04-10-2011, 11:20 AM | #276 | |
Re: No Limit '72 C-10
Posted via Mobile Device Posted via Mobile Device |
04-14-2011, 10:51 PM | #278 |
Active Member
Let me see what I can do. Please be patient. I'll try to post some more pics Saturday or Sunday. Yes we will be offering some products. Separately or as a chassis package. Not sure when. Be patient. It will be soon.
04-15-2011, 03:42 PM | #279 |
Prestige Worldwide
Man, just read through all of this and your truck came together really nice....and quick too
So did you guys decide not to use the mustang buckets after all? |
04-15-2011, 07:43 PM | #280 |
Honestly, the mustang seats suck. for now, we have a recovered (mexican blanket) stock bench. But, it sucks too. We are going to a 60/40 split bench from a 88-98 chev p/u. Autocrossing in Del-Mar was fun, but sliding around on the seat, and slamming into the door isn't the fast way around. lol
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
04-17-2011, 03:51 PM | #281 |
Finally found this thread!
Looks great so far, and I can't wait to see more!
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
05-04-2011, 03:45 PM | #282 |
last night we went back out to Adams Motorsports park and ran some Time-Attack laps with the J.T. It was warm, and the track had some good rubber on it, so it was a good night. We haven't made any real big changes lately. 1. We gave it a good alignment before Del-Mar. 3/4* neg. camber, 7* pos. caster, and 1/8" toe out. It drives great, feels very stable at speed, and turns in very well with this set up. 2. We installed two toggle switches in the glove box. One interupts the VSS signal to the ECU, with the switch off, the ECU see's no speed signal, and doesnt try to shift the trans for us. The second switch is a seporate power input to lock up the torque converter. So, we can keep it in second gear, and the converter stays locked, so that the truck pulls off the corner better. The result, Mike Sullivan, a tech here, put down a 51.27 fast lap (previous fast lap for the truck was 53.53) Next project is to swap to air ride in the rear.
05-04-2011, 03:52 PM | #283 |
67cheby
i dont know alot about auto-crossing...but that sure looks like a respectable drop in time !!
05-05-2011, 03:18 PM | #284 |
Yeah, thats huge. I think the rear difference is in Mike getting used to driving it. The seat is really proving to be a P.O.S. looking for a 88-98 split 60/40 seat.
05-05-2011, 03:28 PM | #285 |
Couple of questions if ya don't mind...
1) Toe-in vs. toe-out. How does that affect entering and/or exiting a corner? Which is better? In what situations? When should you align for toe-in? When should you align for toe-out? 2) You installed toggle switches to control the 4L80e the way you want. Awesome! With the VSS signal disabled, do you shift the tranny just like if it had a manual valve body? Stock column shift or floor shifter? If so, this would give you the best of both worlds. Leave it on for cruising. Turn it off for spirited driving. Thanks for your time! AND, I love this thread !!! |
05-06-2011, 12:56 PM | #286 |
Subscribed......Thanks for all the information and details in the changes you're making. Good job.
05-06-2011, 03:54 PM | #287 |
TOE - to start with, if you set the front wheels parallel, 0 toe, it will wander around the highway, and follow every groove and lane cut. No good. So, a slight amount of 'conflict' between the front wheels will keep them going straight ahead. Most cars/trucks alignment spec is toe'd 'in'. Remember that most people aren't very good drivers, and don't really pay attention. Toe in makes the car/truck a bit lazy, but easy to drive. Toe out makes them much more responsive, but can be twitchy. If you enjoy driving, try a little bit of toe out, maybe 1/8".
With the vss off, it will stay in the gear you set it in. I have a floor shift, but I don't shift at all on a short track. It is worth the 3 bucks for the swith.
05-06-2011, 05:12 PM | #288 | |
Good info on the VSS Rob. Would you happen to know the pin number of these 2 wires so we can all try it? Also, I got the new panhard bracket installed and it fits great. Any idea when the sway bar kit will be ready? That's the last thing I need to finish my suspension, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-06-2011 at 05:13 PM. |
05-06-2011, 09:43 PM | #289 |
Looks good, - the panhard should be level at ride hieght. I don't know if your truck is lifted in the picts or not, but take a look at putting the bar mount on top of the mount plate. That may make it closer to level. Sway bars due in 2 wks.
05-06-2011, 10:03 PM | #290 |
I replaced the 4" dropped springs with 6" dropped springs and that took care of the problem......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-06-2011 at 10:47 PM. |
05-07-2011, 05:07 PM | #291 |
How's this?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-08-2011, 02:17 PM | #292 |
A guy with a truck
Better than before. Looks better too I would still look at flipping the mount to the topside. You want it parallel with the ground (or the axle tubes) at ride height, assuming you have room with the cast diff cover...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-09-2011, 03:31 PM | #293 | |
06-13-2011, 05:12 PM | #294 |
I'm just glad to be here!
I just found this thread...i will have to take the time to start at the begining...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-15-2011, 09:51 AM | #295 |
Saw the first article in the series on JT in Street Trucks and am looking forward to future installments.
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
07-21-2011, 07:32 PM | #296 |
I am loving the truck. It has a great look!! What rims are those?? Look like Rockets or Billet Specialties?
07-21-2011, 09:25 PM | #297 |
they are Rocket's. good price, 18 x 9 all around, 275 40 18 BFG KDW tires.
08-10-2011, 11:29 PM | #298 |
Was finally able to read this whole thread. I had foot surgery this morning and was able to spend some time on here. I have seen the magazine articles and was hoping for the details in the frame mods.
Any pictures/layouts of the changes as mentioned earlier? Is JT going to be at the GG show in Dallas this fall?
08-11-2011, 02:08 AM | #299 | |
'69 Chevy SWB
Looking good. Do you have any finished shots of the exhaust routing from front to back. I like the looks of them exiting RIGHT behind the rears like that. By the way, congrats on the article in Classic Trucks (I think). Although you guys are no strangers to the shiny pages.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
08-11-2011, 06:01 PM | #300 |
Wow! I missed alot since I haven't been able to check this thread much. Nice work, Rob and the No Limit crew. I think I'm gonna look into some of the products offered.
Tags |
1972 chevy, c-10, no limit engineering |
Thread Tools | |
Display Modes | |
