![]() Join Date: Sep 2005
Hotchkis TVS
Does anyone have a hook up on this kit? I would really like to purchase it for my c10 but it is super expensive. Does anyone know of another bolt on kit that would improve the suspension performance? I was thinking about buying a front end rebuild kit, but then thought why? I should buy a new suspension kit.
Thanks http://www.hotchkis.net/6772_c10_2wd...le_system.html |
![]() Join Date: Jun 2006
Re: Hotchkis TVS
Summitracing.com has it for $4,222.99.
Summit part HSS-80390. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Hotchkis TVS
There is a member here from Hotchkis, cant remember his name, look in the vendor section, maybe he posted something in there.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Hotchkis TVS
Do you guys think 4300 is expensive?
Posted via Mobile Device |
Re: Hotchkis TVS
Also keep in mind that the TVS system from Hotchkis recommends using a different spindle than the stock 67-72 C10's.
I've been wanting this kit for a year now, maybe next year I will save up and get it. One thing that I would have to change is switch my long tube Hooker headers for some mid-length headers so they don't sit below the frame rail. Not sure how much clearance there is after the installation of this kit.
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
Re: Hotchkis TVS
Any one have this kit installed? I wonder how it rides?
Re: Hotchkis TVS
Re: Hotchkis TVS
What spindles are used?
#9 | |
Re: Hotchkis TVS
![]() Here’s a recent thread with some input from PCHRODS (a forum member here) about our TVS kit for the C-10. “Nate - Let me start out by saying....and you can quote me all day long on this too!! "Hotchkis C10 components are worth every red cent" I have ran several different brands of products on our truck, but we now have the complete Hotchkis TVS Suspension System, and i will tell you this. You will not find a better handling suspension for the C10. The upper and lower control arms to me are the heart and soul of this kit. Don't get me wrong, all the other components are definitely needed to get the "full" potential for the handling characteristics. If you want to see for yourself go to youtube and type in PCHRODS in the search and look at all the videos of our truck, i think you too will be amazed. the OUSCI videos really show you some impressive moves for a 4280 lb truck.“ It came from this thread: http://67-72chevytrucks.com/vboard/s...31#post4880731 ![]() This is Mike’s Hotchkis TVS-equipped C-10: ![]() ![]() |
Man of Mini-Talents
Re: Hotchkis TVS
You should take a few minutes and check out this thread on handling LINK
Rob at No Limit is really cool to deal with, and he races his stuff also. Talk to him and he will ask you about your goals (ride/handling) and he will fix you up at a price you'll like.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
Re: Hotchkis TVS
A guy with a truck
Re: Hotchkis TVS
Hotchikis, from their instructions, does not require a special spindle, but will require trimming of steering stops on some castings...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#13 |
Re: Hotchkis TVS
How do I know which spindle I have? I have disc brakes but bought the truck this way. How do I tell the difference between a 71 spindle and the 73-87 spindle?
Here is the info from Hotchkis instructions for anyone who is thinking about the kit. Ball Joint Info: Before you install this product, please verify which front spindles you have. We have designed the upper aarms to utilize the 73‐87 style spindles. This type of spindle was widely used in disc brake conversions due to its easy interchangeability and readily available replacement parts (e.g. ball joints, tie rods). If you have original 71‐72 style disc brake spindles, you can order ball joints from us to convert the Hotchkis upper a‐arms to work with that spindle. (Part # FA683) If you have 63‐70 drum brake spindles, you will need to upgrade your spindles and brakes to take advantage of this a‐arm kit. |
#14 |
Re: Hotchkis TVS
i wasnt aware of this..... yeah what spindles?
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
#15 |
Re: Hotchkis TVS
Hey all – If you check out these detailed instructions with great pictures for spindle identification, they should answer your questions. If you have more questions after reading them, we’ll be glad to answer them.
![]() http://www.hotchkis.net/_uploaded_fi...ons213file.pdf |
#16 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Hotchkis TVS
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#17 | |
Champagne Taste on Beer Budget
![]() Quote:
Coming Soon: Project 1970 Country Truck |
#18 |
Re: Hotchkis TVS
Hotchkis, I reviewed the photos and want to know which spindle was used on the Orange truck on the instructions? The OEM or the 2" drop spindle?
Thank you! |
#19 |
Re: Hotchkis TVS
If I'm not mistaken, he has OEM spindles with the 4" front drop springs. I'll see if I can find what he has.
#20 |
Re: Hotchkis TVS
C20-67 N MO – You’re right, that is a screaming price they have on our C10 TVS kit! WOW!
Vandals909 – Mike is using stock spindles. ![]() |
#21 |
Re: Hotchkis TVS
Hotchkis again. Is the orange truck using an oem height 73-87 spindle.or the 73-87 drop spindle? Which one?
#22 |
Re: Hotchkis TVS
Vandals909 – The orange C10 is Mike Hickman's truck. He's using the stock 73-87 spindle.
#23 |
Re: Hotchkis TVS
Thank you so much for clearing that up!
#24 |
Re: Hotchkis TVS
When summit dropped the price to $3,800, I had to order it. Much to my surprise, I didn't even end up paying shipping. Just the 12.95 handling fee or whatever. I can't get the truck back on the road soon enough at this point, I want to feel it work!
#25 |
Re: Hotchkis TVS
Vandals909 – You’re welcome!
Portmod7 – That’s definitely a screaming deal…especially with the extremely low cost of handling compared to what you would pay to ship something that heavy. Amazing! Get in gear! ![]() |
