Old 11-09-2008, 11:56 PM   #26
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Starting 72 rear axle install..
I dont know whats going on Joe, Im having problems getting the rear end to line up i guess tomorrow ill try it again.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 11-10-2008, 12:32 AM   #27
protrash64
Resistance is Futile
protrash64's Avatar
Hey gulf....when I took my 'burb apart the rear shifted to one side. I think they can be under load one way or another. I was laying under the truck pushing the frame with my feet and the rear with an arm trying to get the bar on to the mount. It was one of the many BFH moments working on that stuff. Your arm is probably still sore from taking out those U-bolts.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-10-2008, 10:54 PM   #28
gulfcoast66
64-66 CHEVY JUNKIE
Yeah thats the problem, I checked each side and sure nuff one side is sticking out more then the other. Protrash did you post pics of your tank? The reason i ask is i have a gas tank i picked up from somebody for 10.00$ he didnt know what it was, i dont know but it looks like yours can you post some flicks here for me Thanks bro. Ill post some of the tank that i have.. Chris
Old 03-11-2010, 12:35 AM   #29
60apache
60apache's Avatar
would the 72 be a bolt in on a 1960?
60apache is offline   Reply With Quote
Old 03-11-2010, 01:01 AM   #30
Captainfab
60-66 Nut
NO.....you'll have to move the trailing arm mounts and the '72 uses the short panhard bar. So you'd be best off to transfer the panhard bar and it's mount from your current rear end to the new one. In other words, cutting and welding required.
Old 03-11-2010, 11:24 PM   #31
60apache
60apache's Avatar
where did you buy new u bolts from?
Old 03-11-2010, 11:56 PM   #32
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Only 63 and newer is it a bolt in. Your trailing arm pads are different width apart on the earlier trucks.
Old 03-12-2010, 02:19 AM   #33
Captainfab
60-66 Nut
I get mine from a business that specializes in new and rebuilt automotive springs. You should be able to get them from a good auto parts supplier such as NAPA.
Thread Tools
Display Modes
