64-66 CHEVY JUNKIE
Starting 72 rear axle install..
Well I got some stuff yesterday for my rear end, hopefully i will have time to do it this week end. Im still trying too get back on my feet since the storm (IKE) anyways thats all im going say about that. So for i have cleaned and painted the axle and installed new brak shoes. I have new u-bolts and gasket for cover. I got the thing from pick-a- you know the rest, last year. Inspection inside was good. its from a 1972 1/2 burban with 4.11s. Iwas thinking swapping 3.73s from my 6lug axle, but im just ready to put that thing under my truck and be that closer to being finished my truck.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
64-66 CHEVY JUNKIE
Re: Starting 72 rear axle install..
[IMG]
64-66 CHEVY JUNKIE
[IMG]
64-66 CHEVY JUNKIE
Having a hard time removing the old u-bolts from the trailing arms. If i cut them ill still have the problem of getting whats left out the trailing arms!!
PB Blaster and a BFH. You can get lots of things done with just those two items.
From the PB Blaster site-"Quickly breaks loose the surface tension of frozen parts and protects against further rust and corrosion." Spray it down, let it sit a bit, then beat the hell out of it. The rust and scale should break down and allow the bolts to be driven out. Chopster |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If you have a torch you can heat up the area of the trailing arms where the U bolts go thru and that'll break them loose. Don't get it too hot though. If nothing else you can cut the U bolts off and then you have a little more room on the topside to swing a BFH to drive out what is left in the trailing arms.
64-66 CHEVY JUNKIE
Yeah CaptianFab that look like what im going to have to do. Im starting to bend my trailing arms prying and hamming on them. anyway im beat work a 12 last night off 2 days. Ill cut 2 morro and see what happens. Chris..
I have had to cut a few, I soaked them with wd and used a big pipe wrench to twist the remaining part out of the trailing arm. Good luck!!
Its Deja Vu time again
I personally cut the U-bolts as low as possible making 3 pieces. The arch was basically cut out.
I then pulled the trailing arm off the cross member and then I sprayed the heck out of the bolt and let it penatrate the trailing arm. I then flipped the arm over on its top and pushed down and the bolt pushed down and well the nut side pushed out. Just make sure you put all of the weight on the cut off bolt not the trailing arm its self. Oh I forgot to mention I did lower the arm as low as I could with it still connected and U-bolt cut and gave it a few good wacks with a peice of wood under it so I could hammer the nut side down. The trick of course being I soaked the arm with PB blaster the day before and just before I hit it. AFter I hit it a few times with a small hammer I then used some channel locks and twisted the U-bolt then I took it off and did what I mentioned in the paragraph up above. Looks like you bought the same bolts as I did. Last edited by kizer; 11-06-2008 at 06:13 PM. |
#10 | |
Ol' Blue Viking
![]() http://www.seafoamsales.com/deepCreepTech.htm Try it for yourself, that and a lead hammer.
Driving Paw-paws truck into the Sunset! |
64-66 CHEVY JUNKIE
Well i got a little time today to work on those rusty u-bolts, I soaked them last night with some koil and today cut them, the rear side of the bolts just dropped out but the front parts fight to the bloody end! any way i blocked the trailing arms up and sprayed,beat and turned them until they came out. I cleaned everything up and 2morro I will start putting everything back to gether.
64-66 CHEVY JUNKIE
[IMG]
#13 |
64-66 CHEVY JUNKIE
[IMG]
#14 |
64-66 CHEVY JUNKIE
[IMG]
#15 |
64-66 CHEVY JUNKIE
[IMG]
#16 |
64-66 CHEVY JUNKIE
[IMG]
#17 |
64-66 CHEVY JUNKIE
Man I am finished with the install of the rear axel. Ran into a couple of problems 1) The washers that lmc sent were to big to fit the bottom of the shock bracket, So im glad i did not thow anything away 2) My panhard bar dont fit anymore, but my truck is sitting on its own weight, Oh yeah the72 is a little wider then the 66 rear. do anybody know were the best priced panhard bar are? Chris..
#18 |
64-66 CHEVY JUNKIE
[IMG]
#19 |
64-66 CHEVY JUNKIE
[IMG]
#20 |
64-66 CHEVY JUNKIE
[IMG]
#21 |
64-66 CHEVY JUNKIE
[IMG]
#22 |
64-66 CHEVY JUNKIE
[IMG]
#23 |
looks good!!
#24 |
64-66 CHEVY JUNKIE
Thanks Joe!
#25 |
cpp 1965-72 Adj. Track Bar - 24” long $59.99
LINKY that is all i can find right now, but there are plenty more out there why won't your work? shows 65-72 are the same
![]() ![]() Last edited by joe231; 11-09-2008 at 11:04 PM. |
