01-02-2012, 01:51 AM | #26 |
Re: are 68 Chevy Fenders the same as GMC thru 67-72
Do the GMC fenders which are interchangable with 68 chevys possibly have extra trim holes for the GMC Eyebrow trim? I know the 68 Chevy also had an option for trim, just unclear on clip holes.
Bob |
01-02-2012, 12:16 PM | #27 |
That's true. This is a 1970 GMC fender. You can see the trim holes and the fade line where the eyebrow was.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-11-2020, 09:09 PM | #28 |
Sorry to bring up such an old thread.
I assume this means that a 67,68 GMC hood would fit on 69-72 GMC fenders if you change the grille top bar. Is that correct? |
05-12-2020, 10:57 AM | #29 |
Yep. Thought of doing it my self but haven't found a 67 68 gmc parts truck.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
05-12-2020, 11:43 AM | #30 |
Would the hood latch need to change also on the core support?
And I assume the eyebrows would need to be 67 as well? |
05-12-2020, 01:35 PM | #31 |
I would think so. As for the eye brows just remove them or keep them. They would not interfere with it. All thou it would look wired.
05-13-2020, 02:26 PM | #32 |
Fwiw, we used to have a '70 GMC with '68 Chevy hood and grill on it.
05-14-2020, 07:29 AM | #33 |
05-14-2020, 02:46 PM | #34 |
It's been a long time but I don't recall modifying anything.
05-14-2020, 06:30 PM | #35 |
Thank you for the your answer.
I have a 69 GMC in the body shop, almost done and I have a chance to buy an original 67 chevy hood. So if I'm gonna do it I have to do it now before all work is done and I buy the grill. Can anyone else with experience please help me out with this info? Just trying to find out for sure if my core support and hood latch on a 1969 GMC truck will work with a 67/68 GMC/Chevy hood? |
05-14-2020, 07:12 PM | #36 |
The hoods are the same. I believe.
05-21-2020, 11:56 AM | #37 |
The hood will fit, but the hood latches are different, if you want to use a 67-68 hood (either gmc or chevy) you will need the the 67-68 gmc top bar and the 67-68 gmc hood latch ( the gmc hood latch curves out to the right side of the gmc grill center bar)
You will have to remove the 69-72 gmc chrome trim from the top of the gmc grill and replace it with the 67-68 top bar. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Thread Tools | |
Display Modes | |
