06-13-2009, 11:06 PM | #1 |
6 lug/ 5 lug?
This 65 GMC I just picked up has the factory 6 lug drums in the front, but it's had a rearend switched into it from who-knows-what with 5 lug drums. What's the cheapest way to make them match? I'm looking at 5 lug disc brake conversions, but they're more than I want to drop into this truck. Are there 5 lug drums that fit for the front?
My 68 cougar restomod build:HERE |
06-13-2009, 11:26 PM | #2 |
SSN 706
Re: 6 lug/ 5 lug?
Search craigs list for a 70-80 1/2 beater for $100- $250 and swap out the whole front cross member. If you lucky you can use the power steering and power brakes also.
06-13-2009, 11:27 PM | #3 |
Re: 6 lug/ 5 lug?
you don't even have to swap the whole cross-member, just the A-arms out to have 5 lug discs.
CHEVY ONLY |
06-13-2009, 11:38 PM | #4 |
SSN 706
Re: 6 lug/ 5 lug?
Da, what was I thinking. That would even be easier.
06-13-2009, 11:50 PM | #6 |
Re: 6 lug/ 5 lug?
I don't think so, you would have to find a drum hub that was five lug and fit your spindle, but when Chevy went to 5 lug on the trucks (5 x 5 pattern) they went to disc brakes on the front...not to mention the 6 lug drums are pretty narrow.
you might be able to drill your hub and machine down a rear 5 lug drum...but by the time you did all that work a disc swap would have been cheaper and much less work...
CHEVY ONLY |
06-14-2009, 12:12 AM | #7 |
Resistance is Futile
Re: 6 lug/ 5 lug?
Be sure to check the bolt pattern first, just in case its 5x4.75''.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-14-2009, 12:18 AM | #8 |
SSN 706
Re: 6 lug/ 5 lug?
What the diff between 5x5 and 5x4.75 I know .25 but is it the distance between the studs?
06-14-2009, 12:22 AM | #9 |
Re: 6 lug/ 5 lug?
Yes, its a smaller bolt circle.....Ive seen some trucks sportin' passenger car rears in them. Just never know, thats why I mentioned it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 06-14-2009 at 12:23 AM. |
06-14-2009, 12:28 AM | #10 |
SSN 706
Re: 6 lug/ 5 lug?
It true you never know what you'll find. I found a mouse nest with 4 babies in it my car today.
06-14-2009, 02:53 PM | #12 |
SSN 706
Re: 6 lug/ 5 lug?
Well at first I gently removed the nest from my car. Then I carefully placed it on the soft ground. Then with the utmost care:
06-16-2009, 02:52 PM | #13 |
Keep It Simple Stupid.. Nope..
Re: 6 lug/ 5 lug?
Haha. If you want five lug just switch the front end out from a parts yard. If you want matching 6 lug, find one at the yard and pull the axle. I prefer the 6 lug though, just because that's all I've ever had and have became a pro at finding wheels for them.
1963 GMC SWB Fleetside in Sunburst Orange Metallic 305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire. – Custom Classic Trucks |
06-16-2009, 03:12 PM | #14 |
Re: 6 lug/ 5 lug?
This is what I'm doing on my 65.............
You can use (72-87) truck spindles. You just change the upper and lower balljoints to same year as "new" spindles (72-87). Also you will need the outer tie rod ends to match the spindles AND a special sleeve to adjust the toe-in. Take your old tie rods and flip outside to inside, add the adapter sleeves and new outer ends. Note: 71-80 1/2 ton trucks are more likely to have the heavy duty (1 1/4 inch thick) rotors that are most desirable for this conversion. Link to tie rod adjusting sleeve: http://www.classicperform.com/Store/1960_1972_Chev.. |
06-16-2009, 05:20 PM | #15 |
Re: 6 lug/ 5 lug?
See, I'd much rather get all new parts than have to deal with a junkyard. I've seen the drop spindles, which I could do, but then I'd have to get the calipers, caliper brackets?, pads, hoses.. and I guess a bunch of miscellaneous hardware. I'm much more of an ebay-kit sorta guy.
I do like the idea of just changing the axles, though. That shouldn't be too expensive, I imagine.
06-16-2009, 07:08 PM | #16 | |
Re: 6 lug/ 5 lug?
For the rears, ECE & CPP definitely offer 5-lug axle swap pkg's or try Moser Engineering for axles & use your local parts place for the drums (71-72 truck drums). I did the Moser route on my 68 & it was about $300 (in '00 dollars).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-16-2009 at 07:08 PM. |
06-16-2009, 10:51 PM | #17 |
Re: 6 lug/ 5 lug?
Yeah I'd just do the axle swap. Much easier, just find a matching 6-lug from the same year or a new truck.
06-16-2009, 10:56 PM | #18 |
Member of the longbed union.
Re: 6 lug/ 5 lug?
First off what lug pattern do you want. 6 or 5 lug. If 6 lug. I bought my front kit from performanceonline.com it came with 73-87 2 1/2 drop spindle, caliper, rotor, pads, hoses, everything to mount it. You can use the same control arms that you have as well, because the kit comes with ball joints to fit the spindle and tierod ends as well. You can also get the kit to fit the 71-72 spindle, it comes with the correct ball joints for it. Every kit that comes with 6 lug comes with custom rotors to fit the spindle. If you want 5 lug, since you already have the rear end. Make sure you know which bolt pattern you have. All the companys that sell the disc conversion sell either the 5x5 or 5x4.5. These kits run anywhere from 600-700 for a basic kit. You will pay close to $100 for shipping since these are heavy Items. As far as the rear end if you dont know how to change all the stuff, get a pro very easy to destroy a rear end if not right! Also I would try to stay away from classicperformance if possible, a lot of people have been having problems with them and they have very bad customer service. Check with a lot of vendors on here since they give forum discounts!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
06-16-2009, 11:00 PM | #19 |
Re: 6 lug/ 5 lug?
I should have said if you want the 5 lug 5x5 best thing to do is buy a parts truck for a couple hundred and swap the whole front end except the crossmember, Most people perfer 73-87. getting a donor truck you can save a lot of money since the frames are the same you can reuse all the brake lines MC/PB. Swap out the steering as well! And sorry for the long novels!
06-16-2009, 11:07 PM | #20 | |
Re: 6 lug/ 5 lug?
Isn't that front end ..........1.5" wider ??????
06-16-2009, 11:21 PM | #21 |
60-66 Nut
Re: 6 lug/ 5 lug?
I've never checked the track width on the front, but I do know that the rear differential is 1.5" wider. If the front is indeed wider it wouldn't be as much of an issue as the rear differential. However that can be taken care of with different backspacing wheels. Lots of people use the '73-'87 front suspensions and I haven't heard of any width issues.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-16-2009 at 11:22 PM. |
06-16-2009, 11:31 PM | #22 |
Re: 6 lug/ 5 lug?
I haven't heard anything about the front being wider at all. As for the back I believe 71 the rear end got 1.5" wider. Not an isue as long as you know what you have and get the correct BackSpacing front and rear.
06-16-2009, 11:35 PM | #23 | |
Re: 6 lug/ 5 lug?
Not quite. The crossmembers & all attached hardware interchange. Even if you don't swap c.members, all disc brake spindles (disc brake conversions using GM 1/2 ton spec'd parts) will widen the track width ~1.00" unless you purchase the spindles that are specifically made not to (CPP's 'modular' spindle).
SeanPaintsFlames . . .... For the axle swap: Pop the rear cover & drain the fluid, remove the retaining pin, push the axles in slightly, plop the c-clips out, slide the old 6-lug axles out, slide the new 5-lug axles in, re-install the c-clips, tug the axles out slightly to ensure the c-clips are seated, re-install the retaining pin, re-install the rear cover, add fluid. You could do some further maint work & replace the axle seals but it's not mandatory. The benefit of doing the aftermarket axle swap is the replacement axles are of higher quality vs. the originals & they don't have 35+ years of wear @ the bearing surfaces.
06-16-2009, 11:44 PM | #24 |
Re: 6 lug/ 5 lug?
I forgot CPP made those modular spindles!
06-17-2009, 12:01 AM | #25 | |
Re: 6 lug/ 5 lug?
Do they make 6 lug axles to fit 5 lug diffs?
CHEVY ONLY Last edited by joe231; 06-17-2009 at 12:04 AM. |
