Old 12-05-2011, 05:01 PM   #26
PurdRob
Re: Hotchkis TVS
Hey Portmod7,
I too ordered it but have seen numerous delays in delivery. In fact it's now pushed out to 12/30. Have you had different luck than I?
PurdRob is offline   Reply With Quote
Old 04-19-2012, 09:59 AM   #27
Vandals909
Re: Hotchkis TVS
Sorry to bring up an old thread but I have some questions and hope someone might be able to clear them up.
1. Is their an advantage to running the 73 ball joint over the 71-72 ball joint?
2. If you run the 73 spindle on the hotchkis tvs kit on a 67-72 C10 which brake kit would you buy from CPP or any other vendor? One for a 67-72 or one for a 73 since your running a 73 spindle? Or does it even matter?
Vandals909 is offline   Reply With Quote
Old 04-19-2012, 12:18 PM   #28
69gmcc10
69gmcc10's Avatar
Re: Hotchkis TVS
73 and newer ball joints are cheaper and easier to find. There are light duty truck brakes and heavy duty truck brakes, and all the heavy duty brakes are the same from 71 clear through the 80s with the exception of in the late 70s gm went to metric bolts. Read this for more details on LD and HD brakes and ball joints and tie rod ends:
69gmcc10 is offline   Reply With Quote
Old 04-19-2012, 02:52 PM   #29
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Hotchkis TVS
Parts will be more readily available and cheaper with the 73-87. Later ball joints are also larger diameter, so potentially stronger.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-19-2012, 03:50 PM   #30
Pro Performance
Pro Performance's Avatar
Re: Hotchkis TVS
If you run the CPP modular spindle, then you can run the larger disc brake systems from Baer and Wilwood.
Pro Performance is offline   Reply With Quote
Old 04-19-2012, 05:23 PM   #31
Vandals909
Re: Hotchkis TVS
So the front brakes on a 71-87 are the same? Does anyone know about the rear?
Was wondering if I bought this kit:
http://www.classicperform.com/Store/...2FRBK-BB-R.htm
It appears the front would be ok right? What about the rear?
Old 04-19-2012, 05:40 PM   #32
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Hotchkis TVS
Yes they are, with the exception of the LD vs HD and the swap to metric banjo fittings around 1981. Rear brake mounting is same. You will need 5-lug axles...
-Chris
Old 04-19-2012, 07:23 PM   #33
Vandals909
Re: Hotchkis TVS
My 71 has 5 lug front and rear.
So it sounds like i'm ok to order the cpp front and rear brake kit for my year (71) since the spindle for the 73 is the same but only uses a different. Ball joint.
Old 04-24-2012, 12:23 AM   #34
Vandals909
Re: Hotchkis TVS
For those who have the hotchkis tvs kit, what spring rates front and rear seem to be best? Truck wil probably be driven 75 street and 25% track (maybe). Thanks in advance.
Old 04-24-2012, 09:45 AM   #35
Pro Performance
Re: Hotchkis TVS
I believe they only come with one spring rate.
4” Front Lowered Front Springs, 1100 lbs/in for optimum handling balance
6” Lowered Rear Springs, 380 lbs/in for optimum handling balance
http://www.azproperformance.com/Hotc...C10-80390.html
Old 04-24-2012, 11:56 AM   #36
Portmod7
Portmod7's Avatar
Re: Hotchkis TVS
Originally Posted by PurdRob View Post
Hey Portmod7,
Sorry PurdRob, I guess I should subscribe to threads I post in.
My order was shipped the same day I ordered it, and I received it within a week. Sorry to hear you're having trouble. One good thing about Summit, they WILL make it right...
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 04-26-2012, 12:08 AM   #37
Vandals909
Re: Hotchkis TVS
Earlier in this thread I was advised to run the 73-87 stock height spindle.
I just received an email from CPP today that you can not run a big brake kit with a stock height spindle =(
No sure how to achieve big brakes with a stock height spindle.
Old 04-26-2012, 12:16 AM   #38
Pro Performance
Re: Hotchkis TVS
I would see what that orange truck in the videos for Hotchkis is running. I am sure that truck has big brakes, and ask what spindles they are running. I think that truck has a good stance.
Old 04-26-2012, 12:37 AM   #39
Vandals909
Re: Hotchkis TVS
I think I found my answer. The member PCHRODS truck has a nice stance.
In looking at the TVS kit it comes with a 4" lowered front spring.
Here is a quote from PCHRODS about his setup:
"Great question!! and the answer is "yes", we are using a 2" drop spindle and our own 2" drop spring for a big block, because the first run of Hotchkis TVS kits are for small block equipped trucks (front spring rate on the Hotchkis kit is for a small block truck.) but all the parts are usable on BB trucks, just the front springs are for small blocks, softer rate. You will want to get the shock relocation brackets at the same time, this corrects the angle and geometry on the shocks in a lowered application, which allows them to operate correctly!!"
http://67-72chevytrucks.com/vboard/s...=432310&page=3
So if I order the Hotchkis kit I need to ask them for the 2" lowered front spring. (Not the 4" the kit typically comes with)
I can then run a 73-87 2" drop spindle and then be able to run the big disc brakes. Right? Sorry if this is all repetitive, just want to order the correct components the first time.
Old 04-26-2012, 01:07 AM   #40
Portmod7
Portmod7's Avatar
Re: Hotchkis TVS
You know about Wilwood's D52 calipers right? They bolt right in place of the stock caliper and are a four piston design with a pretty good piston area. I know it's not the same as "big brakes", but it's a pretty good improvement over stock with some performance brake "bling" and a reasonable price tag.
With the Hotchkis kit I believe a little bit of the improvement in front geometry comes from getting the lower control arm more parallel to the ground. That's why they intend for you to use a stock spindle and get all the drop from the spring. I think you'd be compromising some handling improvement by using a drop spindle. Just something to think about. Might call Hotchkis and talk to them.
Old 04-26-2012, 01:12 AM   #41
Pro Performance
Re: Hotchkis TVS
Nice, that is good that they will swap the springs for you. So, now you can go with that CPP modular spindle and open up the options for brakes. Let me know if I can help you out with that. We are an authorized Baer and Wilwood dealer.
Potmod7:
The D52 is a great replacement for the stock caliper, and definitely a good way to get better braking at a more affordable price. It is a 2 piston caliper.
Old 04-26-2012, 01:30 AM   #42
Portmod7
Portmod7's Avatar
Re: Hotchkis TVS
Originally Posted by Street3285 View Post
Potmod7:
Whoops, my bad. It's been a while since I've looked at mine!
Old 04-26-2012, 02:00 AM   #43
Vandals909
Re: Hotchkis TVS
I'm not sure if they will swap out the 4" spring for the 2", it was just a thought since they have 2" srpings listed on their site. I will have to ask them and see if there is an advantage or disadvantage to running a 2" drop spring with a 2" drop spindle vs just a 4" drop spring.
Old 04-26-2012, 07:13 PM   #44
djw32
Re: Hotchkis TVS
Pchrods is using 2.5 inch drop spindles.
djw32 is offline   Reply With Quote
Old 04-27-2012, 09:42 AM   #45
Vandals909
Re: Hotchkis TVS
djw32, I'm not 100% on if it is a 2" or a 2.5" but Pchrods quote in my post above states he is using a 2" drop spindle.
I received a response from hotchkis regarding using a 2" drop spindle and 2" drop front spring vs a 4" drop spring only.
I also asked if they would swap out the 4" drop spring for a 2" drop spring when you buy the kit.
sales@hotchkis.net writes:
There is no problem with the 2+2 drop. We would not swap them out, but you can buy the parts separately so you would get the right parts on your first purchase.
Old 04-27-2012, 10:40 AM   #46
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Hotchkis TVS
How 'bout the kit plus 2" spindles and 2" blocks for a 6/8 drop?
-Chris
Old 04-27-2012, 08:14 PM   #47
smbrouss70
smbrouss70's Avatar
Re: Hotchkis TVS
That's what I was thinking too!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Thread Tools
Display Modes
