#126 |
Re: 5.3 swap build so far
I was able to use the ones from the 5.3, they worked with my gear box, my gear box leaks pretty bad tho
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#127 |
Ya I'm getting some tomorrow, they are making that clicking noise before they go bad
#128 | |
yup just pull the weird stuff off the back of the 5.3 pump and slap the stock valve & fitting from the old sbc pump in there. worked like a charm and no leaks. take a sec to flush your box and pump. mine got moisture in it from sitting and made a nice milkshake when i fired it up. |
#129 |
Kool thanks fellas
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
#130 |
Doing odd and end stuff, this truck hasn't seen a overflow tank in ten years!!!
#131 |
Lookin good . I take it you used the stick radiator? I nerd to get a radiator for mine. What did you end up doing for the mufflers?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
#132 |
I used the same ones as before, They where somewhat new so no need to replace them
#133 |
Fans are about ready to go in!!!! Just gotta eat some Easter dinner
#134 |
Check engine light location
#135 |
My pics always load sideways so annoying
#136 |
Hooked up and ran, no codes at the moment, when it does throw a code it's crazy bright, that just lets you know it's working
#137 |
Custom made shifter for the old KLS-10...deer antler from a few years back
#138 |
Linkage is getting there, gotta make some adjustments
#139 |
so this linkage somewhat worked, didnt want to go into park, so back to the drawing board...i might do something similar except with 1/4 inch steel, i may do the something but go underneath the column instead of over it...pretty frustrating!!!!!
#140 |
any ideas would be very much appreciated!!! not trying to buy too much stuff, still have the old linkage as well
#141 |
![]() Join Date: Sep 2005
I used the stock linkage in my 71 swap just swaped the c channel cup on the trans
#142 |
you got any pics?
#143 |
Looking good. I just picked up the pump fitting for mine as well. I also need to div the linkage. What transmission are you running? I need to do my linkage too.
#144 |
I'm running the 4l60, shifts good, for a couple days i drove around with the linkage coming through my little door window!!! haha...too eager to get her out and about
#145 |
I just slid my pointer on the frame back until it lined up with the shaft on the trans. About 7/16". Bolted it up and never thought about it again.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#146 |
I'm working on it right now
#147 |
You got a pic by chance?
#148 |
I got it man, I had to goto ammco to get the piece to slide it in but so much easier than I was trying to do
#149 |
My view right now...
#150 |
^^^and ofcourse it's sideways!!!
