Old 09-27-2022, 11:31 PM   #1
slikside
slikside's Avatar
Re: Upgrading Headlights
Subscribed!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 10-10-2022, 08:45 AM   #2
6600DURAMAX
6600DURAMAX's Avatar
HO455 - are you running the Daniel Stern lighting setup ??
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 10-13-2022, 09:41 AM   #3
HO455
HO455's Avatar
Currently I have 25 year old pair of Hella H-4's with relays installed. But I have a brand new set of the Koito H-4's in the garage that I plan on using to do a comparison test with when I install them.
RIP Bob Parks.
Old 10-15-2022, 09:51 AM   #4
72SB
I have the LMC and yes the packageing says made in china....but so far it works fine
I also have one in my 67 Camaro I bought from Speedway for about the same $ a few years ago. It just came in a zip loc bag. IDK origin but assume some place in US make it. I also have had no issues with it either
Time will tell if either presents issues or if a relay needs replacing
72SB is offline   Reply With Quote
Old 10-18-2022, 05:17 AM   #5
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
https://www.lmctruck.com/1967-72-che...stom-headlight
More my style and is my current setup. DOT, clear glass housing with replaceable bulb. I prefer regular halogen bulbs. Cheaper to replace. Easier to find. More of an OEM look.
Wiring setup is required and is brighter than OEM with better light pattern. I've done the same style setup with my '87 Chevy and my Jeep.
It reads "Each headlight includes a wiring adaptor to connect to the appropriate factory wiring."
But I'd recommend the headlight harness.
desert-rat is offline   Reply With Quote
Old 10-18-2022, 05:19 AM   #6
mikey531
mikey531's Avatar
That is what I have now but at my age I need something brighter, I was hoping I could see better at night.
mikey531 is offline   Reply With Quote
Old 10-18-2022, 05:28 AM   #7
desert-rat
Did you use the harness?? Pulls power from the battery making them brighter. Will never be as bright as HID or LED. But these blind oncoming traffic.
Old 10-19-2022, 09:23 AM   #8
Willie Makeit
Willie Makeit's Avatar
my .02 worth on the original question, have always found the Hella E-code housings, good quality H4 bulbs and the relay harness to be as bright or brighter than any Chinese-made LED "kits"
Willie Makeit is offline   Reply With Quote
