Old 05-07-2014, 03:58 PM   #601
PurdueSD
PurdueSD's Avatar
Re: 1949 Chevy 3600 into a daily driver
Awe Henry is about to loose his virginity!
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 05-07-2014, 09:53 PM   #602
Coach529
Coach529's Avatar
Made some headway tonight. The motor and tranny are just about ready to pull. all the extra BS is off it.
Spent some time digging around in the grease and dirt trying to find bolts for the motor and tranny.
What is the easiest method of getting it all out? Together? Separate them?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-08-2014, 09:21 AM   #603
youngrodder
youngrodder's Avatar
I pulled mine out in one piece but my front end was off. It is HEAVY as a complete unit. The most trouble was caused by the floor shifter and other linkage (starter, gas & brake pedals getting hung up). I removed (2) head bolts and replaced them with (2) long eyebolts to hook the chain to. It provided a good anchor point.
Good luck.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-08-2014, 09:26 AM   #604
Coach529
Coach529's Avatar
Good luck.
Marc
I have my complete front clip off Marc. I will give it a shot.
Thanks!!
1949 Chevy 3600
Old 05-08-2014, 01:14 PM   #605
youngrodder
Thanks!!
A few friends to help wrestle it is also not a bad thing. I'm sure you'll gett it.
Good luck
Marc
Old 05-13-2014, 06:45 PM   #606
NEWFISHER
NEWFISHER's Avatar
Awesome
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 05-14-2014, 09:31 PM   #607
Coach529
Coach529's Avatar
I was able to sneak away from work for a 1/2 day today. Was able to get the drive shaft and torque tube disconnected form the tranny. The unbolted the front motor mounts and some misc stuff that was in the way.
Then out came the motor and tranny. Wow.......that is heavy!!
My son and I must have scraped 25lbs of crap off the frame.
I then hit it with some heavy degreaser and the pressure washer!!
I cleaned up the SBC as well.
1949 Chevy 3600
Old 05-15-2014, 10:11 AM   #608
dubie
dubie's Avatar
are you leaving the straight axle front end or are you clipping it?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-15-2014, 04:35 PM   #609
Coach529
Coach529's Avatar
Leaving the straight axle. Who knows what the future will bring...but for right now I am rocking the stock axle!!
1949 Chevy 3600
Old 05-15-2014, 05:21 PM   #610
ghettoluxury
ghettoluxury's Avatar
Are you going to give the engine and frame a fresh coat of paint before re-installing? I think it just gives it that clean finished look.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-15-2014, 05:25 PM   #611
Coach529
Coach529's Avatar
That is the big debate right now...........might just leave it as is!!
1949 Chevy 3600
Old 05-15-2014, 06:18 PM   #612
BlueJeep
BlueJeep's Avatar
Since you've already pressure washed it, I'd paint it. If nothing else just to make it cleaner/easier to work on in the future.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-15-2014, 06:58 PM   #613
focusedontheprize
focusedontheprize's Avatar
I agree and think it would look great painted fresh orange with that blue worn firewall in the back.
Just my 0.02
focusedontheprize is offline   Reply With Quote
Old 05-15-2014, 10:35 PM   #614
ADchevys
Are you going to offset the engine, or move the steering box over.
ADchevys is offline   Reply With Quote
Old 05-16-2014, 08:13 AM   #615
Coach529
Coach529's Avatar
I plan on offsetting the motor.
1949 Chevy 3600
Old 05-16-2014, 10:04 AM   #616
nvrdone
I don't think you can off set the motor due to exhaust manifold clearance on the right side. Ive got rams horn manifolds and they clear the right frame rail by about 1" with the engine centered.
I off set the steering box about 30 years ago & it still works fine.
nvrdone is offline   Reply With Quote
Old 05-16-2014, 10:09 AM   #617
Coach529
Coach529's Avatar
Maybe that is the case......I will not know until it is mocked up.
1949 Chevy 3600
Old 05-16-2014, 10:43 AM   #618
Coach529
Coach529's Avatar
I figured a little bit of both would be needed. Little shuffle of the motor, and a little spacing of the steering box.
1949 Chevy 3600
Old 05-23-2014, 03:26 PM   #619
Coach529
Coach529's Avatar
Awesome progress today.
Bolted the TH350 to the SBC along with the headers and dropped it into Henry to get a test fit and mock up motor mounts and transmission crossmember.
Went fairly smooth considering I was working solo.
Chassis Engineering Inc motor mounts.
Ready to pull it all out and do the final welding, then paint!!
1949 Chevy 3600
Old 05-23-2014, 03:49 PM   #620
Katrina/10
Katrina/10's Avatar
Looks like that steering box was really in the way!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-24-2014, 09:04 AM   #621
Coach529
Coach529's Avatar
Yea, it was......
1949 Chevy 3600
Old 05-26-2014, 10:40 PM   #622
Coach529
Coach529's Avatar
So after thinking about it for the night.....I decided to offset the motor to the passenger side to allow room for the steering box. I had briefly thought about PS......but decided against it for a number of reasons.
So I spent the better part of a day taking apart what I had completed and making room for the steering box.
The passenger side mount had to be shortened and recessed into the frame rail. The driver side was pulled out of the frame rail.
I used some 1/4-20 bolts to hold everything in place while I pulled the motor and to use them as a reference upon assembly.
I was not happy with the initial welds on the drivers side mount, so I boxed it all in. Overkill.....but I will sleep better at night.
After the motor mounts were done....I spaced out the steering box by 1-1/2" with some angle iron and some dom tubing.
The motor has been opened up and looks great. I am going to button it back up, throw a coat of paint on it and call it good.
The punch list is getting smaller!!!
1949 Chevy 3600
Old 05-27-2014, 12:14 AM   #623
ADchevys
How much did you off set the motor and what brand of headers are you using.
Old 05-27-2014, 08:40 AM   #624
Coach529
Coach529's Avatar
I offset the motor 2" to the passenger side.
Headers are cheapies off Ebay.
http://www.ebay.com/itm/SBC-Small-Bl...85ef9e&vxp=mtr
1949 Chevy 3600
Old 05-27-2014, 09:12 AM   #625
99 to Life
99 to Life's Avatar
good job, I'm backing you on the manual box too.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
