Old 07-27-2010, 07:36 PM   #26
cochino12
It followed me home?
cochino12's Avatar
Re: Is something wrong here? thought I'd be lower...
Originally Posted by edflores View Post
How does your Balljoint angle look now?
And shoot pics of the cups.
after pulling the shims, right now there are no cups in the arm but here a picture
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-27-2010, 07:39 PM   #27
edflores
What brand drop spindles are you using?
edflores is offline   Reply With Quote
Old 07-27-2010, 07:40 PM   #28
cochino12
cochino12's Avatar
Not sure what they are, I didnt buy them. I think they might be chassis tech though
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 07:42 PM   #29
SBTork
Garage wrench
SBTork's Avatar
those cups look a little tall, how tall are they?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-27-2010, 07:49 PM   #30
edflores
How do you know that they are 3" drop spindles then? Or that they are drop spindles at all?
And the cups look to be too tall. I'd say at least a half inch can be removed.
Old 07-27-2010, 07:50 PM   #31
cochino12
cochino12's Avatar
2" but it wont go all the way down even with them out.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 08:05 PM   #32
cochino12
cochino12's Avatar
I installed them
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 08:07 PM   #33
lolife99
67-72 parts collector,…
lolife99's Avatar
Adam,...
That plate in the picture is your upper plate,... correct?
Do you have any pics of the lower a-arm in this same configuration?
You're not running a lower a-arm plate also???
Keith
Convert to disc brakes.
Old 07-27-2010, 08:13 PM   #34
cochino12
cochino12's Avatar
Adam,...
here are a few I took yesterday, nevermind the rag in the LCA please I just set it there so the bag wouldnt rub the bump stop that I will be grinding off later. Not sure if these are what you need
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 08:16 PM   #35
cochino12
cochino12's Avatar
more
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 08:18 PM   #36
lolife99
lolife99's Avatar
I don't see how you could get any lower.
The cups can be cut down to 1.625" total height,... and the bag will take up approximately 3".
I think you are as low as possible.
I would be worried about your upper ball joint bolts, cutting the rubber boot at full drop.
You might want to turn them around.
Keith
Old 07-27-2010, 08:22 PM   #37
edflores
Im going to take a guess on the situation. You may have 2.5 drop spindles, not 3".
Also, your tires are too tall. Do a 245/35/20 instead. Lastly, your cups are too tall. Cut as much as you can
Old 07-27-2010, 08:46 PM   #38
cochino12
cochino12's Avatar
I'm thinking the same thing.
turn them around?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 08:57 PM   #39
SBTork
Garage wrench
SBTork's Avatar
In the first pic in post #34 it looks like the heater hoses are wedged between the heater box and the wheel, is that maybe a problem?
-Adam
Old 07-27-2010, 09:31 PM   #40
blime81
Laid Lo
blime81's Avatar
Ok, a couple things:
1: The bolts for your upper ball joints are in backwards. The nut should be up with the bolt head down.
2: You do have drop spindles, I can plainly see the back of the spindle in one of your pics. It is higher (more towards the middle) than stock ones so it's a drop spindle for sure but may not actually be 3" probably a 2.5" or 2".
You have to flip the bolts for sure.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 07-27-2010, 09:48 PM   #41
cochino12
cochino12's Avatar
I will get them changed tomorrow
I'm almost 100% sure they are 3" spindles as they rubbed my 15" rally's pretty good, I dont think a 2.5" spindle will cause any rubbing
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 10:01 PM   #42
54Caddy
GM Addicted
54Caddy's Avatar
what would flipping the bolts on the ball joints change??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-27-2010, 10:04 PM   #43
blime81
Laid Lo
blime81's Avatar
Probably won't change anything for his getting lower problem but it will keep the bolts from cutting into the rubber boot.
Semper Fi,
Jeff
Old 07-27-2010, 10:08 PM   #44
blime81
Laid Lo
blime81's Avatar
More info on ball joint install and a pic of moog install instructions here:
http://67-72chevytrucks.com/vboard/s...d.php?t=384744
Semper Fi,
Jeff
Old 07-28-2010, 05:04 PM   #45
robnolimit
robnolimit's Avatar
pull the bags and shocks to check the travel of the ball joints, thats the easy way, the, add parts back in until you find the binding point.
robnolimit is offline   Reply With Quote
Old 07-29-2010, 09:27 AM   #46
bagged74
its just $$$$$
bagged74's Avatar
I agree....kinda....
I think they are 2.5" Drop Spindles
Cut the cups down to 1 5/8"
DON'T go to a 245/35..you will hate yourself if you do
bagged74 is offline   Reply With Quote
Old 07-29-2010, 10:09 AM   #47
dv8customs
dv8customs's Avatar
Just Z your frame and call it a day...
dv8customs is offline   Reply With Quote
Old 07-29-2010, 10:22 AM   #48
N2TRUX
Happy to be here
N2TRUX's Avatar
Dude, put your sawz-all away....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-29-2010, 12:34 PM   #49
dv8customs
dv8customs's Avatar
A sawz-all and a welder can fix anything though...
It looks like his bag is fully compressed so I don't think modding the ball joint angle will help any. I have 3" spindles on mine and I know my arms didn't max out the ball joint like that when I was running this same set up. My lower cups were a lot shorter than that too.
Old 07-29-2010, 02:19 PM   #50
edflores
Wrong post
Thread Tools
Display Modes
