Old 02-06-2009, 08:55 AM   #26
joe231
joe231's Avatar
Re: 1966 gas tank retro fit under bed
Originally Posted by Captainfab View Post
They are basically the same with some minor differences between the '63-'66's and the '67-'72's. Those differences are 1) the frame horns at the front for the bumper is different 2) the rear cab mount bracket is a little different 3) the front crossmember in the '63-'66 frames that is the lower radiator mount is not there in the '67-'72 frame. All of these things can be changed fairly easily.
just wanted to add.......the '68-'72 has the indention for a power steering gear-box
CHEVY ONLY
Old 02-06-2009, 01:50 PM   #27
Captainfab
60-66 Nut
Thanks for adding that Joe.....good point.....totally forgot about that
Old 02-06-2009, 02:13 PM   #28
JTR
For the sake of tech dicussion. It seems to me you could put a newer tank and sending unit (0-90 ohm) and wire a 58 ohm resister in parallel. This would make your guage "see" 35.27 ohms full instead of 90.
Someone has to have done this........did it work?
A Bronco tank might make a good swap for these trucks too. The filler comes out the side.
25.5 Gal and 33 Gal available
Swiped from Jeffs bronco graveyard
JTR is offline   Reply With Quote
Old 02-06-2009, 02:13 PM   #29
DaddyMack
Wide Eyed User
DaddyMack's Avatar
This was the thread for my 62. but the 63 up frames are even easier.
http://67-72chevytrucks.com/vboard/s...d.php?t=320376
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 02-06-2009, 02:35 PM   #30
joe231
joe231's Avatar
the problem I see with that is you will never see zero ohms, when the sender ohms go down to zero your circuit will see the full 58 ohms of the added resistor. guess if it never makes it to zero, it should work.....but you will never see empty, or is it full? can't remember
CHEVY ONLY
Old 02-06-2009, 04:06 PM   #31
dhughins
dhughins's Avatar
how about one of them 31 gallon blazer tanks from jcwhitney for $147. what else would i need?
dhughins is offline   Reply With Quote
Old 02-06-2009, 05:00 PM   #32
JTR
If it never got below 1 ohm it would be fine but if it hit zero, yes it would be 58 ohms.
I am going to try it with a Bronco tank. I will start a new thread when I do it.
Old 02-06-2009, 06:50 PM   #33
ol Curt
Junior Member
ol Curt's Avatar
As far as dimensions and making it fit, I found a lot of different options in this catalog with dimensions. I am just never sure if their dimensions are from the outside edge of the flange or from the sides of the tank.
http://www.quantaproducts.com/departments.asp?dept=1
ol Curt is offline   Reply With Quote
Old 02-06-2009, 06:59 PM   #34
joe231
joe231's Avatar
maybe you could modify the sender so it never goes below a half or quarter ohm......guess first you would need to find out what the exact resistance from the sender registers E on the gauge (i educated myself zero ohm is empty) and adjust accordingly......
cool, can't wait
CHEVY ONLY
Old 02-06-2009, 07:40 PM   #35
JTR
cool, can't wait
I will put a 1 ohm resistor in series with the sender/58 ohm and elimante the possibility of ever going 0. I think all the parts are less than $1.
Old 02-06-2009, 11:45 PM   #36
joe231
joe231's Avatar
actually that won't work, if the sender went to zero ohms then you would have a 58 ohm and a 1 ohm in series for a total of 59 ohms...
CHEVY ONLY
Old 02-07-2009, 09:36 AM   #37
roofing458
Originally Posted by 63 & 64 Bowties View Post
No, not without putting a resistor inline (way above my head.) Frizzle Fry did one where he used the original 60-66 sending unit and bent the float arm to allow for the shorter travel. Here is the thread. Some great info, should tell you everything you want to know about the Blazer tank install.
how about the tread with the 69 camaro tank with the filler coming right the license plate .i also seen where a guy used a 71-72 cutlass tank....seems like a lot less work.who else has done this >>>>HHHHMMM chime in there has to be a easy way with welding a GAS TANK
roofing458 is offline   Reply With Quote
Old 02-07-2009, 12:25 PM   #38
JTR
actually that won't work, if the sender went to zero ohms than you would have a 58 ohm and a 1 ohm in series for a total of 59 ohms...
true. gonna have to bend the float rod I guess.
Old 02-11-2009, 05:10 PM   #39
derider
derider's Avatar
I picked up a tank from a blazer, now I am just wondering how people have plumbed it and what they did for fuel filler etc. I have found a lot w/ the fleetsides, but I have a step.
derider is offline   Reply With Quote
Old 02-13-2009, 10:54 AM   #40
98L150
///Relaxed Atmosphere
98L150's Avatar
here is what i have done on my 64. go thte tank a few years back when So Cal Speed Shop had a store here in the Houstoin area. The tank is from Tanks Inc if I am not mistaken. Should have the bed mount back on the truck in the next few weeks before we tear back down for paint.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 02-13-2009, 11:45 AM   #41
Chevy Fleetside
Chevy Fleetside's Avatar
If you get the 67-72 blazer tank kit you can order it with a 0-30 ohm sender or the 0-90. It fits in the frame rails so no trimming or welding and it is 20 gals. Here are some pictures of it in my frame. http://s49.photobucket.com/albums/f2...t=000_0346.jpg
http://s49.photobucket.com/albums/f2...t=000_0345.jpg Sorry they are too big to post in the thread.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-13-2009, 11:56 AM   #42
63 & 64 Bowties
and a few others
here ya go....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-05-2009, 03:12 PM   #43
bobjob
i need a inexpensive tank to fit my '63 carryall...any suggestions??? working on tight budget,, any help would be appreciated...
bobjob is offline   Reply With Quote
Thread Tools
Display Modes
