Old 05-22-2018, 05:47 PM   #1
roger rabbit
running hot
I see a lot of threads about heating and a lot of opinions. What I want to know is who sells the best stock look non aluminum three row radiator? For a 1970 c10 Please reply!
roger rabbit is offline   Reply With Quote
Old 05-22-2018, 07:13 PM   #2
68 P.O.S.
Re: running hot
What size engine is it for? I have no experience, but I've heard good things about the Spectra radiator on Rock Auto.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-22-2018, 08:09 PM   #3
roger rabbit
Re: running hot
350 4 bolt main swb auto power sterring
Old 05-23-2018, 12:38 AM   #4
BCOWANWHEELS
Re: running hot
Just get a 4 core, same price.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-23-2018, 01:04 AM   #5
68 P.O.S.
Re: running hot
Champion radiators have a good rep on the board for being a decent radiator for a decent price. Not exactly stock looking tho. What problems are you having? Temps?
Old 05-23-2018, 01:37 AM   #6
BCOWANWHEELS
Re: running hot
Rock auto
Old 05-23-2018, 07:44 AM   #7
roger rabbit
Re: running hot
Originally Posted by BCOWANWHEELS View Post
Rock auto
Thanks for the info. They are currently out of stock. I could be wrong but the spectra tanks looked like plastic. Are the three and four row all metal? I should be good with a three row, w/o air. Currently have a two row. I believe that is incorrect. Tends to run a tad hot in hot weather,when pulling the boat.
Old 05-23-2018, 07:53 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: running hot
Local O Reilly's has the stock brass radiators.
https://www.oreillyauto.com/detail/b...radiator&pos=0
https://www.oreillyauto.com/detail/b...radiator&pos=1
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-23-2018, 11:50 AM   #9
demian5
demian5's Avatar
Re: running hot
Really?
Construction: Plastic Tank/Aluminum Core
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-23-2018, 04:50 PM   #10
68 P.O.S.
Re: running hot
http://www.championradiators.com/Che...r-V8-1967-1972
Old 05-23-2018, 05:01 PM   #11
BCOWANWHEELS
Re: running hot
on my 250 I run a 7 blade/ no clutch and 160 stat and 4 core brass/copper rad. its my work truck
Old 05-23-2018, 05:20 PM   #12
roger rabbit
Re: running hot
Originally Posted by demian5 View Post
Really?
no plastic please!
Old 05-23-2018, 05:29 PM   #13
roger rabbit
Re: running hot
I have a high performance flex fan my heads have a front left sending unit and a right rear, leads me to believe two left heads,switched to front unit.
checked cap pressure,is working properly getting a better guage reading now. will pull the boat as soon as it quits raining!!
Old 05-23-2018, 05:31 PM   #14
roger rabbit
Re: running hot
Really?
no plastic for me
Old 05-23-2018, 06:32 PM   #15
demian5
demian5's Avatar
Re: running hot
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-23-2018, 07:10 PM   #16
68 P.O.S.
Re: running hot
2 left heads doesn’t make sense to me. From factory, temp gauge sending unit is on driver’s side towards the front of the truck, or left side of head. Passenger side has temp light sending unit towards the rear of the truck, or left side of head once again. So does that mean factory used 2 right side heads on our trucks? I’m guessing you have heads from a different application then? Running the numbers on the heads will tell you for sure.
Old 05-23-2018, 07:33 PM   #17
zosoppp
Re: running hot
The sbc engines have only heads (there is no left/right distinction)
That said the only differences might be if the older heads don't have all the accessory bolt holes in the head ends like the newer ones do.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 05-23-2018, 07:37 PM   #18
BCOWANWHEELS
Re: running hot
lol sbc n bbc heads are same
Old 05-23-2018, 07:43 PM   #19
leddzepp
Moderator
leddzepp's Avatar
Re: running hot
They are a great radiator. If you want it to look original just paint it black
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-23-2018, 08:32 PM   #20
68 P.O.S.
Re: running hot
Old 05-23-2018, 11:36 PM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: running hot
There's gonna be a pipe plug in the head that doesn't have the hole open for the temp sender. Easy to sort out, right?
~Steven
Simi Valley, CA
Old 05-24-2018, 08:55 AM   #22
Steve Cole
Re: running hot
If I were you I would get rid of that flex fan ASAP.
Steve Cole is offline   Reply With Quote
Old 05-24-2018, 02:07 PM   #23
StingRay
StingRay's Avatar
Re: running hot
If it's running hot put in a 4 row. Make sure the shroud fits tight to the rad and seals to it. Make sure the fan is about halfway into the shroud. Run a good clutch fan or an electric. Flex fans like to come apart. Fan performance is optimal with about half the blade in. With all that and a good t-stat it shouldn't overheat in any weather period.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-24-2018, 04:01 PM   #24
roger rabbit
Re: running hot
passenger side is the right head,right and left are determend from driver position
Old 05-24-2018, 04:08 PM   #25
roger rabbit
Re: running hot
left front should be heat sending unit a 350 4 bolt main should have a three row ifsomeone changed the heads or the engine then its all out the window the heads have been changed because it takes the small plugs!!
