Old 05-22-2006, 05:11 PM   #26
meathead95
computer illiterate
meathead95's Avatar
Re: What did you get done this weekend?
Originally Posted by yellow69
Went to the Huntsville Super Chevy show on Friday and bought a 72 Suburban while I was there. Worked the race track on Sat night as usual, then work later Sat night. Sunday spent it with my in-laws(AS USUAL ) Can't ever get out of that. Can't wait to pick up the burb on Wed.
give us some details on the burb. i was down there saturday and saw a blue and white one with a real good body and a 402/th400 for sale
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-22-2006, 07:28 PM   #27
5150
C10 Club Tennessee
5150's Avatar
That would be the one
http://67-72chevytrucks.com/vboard/s...d.php?t=200050
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 05-22-2006, 07:39 PM   #28
Kurt L
Kurt L's Avatar
changed oil and greased my 91 sat,then sunday put a new front bumper on thats been in shop for two yrs.finally got that done then sunday evening washed and waxed same.
Kurt L is offline   Reply With Quote
Old 05-22-2006, 08:54 PM   #29
roughedup72
roughedup72's Avatar
removed the 3.73 posi out of the parts truck and installed it into my project, next up installing my 94' split bench seat, any suggestions on how to mount the middle tracks to the hump.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 05-22-2006, 09:10 PM   #30
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Swap meet...cast stainless steel big block exhaust manifolds...now comes the hard part...grinding sanding and polishing. I just don't like leaky headers and this is going to be a torque motor anyway.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-23-2006, 04:00 AM   #31
Lippyp
English Chevy Owner
Lippyp's Avatar
Moved my truck last night into some rented workshop space to start the rust repairs, it's a little piece of America in rural Lancashire UK as she's sharing a space with the following:
1968 Impala:
Mark IV, 454cu, 7.43 litre, 'hi perf pass' Big Block Chevrolet (1973 - 1990)with full engine stand rebuild. Block casting number 361959 F28 77, 4.250" bore, 2 bolt mains, manufactured June 28th 1977. Lakewood engine mounts, Holley 750cfm vac sec carburettor, Edelbrock performer 2 intake manifold, BTE Racing Flex plate, Large oval desirable cylinder heads casting number 336781 - fully rebuilt by Real Steel, 2.06" intake valves, 1.72" exhaust valves. ARP fixing bolts, self designed custom valve covers, relieved to clear brake servo, Moroso valve cover breathers, Stock HEI ignition rebuilt with MSD high energy coil, MSD high energy module, MSD cap and rotor and MSD leads. Weiand aluminium water pump, Edelbrock pro flo air cleaner, 68190 Hedman hedders connected to a 2.5" stainless steel cross over exhaust, tapering to 2.25" Hedman mufflers. Chrome oil pan, chrome pulleys, 17" flex a lite fan with 2" fan spacer, stock re-cored 3 row high efficiency radiator, all new hoses, Kenlow auto electric fan, stock impala fan shroud. Painless remote starter solenoid kit.
and this little beauty currently running low 9's:
Engine - Jeff Bull built 454cu Big Block Chevrolet, 4 bolt mains, bored +30', with stroker crank to 489cu, 8013cc. Race prepared for Methanol (Alky), Air Flow Research 335cc Fully CNC Ported Magnum BBC Head. Competition 5-angle valve Job. Intake Valve 2.300” stainless steel. Exhaust Valve 1.880” stainless steel, 1.550” OD Roller Dual Valve Spring with dampner, 240 lbs. on seat, .750” maximum lift, 10º Chrome Moly Retainers, 10º Chrome Moly Valve Locks, Valve Seals, Hardened Shims, Intake Valve Seats, Exhaust Valve Seats, Bronze Valve Guides Intake, Bronze Valve Guides Exhaust, Guide Plates, 7/16" Exhaust Rocker Stud, 7/16" Intake Rocker Stud.
2002 machine work - Reface decks, honed bores with torque plates, Faced main caps and line hone, chemical clean, deburr damage from previous, balance of rotating assembly.
Scat 4.250 crankshaft, JE 13.5 to 1 pistons, Eagle .250 longer H beam rods, Childs and Albert zero gap ring set, Clevite 77 H series std rod bearings, Clevite 77 H series std main bearings, Clevite 77 cam bearings, Crane HP timing set with torrington, Felpro RACE gasket set, Felpro oil pan set, Felpro 1027 head gaskets, SCE intake gaskets, Melling hv oil pump, B and B (steff) oil pan and pick up, Crane roller camshaft, Brass core plug set, Oil gallery oil plugs, SFI flex plate, ATI fluid damper, Manley cam lock set, Crane roller lifters, Crane rockers, Chet Herbert Race valve springs, Dart intake manifold, Hedman Hustler headers Ceramic coated, Mallory 37 distributor, MSD race ignition 7AL-2, Scirocco Ally radiator, Weiand electric water pump, BLP alky crank drive fuel pump, 1150cfm BLP alky Dominator carb.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-23-2006, 06:56 AM   #32
al's71gmc
4 eyed fever
al's71gmc's Avatar
Finally got my son's project truck off to the paint shop. Supposed to get it back in 3 weeks. We are both stoked!! I'll post a detailed pic post when it comes home. Time to change my sig.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 05-29-2006, 01:21 AM   #33
HUEVUDO
HUEVUDO's Avatar
Finished up the rebuilt transmission. A rebuilt turbo 350 in my red 68. It was my first time to do this. It was great. If I thought I was messing up I just went to look at my 67 for a reference. Transmission man said 13 quarts in a turbo 350. Put 3 quarts in, start put in reverse. Stop and fill the rest.
HUEVUDO is offline   Reply With Quote
Old 05-29-2006, 01:27 AM   #34
krue
Designated A-hole!
krue's Avatar
Work.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-29-2006, 04:47 AM   #35
chevyboy55
chevyboy55's Avatar
Lots of overdue maintenance on the 88 go to work truck.
chevyboy55 is offline   Reply With Quote
Old 05-29-2006, 06:56 AM   #36
68 50th
68 50th's Avatar
Continued the disassembling of my truck.
I took out the rear axle and the front suspension, I put up the front cross member in an engine stand which made it really easy to work on.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 05-29-2006, 08:46 AM   #37
Lippyp
English Chevy Owner
Lippyp's Avatar
This weekend is a holiday weekend here in the UK with monday as a public holiday. Had some friends and their 2 1/2 year old daughter staying for the weekend so did nothing apart from some serious eating and drinking and chatting, so now I feel like death on a stick!
Phil
'67 C10 long fleet.
Old 05-29-2006, 09:05 AM   #38
Gray Ghost
Gray Ghost's Avatar
I got a bunch done on mine...
http://www.bowtiemadness.com/Blue70mods4.html
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 05-29-2006, 12:47 PM   #39
dboyzalter
dboyzalter's Avatar
had to work... but managed to pull off my rear brake lines... thats about it...
dboyzalter is offline   Reply With Quote
Old 05-29-2006, 01:15 PM   #40
roj2323
started the bolt list for reassembling the frame on my 71. wow stainless is expencive.
roj2323 is offline   Reply With Quote
Old 05-29-2006, 01:35 PM   #41
boogie67
boogie67's Avatar
Hell I 've been sick for the last few weeks so I have not done anything.Today I went out and finish welding my firewall its looking good for not knowing what Im doing.One day hope to learn how to post pics so I can show you guys what Im doing.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 05-29-2006, 05:36 PM   #42
rkarr
rkarr's Avatar
Got the cab on!!!!
Before...
Staring to look like a truck again!!!!!!
After...
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 05-29-2006, 09:53 PM   #43
Sweet72
Sweet72's Avatar
My son's and I got the 383 bolted up on my GMC.
Repaired the poorly installed chassis/body ground wires on the 90 corolla (grounds were bolted to painted metal at assembly plant, imagine that)...amazing how much faster she starts and all the lights are 25% brighter!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-29-2006, 10:09 PM   #44
phlegm
Still Green but learning
phlegm's Avatar
I slow cooked 15 lbs of pork, fixed the clutch on my AC just to find the compressor is shot, and woke up the neighbors with my cracked manifold....
good weekend all around.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 05-29-2006, 10:13 PM   #45
TP from Cntl PA
TP from Cntl PA's Avatar
Finished putting in the cab supports and floors in my K-20................Got the chassis cleaned with the hot water pressure washer, sanded/scraped, washed it again with the washer. Finally got the chassis black I got from a place we buy ag supplies layed on the chassis and under the cab tonight thanks to my dad. He painted the rear half and front half, with the front end sitting up on our heavy steel bench we have here to work on front end loader buckets, I painted the underside of the cab, trans, t-case and frame rails.
Now, get the fire wall cleaned and prep'ed and in color, I can drop the souped up 250 in, put the clip back on it, and paint the rest of the truck
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 05-29-2006, 10:18 PM   #46
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Started thursday installing the new engine in the 67 Dumptruck,nearly finished that up Sunday,until the hayfield called
Tried to take this day off,but still had to fix a couple of flats
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 05-29-2006, 10:43 PM   #47
stllookn
stllookn's Avatar
Squirted some epoxy primer on the rat rod box...finally! Getting closer!
Old 05-30-2006, 08:59 AM   #48
67ChevyRedneck
67ChevyRedneck's Avatar
I think this thread was started to last weekend, but what the heck.... Here's what I did this weekend. First shot is after 2 days of non stop body work and I had just finished hand sanding the whole truck. The second is sunday night after I finished priming the truck, and the last are monday after she was painted medium metallic blue. I'm pooped.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-30-2006, 10:11 AM   #49
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Redneck = nice Blue! Keep us updated on your progress. As for me I just spent money on more parts for my 70. I ordered stainless taillamps, backup assimbalies, and tailgate chains. I also ordered the c/10 emblems, parking lamp, and all side marker assemblies. Next is some nice wood and all the part to do the wood in back. man am I broke.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 05-30-2006, 10:36 AM   #50
motocrosschump
Installed some leather buckets in Max.. That's about it for me.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Thread Tools
Display Modes
