Old 02-11-2011, 12:35 AM   #1
1tonjimmy
1tonjimmy's Avatar
My 1976 Jimmy with a 5.3
I just finished up a GM 5.3 swap into the truck and I replaced everything from the fuel tank to the fuel rail on the motor with new parts. The fuel system is all plumbed in -06 Aeroquip socketless hose and -06 socketless fittings. I replaced the tank with a brand new tank and sending unit for a 1991 Jimmy and put the pump in the tank. I used a Holley/Walbro 255 LPH in tank pump and a regulator/filter from a 99 to 03 Vette. I am the 4th owner of this truck and this truck is an original Arizona truck so there is very little rust on it at all.
Specs :
Dana 60 front
Lock Right
1/4 Diff Cover
4:56 gears
New rotors, calipers and studs
New Wheel bearings
King Pins reworked
2.5 inch BDS front springs
ORD HD grease able shackles
ORD sway bar dico
ORD Steering box brace
14 Bolt rear
Detroit locker
4:56 gears
1/4 Diff cover
U joint / yoke rock guard
Rear disc conversion
New bearings and seals
shock mounts moved
axle perches moved
4 inch BDS rear springs
Built TH400
6 bolt round adapter
6 bolt round NP 205
New bearings, gaskets and seals in the NP 205
New 17X9 Pro Comp 1069 wheels with new 36X13.50X17 Irok bias tires. The tires have 27 miles on them and measure out the same as a 37x14.00X17 Irok which is 36.8 inches.
Hydoboost brakes
The inside of the tub has been Line X'ed
3000 watt continuous 6000 watt max inverter
New 31 gallon fuel tank with skid and very nice rear offroad bumper
Coated Street and Performance headers for a 5.3 swap into a 1973 to 87 GM Truck with a single Dynomax x flow muffler and no cats. The truck sounds great
New Taylor 10.4 wires, Taylor plug boots and with Bosch Platinum plugs
Flushed out the engine when we swapped it in and all I have ever ran in the motor is 5W20 Royal Purple oil.
1tonjimmy is offline   Reply With Quote
Old 02-11-2011, 12:37 AM   #2
1tonjimmy
1tonjimmy's Avatar
Re: My 1976 Jimmy with a 5.3
Here is a few pictures from when we dropped in the motor.
Picking up the motor from the dock...
The Jimmy getting ready for the 5.3 swap.
Pulled out the old tank and put in a new 31 gallon EFI tank with a sump and a in the tank fuel pump. The pump I used is a Holly 255LPH which was dumb on my part because it is nothing but a $100.00 in the tank Walbro pump I guess you live and learn. I also replaced the old fuel sending unit with a new EFI sending unit. All the fuel plumbing is going to be done in -06 Aeroquip Socketless hoes and -06 fittings. I am also using a Vette regulator and filter comb from Pace Performance with -06 fittings as well. I replace all the old straps to hold the tank in the truck and put on new anti squeak material.
We trashed all the old exhaust and I will be going with some mid length headers and a Magnaflow x pipe muffler.
My buddies 7 year and the head mechanic on this job.
New home for the 5.3
Checking all the clearance
And it is in...
Old 02-11-2011, 06:30 AM   #3
67C10BUB
67C10BUB's Avatar
Very cool. How does it run?
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 02-11-2011, 08:24 AM   #4
harnalien
TruckincrazY
harnalien's Avatar
Looks very cool and clean. I'm also interested in how it runs.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-11-2011, 09:55 AM   #5
1tonjimmy
1tonjimmy's Avatar
Red face Re: My 1976 Jimmy with a 5.3
The truck runs great IMO the new GM motor is the way to go for motor swap. The old school SBC is an out dated dinosaur plus the new GM motor swaps are so eazy once you have done one and know what not to do on the next go around. I want to do a beater C20 with a healthy 6.0 6L80 next.
Old 02-11-2011, 12:43 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Very nice! I bet the swap was a little difficult being the Jimmy is so tall!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-11-2011, 01:27 PM   #7
1tonjimmy
1tonjimmy's Avatar
Not at all..... Just let the air out of the tires. There is more then one way to skin a cat.
Note: No cats were harmed during this engine swap...
Old 02-11-2011, 01:28 PM   #8
Pop's C-10
Pop's C-10's Avatar
I've read you have to use a spacer or adapre of some kind to bolt a LS up to a 3 speed..how did you go about it..
Pop's C-10 is offline   Reply With Quote
Old 02-11-2011, 01:37 PM   #9
1tonjimmy
1tonjimmy's Avatar
The Th400 will bolt up to the GMIII and GMIIII just fine. I used this along with this flex plate. I had to elongate the holes on the flex plate a little but it works fine.
Old 02-11-2011, 01:48 PM   #10
Clyde65
Clyde65's Avatar
Nice! I like ur Jimmy.
Many companies supply the flexplate to connect a 3 speed, TH400 or 350 to an LS. Transdapt is one I believe, you can also get one from GM too.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-11-2011, 01:59 PM   #11
1tonjimmy
1tonjimmy's Avatar
Or just use the factory flex plate depending on which one you have. The flex plate is not the problem the main thing is the pilot for the snout of the Tq converter.
Old 02-11-2011, 03:03 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Sweet Jimmy! Nice work on the LSx swap too!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-11-2011, 03:09 PM   #13
1tonjimmy
1tonjimmy's Avatar
Thanks man it truly is a blast to drive.
Old 02-11-2011, 06:29 PM   #14
Pop's C-10
Pop's C-10's Avatar
Thanks for tha info
Old 02-11-2011, 09:25 PM   #15
TR65
TR65's Avatar
Oneton,
Great truck, great swap! Thanks for sharing.
I'm a dot5 man myself.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-11-2011, 09:32 PM   #16
y5mgisi
Second Chance Program
y5mgisi's Avatar
Are you still thinking about selling it?
y5mgisi is offline   Reply With Quote
Old 02-12-2011, 08:10 AM   #17
conman585
conman585's Avatar
what engine mount brackets did you use?
conman585 is offline   Reply With Quote
Old 02-12-2011, 11:39 AM   #18
1tonjimmy
1tonjimmy's Avatar
Thanks for tha info
No problem man!
Originally Posted by TR65 View Post
Oneton,
TR
Thanks bro!
Like I said if they got the money I got the title...
Street and Performance LS motor plates with these motor mounts. You will need to get the S&P plates that move the engine one inch back.
Old 02-12-2011, 03:18 PM   #19
68GMCCustom
I'm about to finish my completely new brake system. What are the +/-'s of going DOT5?
Kurt -
Old 02-12-2011, 06:40 PM   #20
1tonjimmy
1tonjimmy's Avatar
Withstands heat better, does not remove paint, and you get to put DOT5 only on your brake reservoir.
Old 02-12-2011, 10:59 PM   #21
TR65
TR65's Avatar
What 1ton said plus it doesn't attract and absorb water. The paint and corrosion thing is what I do it for. It just isn't right to have an operating fluid ruin your paint with one drop. It is good stuff.
TR
1965 C10 SWB Fleet
Two owner
Old 02-12-2011, 11:00 PM   #22
Pop's C-10
Pop's C-10's Avatar
You got anymore pics of your gauge set-up
Old 02-13-2011, 09:43 AM   #23
conman585
conman585's Avatar
1TON, love your K5
Any more info on the hydroboost setup. Follow any plans? What components did you use?
Old 02-14-2011, 08:20 AM   #24
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
That turned out great 1tonjimmy!
DirtyLarry is offline   Reply With Quote
Old 02-14-2011, 07:00 PM   #25
1tonjimmy
1tonjimmy's Avatar
I will get you some.
1TON, love your K5
All the hydroboost stuff came from a 1986 CUCV
Coming from you that means a lot.... I was going to put this in it.
But Central Freight Lines destroyed it... The motor is a 8.1 from a 2006 1ton Chevy.
