1966 gas tank retro fit under bed
CANT SEEM TO FIND ANY TREADS .HAS ANYBODY HERE DONE this .or point me in the right direction.thanks kevin
Keep It Simple Stupid.. Nope..
Re: 1966 gas tank retro fit under bed
Hey Kevin, are you wanting a thread that explains how to retrofit it under the bed? Or a link to a gas tank kit that can go under the bed?
1963 GMC SWB Fleetside in Sunburst Orange Metallic 305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire. – Custom Classic Trucks Last edited by TwiggyTheDrummer; 02-04-2009 at 12:05 AM. |
i was looking for the 66 guys that have done this so i could pick there brain ,,how ,what,where & what not to do.found 1967 & up thread .Just looking for a few ideas....thanks kevin
and a few others
Kevin, the 60-72 frames are the same. Cheapest thing to use is a full size blazer tank. Get one from one of the guys who haul junk cars to the crusher. Most crushers require the gas tanks to be removed. I put a ad in Craigslist a while back and had two offers the next day for $20. Those guys just want to get rid of them.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Intentionally Left Blank
I just put a Summit fuel cell in the frame rails of my truck. Is that what you're looking for?
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
Kevin I used a tank from a 77-82 1/2 ton Chevy Van. Welded a 3X4 piece of angle the back of the frame rails and had to trim the forward crossmember just slightly see pic. I scrounged mine from the bone yard with straps and filler neck but, they are available new.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
I also had to modify the cross sill above the tank and hole saw through the frame rail for the fill hose as seen in the pic.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-04-2009 at 12:47 PM. |
#8 | |
Junior Member
#9 | |
yes this is what im looking . the more ideas the better .thanks guys i will look into each of your system.
looks good nice work
Resistance is Futile
so much stuff on here I forget where I saw it, but somebody was using a suburban tank. It was nice and square and didnt hang too low.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#13 |
Hey The Dark, tell us more about your fuel cell. How much did it cost, how do you like it, etc.
Thanks |
#14 |
I think I paid around $200 for it. I bought it for another project that went bad, so I figured I'd use it. I just put it in the other day. I have some pix I'll try to post.
#15 |
#16 |
Hey it worked. I didn't know if the pix would show up or not, hurray for me.
#17 |
As you can see, I haven't hooked up the lines yet. Waitin' on the money train........any day now.....
#18 |
I know nothing about fuel cells but am very curious about them. What's the magic in getting them to work? What all needs to be hooked up?
#19 | |
#20 |
It depends on which cell you have. I have one that just has a feed line at the bottom and a vent at the top. The new one, which is in the photo's, has two feed lines, a rollover vent and a return line for fuel injection or if you run a bypass type fuel regulator. One of the main things to remember is to make sure that the fuel pump is lower than the outlet on the cell. The pump should be gravity fed. As you can see in my photo, I'm going to have to put a bracket next to the cell to hang my electric pump from. If I put it up on the frame it wouldn't work properly.
#21 | |
and a few others
#22 | |
#23 |
I was also wondering if people were just using the sending unit from the blazer tank, will this work with the stock fuel gauge?
#24 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
They are basically the same with some minor differences between the '63-'66's and the '67-'72's. Those differences are 1) the frame horns at the front for the bumper is different 2) the rear cab mount bracket is a little different 3) the front crossmember in the '63-'66 frames that is the lower radiator mount is not there in the '67-'72 frame. All of these things can be changed fairly easily.
#25 | |
and a few others
