05-10-2008, 02:31 PM | #26 | |
It'd be alot cooler if you did
Re: Arnott valves?
Where can I get the correct hardline and fittings? |
05-10-2008, 10:23 PM | #27 |
belly dragger
Re: Arnott valves?
We've been selling lots of these. Everyone seems to be quite happy with them.
SAVE THE PLANET DRIVE AN OLD TRUCK |
05-10-2008, 10:36 PM | #28 |
Re: Arnott valves?
Who makes it? Does it come as part of a set?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-11-2008, 12:57 AM | #29 | |
Re: Arnott valves?
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
05-11-2008, 01:02 AM | #30 |
Re: Arnott valves?
I think he's talking about these:
You can just swap out the fittings, but fittings get spendy fast. If you can order the brick with 1/4 installed, that's half the battle.
05-11-2008, 01:02 AM | #31 |
Re: Arnott valves?
Yes, part# ARV4000, retails for $499.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-11-2008, 01:03 AM | #32 | |
Re: Arnott valves?
The ones in the pic are actually the "Big Red Valves" I believe they are 3/8.
05-11-2008, 01:25 AM | #33 |
belly dragger
Re: Arnott valves?
They come from GC valves just as valves 2 way or 4 corner. We sell them in our kits too, but I'm not a site vendor so I can't sell here. Don't want to step on toes
SAVE THE PLANET DRIVE AN OLD TRUCK Last edited by grnddwn; 05-11-2008 at 01:26 AM. |
05-11-2008, 05:58 AM | #34 |
Texas Big Wig
Re: Arnott valves?
My big red valves are 1/2"
05-19-2008, 03:11 AM | #35 | |
Re: Arnott valves?
Not to sound stupid but.... What is the problem with 6 valves? Why would this be a issue? |
05-19-2008, 06:30 AM | #37 |
Re: Arnott valves?
that is one way of setting it up, but if you wire it correctly you can still have independent control of all 4 dumps.
05-19-2008, 01:47 PM | #38 |
Re: Arnott valves?
So what about the prewired kit with the 6 valve setup that started this whole thread? Would it be setup the same as the KP installation thread?
05-19-2008, 03:20 PM | #39 |
Re: Arnott valves?
05-19-2008, 05:14 PM | #40 |
Re: Arnott valves?
05-19-2008, 05:21 PM | #41 |
Re: Arnott valves?
I have no schematic, but it's pretty simple on this one since there is a manifold. The manifold simply has one fill valve, and one dump valve. You will not have the option of a teeter totter switch, because you won't be able to fill valves at the same time you are dumping them. I'm not into that crap so I'm not going to worry about it.
We have 6 valves. One for each corner, one that fills the manifold, and one that dumps the manifold. Anyway, I'll use an example here, let's say the driver side front. To fill that bag, I have to open the fill the manifold, so the fill valve must open, and the valve for the driver front must open. To dump it you must dump the manifold, and open the same valve. It would work the same for all four corners. Your hint for the wiring is : Diodes. These will keep electricity from going where you don't want it to and energizing everything when you hit one switch. You could also use relays, but the diodes are simpler - and cheaper. Here is some information on diodes. They are very useful. http://en.wikipedia.org/wiki/Diode have fun. |
05-19-2008, 05:26 PM | #42 | |
Re: Arnott valves?
Which KP thread are you referring to ?? |
05-20-2008, 02:48 AM | #43 | |
Re: Arnott valves?
05-20-2008, 03:12 PM | #44 |
Re: Arnott valves?
nhtc33d, with the six valve setup i am familiar with, you can either raise or lower the vehicle at one time, can't do both. you can raise any bag(s) and then lower any bag(s) because there is only one dump and one fill for all four bags. a six valve setup will work just fine, but an eight will give you more play on bags. it is just depends on preference. hope this helps
My truck spends more than my wife, is that normal? |
05-21-2008, 03:02 AM | #45 | |
Re: Arnott valves?
05-21-2008, 06:35 AM | #46 |
Re: Arnott valves?
ummm.. you can raise and lower the front and back separately. You just can't lower the front at the same time you are raising the rear and vice versa.
05-21-2008, 02:35 PM | #47 |
Re: Arnott valves?
05-21-2008, 09:59 PM | #48 | |
Re: Arnott valves?
I would love to see a wiring diagram for this. So, for example, if you wanted to dump a bag, you would have to open the bags fill valve and the dump valve at the same time?
05-21-2008, 11:00 PM | #49 |
Re: Arnott valves?
i am no wiring expert but this is what i think it should look like. it is a seven switch box. each switch has up and down. hope you understand i tried my best. smashingchuck, hope i'm not hijacking your thread
05-22-2008, 06:10 AM | #50 |
Seņor Member
Re: Arnott valves?
This is what I'm using. I've had the same set of valves for about 8 years. I've had to replace a couple of o-rings and had to do some re-polishing of one of the shafts after it got a nick in it from a chunk of dirt that built up over time into a "rock." Speed is just fine for my needs.
Thread Tools | |
Display Modes | |
