Old 02-01-2011, 05:18 PM   #1
xconcepts
title edited , please keep them family friendly
So I just picked up a 78 C10 2 weeks ago. Test drove it, no problems. Now when I go over 45mph it surges/jumps heavily and seems as thou it is not getting fuel. I have to push in the clutch and try to rev the engine to keep it from dying. Sometimes it works sometimes it doesn't. When I press the gas she doesn't rev or get any fuel almost like its out of gas, but I know its not.
I've replaced the ignition mod, sparkplugs, cap and rotor coil and the fuel filter near the tanks. Not sure what else to check. I was told the fuel pump is only about 6 months old, but again it only does it at high loads over 45mph.
Its a 78 4 speed 350.
xconcepts is offline   Reply With Quote
Old 02-01-2011, 05:22 PM   #2
71swb4x4
71swb4x4's Avatar
Re: WTF is going on with my truck?
Is there is a fuel filter in the carburator? I know Quadrajets have a filter right where the fuel line goes in.
If you have rust and junk in the tank it may clog a new filter rather quickly, did you notice rusty fuel when you replaced the filter?
If definitely sounds like a fuel problem to me, but I am no mechanic.
High loads seems to support the fuel issue. The pump or filter is letting enough fuel by to get the truck to run at lower RPM's and loads, but not at higher RPM's and loads.
One more point - a new part doesn't mean a good part. It's becoming more and more common to have a new part be bad right out of the box.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-01-2011, 05:33 PM   #3
inovermyhead
I actually had the opposite problem w/my 81 when I was driving it w/a 305. Under 45 it would jump and studder. Turns out the rocker arms were broken on #3 cylinder and one of the push rods was seized up. Not to say it's the same w/yours but that was mine. Try what 71swb4x4 suggested and if not try pulling the valve covers. Hope it's nothing major... that's what led to my frame off
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 02-01-2011, 07:05 PM   #4
xconcepts
Carb is a holley 650cfm. Is the fuel pump in the engine bay or in the tanks? Trucks not with me atm and I've been told both. No rust or crap in the fuel when filter was replaced.
Old 02-01-2011, 07:20 PM   #5
threeonthetree
threeonthetree's Avatar
the fuel pump is mechanical on these trucks and runs off the cam
it is on the pass side of the block.
i'd check for some other fuel filters that could be on the line. something older between the carb and the fuel pump.
could be the holley...
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 02-01-2011, 07:22 PM   #6
threeonthetree
also could be something with your spark. id check all your wires and pull the cap off and make sure theres no moisture in there. is your advanced set right?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-01-2011, 08:17 PM   #7
one low c10
check timing, make sure the floats are set right. check the vacuum advance. is more when cruising or on the gas?
one low c10 is offline   Reply With Quote
Old 02-01-2011, 09:28 PM   #8
xconcepts
Happens when i'm on the gas I can't even get up to cruse at 50+. Timing is spot on, floats were checked Sunday and are good. Plugs were changed out sunday as well along with cap and rotor. No moisture.
I'll probably pull the fuel pump and replace it to rule that out.
Old 02-01-2011, 09:46 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
that really sounds more like a fuel filter than anything...
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-01-2011, 10:20 PM   #10
Psycho71
Psycho71's Avatar
Fuel filter or fuel pump is what it sounds like to me, starving on the big end.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 02-01-2011, 10:26 PM   #11
xconcepts
I've only found one fuel filter, which is near the passenger side tank.
Old 02-01-2011, 11:00 PM   #12
Shyguy
Junior Member
Shyguy's Avatar
I had a similar problem and it turned out the short rubber fuel line on the suction side of the fuel pump was collapsing.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-02-2011, 12:08 AM   #13
Radioactive1
Does the truck have dual tanks? If it was sitting for awhile, you may have some old gas and/or you've sucked something up that is clogging the fuel filter. I'd start with the filter and check it carefully to see if anything is clogging it.
Radioactive1 is offline   Reply With Quote
Old 02-02-2011, 10:38 AM   #14
xconcepts
Yes there is dual tanks, I replaced the filter near the pass tank and there was no crap in the fuel.
Old 02-02-2011, 01:16 PM   #15
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Good Morning,
I like the collapsed line idea. Also check the fuel tank pickup tube sock in each tank. They can become plugged up as well. In '78 the factory did not use a filter near the tank. The fuel filter would of been inside the carburetor.
With a mechanical pump you should always put the filter between the pump and carburetor not before the pump. Mechanical pumps push much better than pull.
God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 02-03-2011, 12:28 AM   #16
78cheyenne292
i had the same problem with my 78 cheyenne 292 were your fuel line goes into your carb theres a small filter behind it pull it out and look at the small gasket on the filter theres one with a rubber gasket and a small hole and one with a paper gasket and a big hole but the exact same paper gasket. if you have one with the small hole rubber gasket go to ur local pars store and find the other one.. there the same size.. that was my problem runs like a dream now!! who ever replaced the filter last prob never noticed a diffrence
78cheyenne292 is offline   Reply With Quote
Old 02-03-2011, 12:30 AM   #17
78cheyenne292
rubber gasket is black paper gasket is brown!! be carefull not to strip your filter housing when ur putting it back in.. i did it to mine and its a real pain
Old 02-03-2011, 02:40 AM   #18
xconcepts
carb is a holley 650 thou, no filter in the carb as far as I can tell. The only filter is right after the tank, I know its not OEM so there is no filter right before the carb like my 66 gto rochester tripower has
Old 02-05-2011, 06:06 PM   #19
xconcepts
So I just replaced the fuel pump and still have the same issue. The line from the pump to the carb was good and the pcv line from the fuel line to the pump was good as well.
Not sure what else it can be....drop the tanks and check the socks and blow air through the fuel lines?? Where is the Y joint for the fuel lines? Could that be bad or going bad? I thought about bypassing that Y joint and running one tank to find out if thats it.
The carb does have a small metal filter and it was clean....
Old 02-05-2011, 10:49 PM   #20
85chevy4x4
85chevy4x4's Avatar
Hey man you may have already found your problem i dunno but before we tore my engine down it was spittin and sputterin when i gave it half or more throttle like it was out of gas. but when time came for a new engine i wanted to take mine apart just for the heck of it and that problem before was the timing chain was really loose. hope that might help
85 custom deluxe 4x4 4 speed 350sb
85chevy4x4 is offline   Reply With Quote
Old 02-06-2011, 12:05 AM   #21
xconcepts
Re: title edited , please keep them family friendly
If it was the timing chain thou then wouldn't it happen all the time not just after 45 or a higher load?
Old 02-06-2011, 12:54 AM   #22
f.monroe
f.monroe's Avatar
Plug wires will break down especially under a load. It will be worse on a manual trans vehicle because there is no slippage in the converter to let it rev a little. I read your original post and you replaced everything but the wires . I would definitely give them a shot . I have had several vehicles act like yours and the wires were the answer most of the time .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-06-2011, 12:59 AM   #23
xconcepts
Wires look great though, not a cheap brand, MSD brand.
Old 02-06-2011, 01:53 AM   #24
pig rig
pig rig's Avatar
when you start giving it gas does it backfire or pop at all through the carb?
also do you know if its starts to get hotter when your trying to give it gas
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-06-2011, 02:05 AM   #25
xconcepts
It does backfire sometimes, maybe 20% of the time. Not sure if it gets hotter as my temp gauge is inop. It can't be too hot though cause it can be sitting overnight and only have it warmed up for a minute or 2 and it will do it. Engine can't be over 180.
