into Henry to get a test fit and mock up motor mounts and transmission crossmember. Went fairly smooth considering I was working solo. ![]() Chassis Engineering Inc motor mounts. ![]() ![]() ![]() Ready to pull it all out and do the final welding, then paint!! ![]() ![]() |
Looks like that steering box was really in the way!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#15 |
Yea, it was......
#16 |
So after thinking about it for the night.....I decided to offset the motor to the passenger side to allow room for the steering box. I had briefly thought about PS......but decided against it for a number of reasons.
So I spent the better part of a day taking apart what I had completed and making room for the steering box. ![]() The passenger side mount had to be shortened and recessed into the frame rail. The driver side was pulled out of the frame rail. ![]() I used some 1/4-20 bolts to hold everything in place while I pulled the motor and to use them as a reference upon assembly. ![]() I was not happy with the initial welds on the drivers side mount, so I boxed it all in. Overkill.....but I will sleep better at night. ![]() ![]() ![]() After the motor mounts were done....I spaced out the steering box by 1-1/2" with some angle iron and some dom tubing. ![]() The motor has been opened up and looks great. I am going to button it back up, throw a coat of paint on it and call it good. ![]() The punch list is getting smaller!!! |
#17 |
How much did you off set the motor and what brand of headers are you using.
#18 | |
Headers are cheapies off Ebay. http://www.ebay.com/itm/SBC-Small-Bl...85ef9e&vxp=mtr |
#19 |
good job, I'm backing you on the manual box too.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#20 |
I just could not bring myself to do the power steering.....not at this time anyway.
#21 | |
Loving the build bud, my favorite Advance design build on here ![]()
#22 | |
#23 |
Think I have all my bases covered. I just have a couple loose ends.
Any suggestions on what to use as a throttle pedal? TH350 transmission to a 4 x 4 blazer rear end. Any idea's on a approx driveshaft length or a suggested donor? |
#24 |
I used a 73 87 type truck cable and pedal in mine. S 10 or car drive shaft should work if you can find one long enough.
#25 |
Thanks.......I will check it out!!
