Old 03-17-2005, 12:09 AM   #26
thisolechevy
I am wanting to do the same thing in swapping out my beat up '69 for a 72 with a billet grille, Can someone tell me why you need the center support latch off of 71-72? Whats the difference from my 69?
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 03-17-2005, 12:25 AM   #27
raggedjim
raggedjim's Avatar
You can put the billet grill in the 69-70 grille surround if you are brave enough to take a cutout wheel to your grill and remove the center bar. Someone on the board did this (Not me) but it would be hard to find the post as it was months ago that I saw it posted...
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 03-17-2005, 08:09 AM   #28
Bowtiefreak
Bowtiefreak's Avatar
Rg
I believe Tx Firefighter did that.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 03-17-2005, 08:48 AM   #29
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, I cut mine.
Old 03-17-2005, 10:38 AM   #30
raggedjim
raggedjim's Avatar
Tx firefighter, that looks great... you're a braver man than I, Rg
Roger
'70 GMC Jimmy 2wd
Old 03-17-2005, 11:33 AM   #31
Tx Firefighter
Earlier in my life, I worked as an A&P doing sheetmetal repair work on corporate jets. My boss used to walk up and hand me a piece of aluminum sheetmetal and tell me it cost 10,000 dollars, make sure I drill the holes in the right place. I'd dick around all day fitting it up and getting my nerve up to drill the first hole. After a couple of years of that, a grille is nothing to be scared of.
Thread Tools
Display Modes
