To make a long box short
Is it possible to shorten the box on a '63C10? I can't find any threads on how to do it? Thanks!
Senior Enthusiast
Re: To make a long box short
Trucks TV ran a segment in 2007 that show exactly how to do this, both to the frame and the fleetside bed. You can watch it on Amazon.com for $1.99, and save it to your hard drive. Following is the link. It's episode 10 dated 5/27/2007.
![]() ![]() Join Date: Nov 2008
I think there are threads here on it. I've never searched for them but pretty sure I've read them in the past. Not that hard with careful measurements and a clean level area to setup the mod. You need to weld OR I suspect you could do all the measuring, cutting, setup and call in a mobile welder. Post pictures all along the way if you do this.
Definetly, I'll take pics and show you guys along the way. I'm picking up the truck in a couple of days. I have a really bad itch to get started on this thing!!! I thought I had see a thread about this before here, but now of course, I can't find it anywhere! LOL
Excellent choice. Longs are disgustingly gross.
http://67-72chevytrucks.com/vboard/s...d.php?t=333241 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Hadn't seen this write up before :
http://www.eastwood.com/blog/eastwoo...-c10-bedsides/
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#8 | |
I wish you luck with this if you shorten. It's beyond my skill set and patience. Too many other things needed doing just to get it driveable. |
#9 | |
![]() Join Date: Aug 2010
Chevy addict
Long bed = work truck
Short bed = wanna be work truck. I have both but will take a long bed over a short bed any day. It's not about the looks, it has be useful to stay at my house. |
Oh great.
Maybe next we can dispute big window vs small.
#13 |
I'm mobile so it's hard to post but everything is self explanatory. I measured from the edge and cut 12" from the front and 8" from the back. Text me at 806-282-6032 if you need help! Oh, I used tape and tried to cut, the tape peeled because of the heat from the cutoff wheel. So I measured, marked with a fine tip marker, layer my tape, then dusted with grey primer and cut on the primer side. It was really easy to see with proper light and I made a very nice cut. Get some of the sheet metal clamps from harbor freight, life savers!
Posted via Mobile Device |
#14 |
#15 |
#16 |
#17 |
#18 |
#19 |
#20 |
#21 |
#22 |
#23 |
#24 |
#25 |
