Old 07-24-2010, 04:41 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Is something wrong here? thought I'd be lower...
Just installed plates, cups, 2600 lb bags and the control arms are still about 1-1.5" off the ground? I have 3" drop spindles, 245-40-20 tires, I assumed I'd be able to get the control arms on the ground or at least very close. It looks like the bag is just bottomed out, shocks not holding it up either. Ideas?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-24-2010, 06:58 PM   #2
kunzy420
Re: Is something wrong here? thought I'd be lower...
Did you try cutting your cups down a hair?
Ive read about people taking 1" to 1.5" off
kunzy420 is offline   Reply With Quote
Old 07-24-2010, 09:10 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
What cups are you running? Have you checked the bump stops? Are your tires hitting the fender liners? With a 3" spindle, Ride Tech cups, and the fender liners removed, my 82 Blazer would lay the A-arms hard.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-24-2010, 09:11 PM   #4
cochino12
cochino12's Avatar
It looks like if I take any more off the cup the bag is going to rub on the LCA. Actually it looks like bag is just bottomed out, damn I was hoping it would be an inch or two lower. I may have to pull the LCA and weld in a pipe so I can lose the cups.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-24-2010, 10:04 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
You can do that if you like, but it's not necessary. You are hitting somewhere.
Articles-
"Refining Sierra"
Old 07-25-2010, 02:28 AM   #6
cochino12
cochino12's Avatar
I thought it should lay out but I cant see where what the problem might be? I took the inner fenders out and I cut all the bump stop bracket out. I have porterbuilt 2" cups but I think the top plates might be wrong because when I look at other setup's it looks like my bag is pushed further toward the spindle. Either that or I got the wrong bags and they are too big to sit in the LCA?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-25-2010, 10:03 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I "think" the Ride Tech cups are shorter so that might make a difference. The upper plates do bring the bag as far to the outside as possible.
Articles-
"Refining Sierra"
Old 07-25-2010, 10:58 AM   #8
edflores
I think my cups were at like an 1-1/4 when i had my c10. I think most people on here are running around 1.25-1.5 tall cups
edflores is offline   Reply With Quote
Old 07-25-2010, 04:40 PM   #9
54Caddy
GM Addicted
54Caddy's Avatar
more info on ordering the ride tech cups, these cups are already cut down??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-25-2010, 11:58 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
They aren't "cut down" that's just the height they offer. To order them, check with any of our forum vendors that are Ride Tech dealers, or go direct to the Ride Tech site.
Articles-
"Refining Sierra"
Old 07-26-2010, 10:24 AM   #11
kev2809
low n' slo
kev2809's Avatar
do you have any pics of you setup?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-26-2010, 02:47 PM   #12
cochino12
cochino12's Avatar
I'll grab some this afternoon, I left my camera in the work truck this weekend
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-26-2010, 02:53 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Have you actually removed the shocks yet to make sure they aren't holding her up? Sometimes they can look like they aren't restricting the amount of dump... I would remove them just to test it out. Even with the cups at the height you requested you should be lower than that.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-26-2010, 05:17 PM   #14
cochino12
cochino12's Avatar
Yep, I took them out completely. Just to see what if the cup was holding me up I took them out and it came down another ~1" til the tire hit the blower motor/ac box, removed that stuff and the LCA is still ~1" off the ground. I think my upper ball joint might be the problem?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-26-2010, 06:20 PM   #15
dv8customs
dv8customs's Avatar
I would say that ball joint is maxed out...
dv8customs is offline   Reply With Quote
Old 07-26-2010, 06:27 PM   #16
cochino12
cochino12's Avatar
Thats what I was thinking, what do I do now? try a better brand of ball joint? Or am I going to have to stup up and get tubular arms that fix the ball joint angle? I bought 20" wheels so I would have to worry about a bunch of extra work/money getting it low. Damn
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-26-2010, 07:11 PM   #17
dv8customs
dv8customs's Avatar
Got a picture of your cups? I just looked back at some of my old pics and with 3" spindles and a 29" tire my arms werent at that extreme of an angle.
Old 07-26-2010, 07:15 PM   #18
cochino12
cochino12's Avatar
I'll get some more pictures soon, there were no cups installed when I took that picture of the ball joint
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-26-2010, 08:48 PM   #19
dv8customs
dv8customs's Avatar
Ooops... I just realized that picture was after I Z'd the frame. Either way, you seem to have another issue.
Old 07-26-2010, 09:22 PM   #20
kev2809
low n' slo
kev2809's Avatar
ya that bj seems ridiculous, i dont think mine get close to that angle.
-_--_--_ _________
Old 07-26-2010, 10:05 PM   #21
cochino12
cochino12's Avatar
ideas? suggestions?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 03:16 PM   #22
blime81
Laid Lo
blime81's Avatar
Just thinking out loud here but do you have any shims in your upper control arm?
The BJ angle is way to much. Probably whats holding you up and even if its not it should be corrected.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 07-27-2010, 05:24 PM   #23
cochino12
cochino12's Avatar
There are a ton of shims in the upper arm, I'll try pulling some of them out and see if that helps.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 06:46 PM   #24
cochino12
cochino12's Avatar
Damn, pulled all but one of the shims and it definitely has more -camber but it doesnt get any lower. Arrggghhhhh
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-27-2010, 06:56 PM   #25
edflores
How does your Balljoint angle look now?
And shoot pics of the cups.
