![]() Join Date: Aug 2010
My 1976 Jimmy with a 5.3
I just finished up a GM 5.3 swap into the truck and I replaced everything from the fuel tank to the fuel rail on the motor with new parts. The fuel system is all plumbed in -06 Aeroquip socketless hose and -06 socketless fittings. I replaced the tank with a brand new tank and sending unit for a 1991 Jimmy and put the pump in the tank. I used a Holley/Walbro 255 LPH in tank pump and a regulator/filter from a 99 to 03 Vette. I am the 4th owner of this truck and this truck is an original Arizona truck so there is very little rust on it at all.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Specs : Dana 60 front Lock Right 1/4 Diff Cover 4:56 gears New rotors, calipers and studs New Wheel bearings King Pins reworked 2.5 inch BDS front springs ORD HD grease able shackles ORD sway bar dico ORD Steering box brace 14 Bolt rear Detroit locker 4:56 gears 1/4 Diff cover U joint / yoke rock guard Rear disc conversion New bearings and seals shock mounts moved axle perches moved 4 inch BDS rear springs ORD HD grease able shackles Built TH400 6 bolt round adapter 6 bolt round NP 205 New bearings, gaskets and seals in the NP 205 New 17X9 Pro Comp 1069 wheels with new 36X13.50X17 Irok bias tires. The tires have 27 miles on them and measure out the same as a 37x14.00X17 Irok which is 36.8 inches. Hydoboost brakes The inside of the tub has been Line X'ed 3000 watt continuous 6000 watt max inverter New 31 gallon fuel tank with skid and very nice rear offroad bumper Coated Street and Performance headers for a 5.3 swap into a 1973 to 87 GM Truck with a single Dynomax x flow muffler and no cats. The truck sounds great New Taylor 10.4 wires, Taylor plug boots and with Bosch Platinum plugs Flushed out the engine when we swapped it in and all I have ever ran in the motor is 5W20 Royal Purple oil. Last edited by 1tonjimmy; 02-11-2011 at 12:39 AM. |
Thread Tools | |
Display Modes | |
