04-14-2014, 09:09 PM | #1 |
Re: 5.3 swap build so far
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
04-14-2014, 09:11 PM | #2 |
its the same exhaust as before, just a lot more power!!!
04-14-2014, 09:41 PM | #3 |
that sounds awesome man! what mufflers r u running? kinda sounds like flowmasters to me
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
04-14-2014, 09:43 PM | #4 |
Ya, I think they are knock offs, crazy how different it sounds from before, I don't think my you joints like the added power
04-14-2014, 10:01 PM | #5 |
better look into some new u joints lol
04-14-2014, 10:02 PM | #6 |
Ya I'm getting some tomorrow, they are making that clicking noise before they go bad
04-14-2014, 09:59 PM | #7 |
hey quick question...what did u use for power steering lines? post pics if u have some. I read that the stock c10 lines can work with the 5.3 pump.
04-15-2014, 10:01 AM | #8 | |
yup just pull the weird stuff off the back of the 5.3 pump and slap the stock valve & fitting from the old sbc pump in there. worked like a charm and no leaks. take a sec to flush your box and pump. mine got moisture in it from sitting and made a nice milkshake when i fired it up. |
04-14-2014, 10:01 PM | #9 |
I was able to use the ones from the 5.3, they worked with my gear box, my gear box leaks pretty bad tho
04-15-2014, 11:52 PM | #10 |
Kool thanks fellas
04-19-2014, 05:03 PM | #11 |
Doing odd and end stuff, this truck hasn't seen a overflow tank in ten years!!!
04-19-2014, 09:24 PM | #12 |
Lookin good . I take it you used the stick radiator? I nerd to get a radiator for mine. What did you end up doing for the mufflers?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-19-2014, 09:43 PM | #13 |
I used the same ones as before, They where somewhat new so no need to replace them
04-20-2014, 02:42 PM | #14 |
Fans are about ready to go in!!!! Just gotta eat some Easter dinner
04-20-2014, 08:53 PM | #15 |
Check engine light location
04-20-2014, 08:54 PM | #16 |
My pics always load sideways so annoying
04-20-2014, 09:36 PM | #17 |
Hooked up and ran, no codes at the moment, when it does throw a code it's crazy bright, that just lets you know it's working
04-20-2014, 11:49 PM | #18 |
Custom made shifter for the old KLS-10...deer antler from a few years back
04-22-2014, 08:09 PM | #19 |
Linkage is getting there, gotta make some adjustments
04-24-2014, 03:28 PM | #20 |
so this linkage somewhat worked, didnt want to go into park, so back to the drawing board...i might do something similar except with 1/4 inch steel, i may do the something but go underneath the column instead of over it...pretty frustrating!!!!!
04-24-2014, 03:37 PM | #21 |
any ideas would be very much appreciated!!! not trying to buy too much stuff, still have the old linkage as well
04-24-2014, 07:30 PM | #22 |
I used the stock linkage in my 71 swap just swaped the c channel cup on the trans
04-24-2014, 11:08 PM | #23 |
you got any pics?
04-24-2014, 11:18 PM | #24 |
Looking good. I just picked up the pump fitting for mine as well. I also need to div the linkage. What transmission are you running? I need to do my linkage too.
04-24-2014, 11:20 PM | #25 |
I'm running the 4l60, shifts good, for a couple days i drove around with the linkage coming through my little door window!!! haha...too eager to get her out and about
