#26 |
Re: 6 lug/ 5 lug?
I mis-read & thought he was wanting to go 5-lug all around.
#27 |
Re: 6 lug/ 5 lug?
Yeah, either way, 5 or 6, whichever is (honestly) the cheapest. I'm not going restomod on this one, so drums are fine in the front. I mean, they suck and all, but It's been done for decades.
This is all very good info. I've located a front end off a late 70's suburban (I think a 4x4) for a few hundred bucks, but I need to verify that it's the same 5 lug pattern I have in the rear. If not, it's almost useless. I like the 6 lug rear axle swap plan, and it'll put me about the same cost I guess. I don't think axle changes are too difficult- A lot easier than changing ball joints and rusty crusty front suspension parts! Thanks guys!
My 68 cougar restomod build:HERE |
#28 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 6 lug/ 5 lug?
Myself I wouldn't pay more than $150 for a C10 front suspension unless it has been rebuilt recently.
#29 |
Re: 6 lug/ 5 lug?
and as far as I know you can't put 6 lug axles in a five lug differential, you will have to swap the entire differential.
#31 |
Member of the longbed union.
Re: 6 lug/ 5 lug?
No they are not. Most came with 4.10 or 3.73. But you can get diffrent ratio's depending what motor was used.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Thread Tools | |
Display Modes | |
