Old 05-09-2015, 09:24 PM   #26
dougf
dougf's Avatar
Re: To make a long box short
Once you cut through both parts separate them!
dougf is offline   Reply With Quote
Old 05-09-2015, 09:25 PM   #27
dougf
dougf's Avatar
Clean any edges up with a flap disc.
Old 05-09-2015, 09:27 PM   #28
dougf
dougf's Avatar
Measure 12" in from the cut edge. I know this doesn't account for the size of the cutoff wheel, but I did it the same on the other side so I just went with it.
Old 05-09-2015, 09:28 PM   #29
dougf
dougf's Avatar
Don't zone out and cut the incorrect amount from the wrong spots. I damn near did this. Keep looking at where your cutting. 12" from the front, 8" from the back.
Old 05-09-2015, 09:29 PM   #30
dougf
dougf's Avatar
Mark with tape and dust with paint again to make a sharp line and cut. Remember which side you cut from, if you forget and cut from
Outside the line on one side and inside the lines on the other, you could be off by 1/4 of an inch if that makes sense.
Old 05-09-2015, 09:31 PM   #31
dougf
dougf's Avatar
Pick up some. Sheet metal clamps from HF. Invaluable.
Make sure your body lines line up and take a level and make sure the bedside continues in a straight line and zap away.
Old 05-09-2015, 09:33 PM   #32
dougf
dougf's Avatar
If I can do this, so can you. Your going to have some gaps here and there, expect that. Just make sure you are good at zapping sheet metal and have a copper backing plate to fill in here and there and you will be fine. If the joint starts pulling I because of the heat by
P the metal out with a hammer and dolly. Go slow, don't let the heat build up, and enjoy
Your new shortened bed'
Old 05-09-2015, 09:50 PM   #33
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for the step by step.
My truck is a short stepside.
I have a long fleetside bed I want to cut down.
Your pics make it less intimidating.
66 C20 Service Truck:
Old 05-09-2015, 10:46 PM   #34
dougf
dougf's Avatar
Thanks. I have had a few beers so I'm going to make a better post when im able to
The last pic makes it look like the bed is anted upwards however it is not. Must be a combo of paint/lighting. If you take your time with the measurements and can follow a line with a cutoff wheel anyone can do it. I'm even using an old craftsman wire feed welder from 2001 that I got from bookoo for $60
Thread Tools
Display Modes
