Old 09-25-2022, 06:15 PM   #1
Dieselholic92
Dieselholic92's Avatar
Upgrading Headlights
Yes I know I should use the search function, but I’ve been trying it for 20 minutes and I wasn’t really happy with the search results. I finally had one low beam go out on my 72 GMC. I want to upgrade the lighting but I haven’t done much research on it. So I’m wondering what guys would recommend? Picture of my truck.
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 09-25-2022, 08:49 PM   #2
jimijam00
Re: Upgrading Headlights
If search is broken, just scroll down the forum and you'll find 2 or 3 recent threads on the same thing.
jimijam00 is offline   Reply With Quote
Old 09-25-2022, 08:55 PM   #3
70cst
70cst's Avatar
This is a recent thread on upgrading the headlights.
http://67-72chevytrucks.com/vboard/s...d.php?t=837539
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-26-2022, 12:43 AM   #4
Richard
If you want something with modern lighting capability, check this out https://www.dapperlighting.com/colle...s/products/575
Richard
Old 09-26-2022, 12:54 AM   #5
CastIron
CastIron's Avatar
It seems like there's a lot less choices when you have a GMC with 4 headlights. I've purchased Hella H4 headlights (for the low beams) and some Hella relays, but haven't actually installed them yet. If they aren't bright enough with the halogen bulbs I may try an LED replacement. I've tried LED bulbs in 4 vehicles, but was disappointed in 2 of those. A high quality upgraded halogen in the Hella H4 lamps might be the best choice. And it's definitely one of the more affordable.
CastIron is offline   Reply With Quote
Old 09-26-2022, 07:35 AM   #6
70cst
70cst's Avatar
If the GMC takes 7" heaglamps - what I did was buy a set of Jeep Wrangler 7" headlamos and then purchased a pair of LEDS ... also puchased the
Per LocKDoc "Jeep JK Wrangler headlights are a direct bolt in swap for the old sealed beam headlights in our trucks. They even have the 3 lugs on the back for alignment and use the stock '67-'72 trim rings. The headlights have more dome to the lense than the originals." ...
With this being said: I ended up buying a set of used Wrangler Rubicon 2015 headlamps ($30) H4-H13 conversion pigtails ($8.00) - these are a direct fit. And .. AUXBEAMS LEDS 9008 for the headlights and 1157's Parking lights. ($52)
Old 09-26-2022, 08:39 AM   #7
MARKDTN
Don't know about low beams, I would probably at least use a relay kit to get all the power to them you can. That helped a lot on my son's '97 Blazer.
Back in the day, aircraft landing lights use to be the hot ticket for high beams. Not DOT legal but if not abused can really help with times you can use the high beams. Would definitely put relays on them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-26-2022, 10:39 AM   #8
Best thing in the world is to add/build a relay harness to give full 12V to lights. The quad/GMC lights are smaller diameter bulbs, so the Wranglers don't fit. Great for the Chevy's single lamp applications. Not sure who has a good build setup for the GMC style. You would be surprised at the difference a relay harness makes, even with stock bulbs
Old 09-26-2022, 11:07 AM   #9
70cst
70cst's Avatar
Thanks for the info - where is the best place to purchase the relay harness
Old 09-26-2022, 11:55 AM   #10
HO455
HO455's Avatar
Take a look at the Daniel Stern website. Lots of information and he sells only quality products.
https://www.danielsternlighting.com/.../products.html
RIP Bob Parks.
Old 09-26-2022, 01:25 PM   #11
I've got mine thru LMC
https://www.lmctruck.com/1967-72-che...dlight-harness
Old 09-26-2022, 01:44 PM   #12
Southcity
Southcity's Avatar
Holley Retrobrights (LED). Yes they are expensive but they outperform H4 even with relay setup. They look like stock, plug-and-play, no relay required as LED draw is extremely low. In return, you get modern performing LED lighting which will last a very long time and a stock look. They offer 5 3/4 for quad headlight setups or 7" for single headlight setups. Ask me how I know, I run them on my 66 K10 Suburban with no relay, superior lighting performance. Tested them on my other 66 Suburban with relay setup, no light output difference. If you run H4 lighting, relay setup is highly recommended.
https://www.holley.com/brands/holley...nd_headlights/
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 09-26-2022, 01:54 PM   #13
DDassow01
I bought the LMC HD relay harness and it wasn't wired correctly for my stock 1970 GMC. I had to move some connectors around in the harness and then it worked properly. Much brighter and a very worthwhile upgrade.
https://67-72chevytrucks.com/vboard/...=502522&page=4
DDassow01 is offline   Reply With Quote
Old 09-26-2022, 02:34 PM   #14
1967-C10
1967-C10's Avatar
rmsLighting.net exact drop in replacement with great prices !
1967-C10 is offline   Reply With Quote
Old 09-26-2022, 08:29 PM   #15
steves1967
steves1967's Avatar
I used the Landcrusier kit.
https://cruiserteq.com/oem-toyota-ko...-elec81110kit/
The big thing is the wiring. The brightest/ best bulbs in the world won't be any good if you continue to use the old crappy wiring. Use new relays, new wiring and use the old wiring as the "trigger" for the new relays.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 09-27-2022, 01:22 PM   #16
mrein3
mrein3's Avatar
AND if you get a relay harness, you no longer have to replace your headlight switch every so often.
Before you start, turn the headlights on and measure voltage at the back of the headlight connector. Its been years since I rewired my truck to use relays for the headlights but the voltage was on the order of 10 volts.
That current has to flow from the battery to the headlight switch, to the dimmer (floor) switch, then out to the headlights.
All that small diameter wire drops the voltage. The byproduct of that is heat. This heat takes out your headlight switch.
When you re-wire the headlights to run straight off the battery through the relay you are turning your headlight switch into a relay controller.
After the re-wire again measure your voltage at the back of the light. It should be within 0.1 volts of the battery. (12.3ish when car off, 14.3ish with the car running).
I made my own "harness". It isn't hard. There are elevendy billion how-to articles on this site and others out there on the google machine.
FWIW, I use good old fashioned, fact-tree style sealed beams. With the battery voltage out of the relay you don't need the much more expensive alternatives others are talking about.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-27-2022, 01:33 PM   #17
cj847
cj847's Avatar
Do these have the locating tabs on the back? Do you have any issues with keeping them aimed properly?
cj847 is offline   Reply With Quote
Old 09-27-2022, 04:29 PM   #18
DA71Grande
DA71Grande's Avatar
I have the octane 5 3/4 led lights in my gmc they are plug and play
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 09-27-2022, 06:25 PM   #19
leddzepp
Moderator
leddzepp's Avatar
Relay harness upgrade and a set of Sylvania silver star sealed beam headlights from autozone makes a HUGE difference and won’t drain your wallet.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-27-2022, 11:31 PM   #20
slikside
slikside's Avatar
Subscribed!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 10-02-2022, 12:18 PM   #21
Dieselholic92
How do you like the led turn signals? I’ve been looking at those too. Thank you for the headlight suggestion.
Amateur mechanic
Old 10-02-2022, 12:19 PM   #22
Dieselholic92
Thank you! I didn’t realize they don’t receive a full 12 volts. I would imagine there’s a write up for this somewhere?
Amateur mechanic
Old 10-02-2022, 12:27 PM   #23
kwmech
Funny, I did this--and yes you have to use relays. When you flip these on at night, you can see a 1/4 mile down the road like it was daylight. It literally saved my butt one time as it lit up a herd of deer just standing in the roadway, the same roadway I was traveling about 50-55 mph down at the time
Old 10-03-2022, 07:45 PM   #24
DA71Grande
DA71Grande's Avatar
Only have led in the headlights
Doug
23 Chevy Tahoe Z71
Old 10-10-2022, 08:45 AM   #25
6600DURAMAX
6600DURAMAX's Avatar
HO455 - are you running the Daniel Stern lighting setup ??
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
