Old 02-06-2011, 08:01 AM   #26
ozark
Re: title edited , please keep them family friendly
Have you checked the power valve in the holley? If it has backfired through the carb it usually blows the powervalve.
ozark is offline   Reply With Quote
Old 02-06-2011, 12:47 PM   #27
pig rig
pig rig's Avatar
well if its back fire through the carb you got a timing issue chains jumped or a flat cam
the reson I ask about getting hot is if your radiator is pluged it wont let it build power once the engine is warmed up but you answerd my other question with a yes
so can you get it up to speed if you eas in to the throttle real slow
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-06-2011, 01:06 PM   #28
one low c10
possible burnt valve?
one low c10 is offline   Reply With Quote
Old 02-06-2011, 02:03 PM   #29
xconcepts
Well I'm not sure what you mean by backfire thru the carb. I occasionally hear a pop from the exhaust, but not from the engine. The timing is good, it was checked twice and is where it suppose to be, I cant remember what that is though...35? Something like that.
I can ease up to 45 but anything after that is a no go. The coil was replace just last weekend. Really thinking its the socks...
xconcepts is offline   Reply With Quote
Old 02-07-2011, 12:27 AM   #30
MikeBK
Holly carbs should have sintered bronze filters where the fuel feeds into the bowl/bowls. It does sound like a fuel delivery problem, did you check your rubber fuel lines for colapsing from suction, also if your gas cap is not venting it can cause the same problem.
MikeBK is offline   Reply With Quote
Thread Tools
Display Modes
