Old 10-12-2012, 04:30 PM   #26
Firebirdjones
Re: hard to fill with gas
Originally Posted by GCncsuHD View Post
That is generally due to the vent tube being blocked.
Not sure about the vapor nozzles, pretty sure our nozzles out here in NC don't have them, and I still have the overflow issue every time if I let it "fill up".
The OP didn't describe a clicking off problem, but instead an overflowing problem. If his is like mine, it overflows well before the pump clicks off.
California is one of the few places I've been that had those silly vapor nozzles that won't pump the gas unless it's way down into the filler and compressing the vapor shield, it acts like a switch that turns the pump on and off. The problem with those is that you have to stick the nozzle so far down into the filler that it constantly burps back the gas and shuts the pump off, a real pain in the butt to fill any of our cars out there, especially the classics with the filler in the rear behind the license plate.
What I end up doing is physically grabbing that vapor shield and pulling back the switch by hand, then I can feed the nozzle in as shallow as I wish, then it pumps just fine, but it's a pain.
We don't have those here in Arizona. If you are overflowing while filling, it sounds to me as if the vent hose is either clogged, too small for the amount of fuel you are dumping, or the vent isn't mounted high enough on the filler neck vs how far you are shoving the nozzle in.
Firebirdjones is offline   Reply With Quote
Old 10-12-2012, 11:44 PM   #27
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I've been putting up with it for almost 35 years...
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 10-14-2012, 06:35 AM   #28
bk2life
put a late model filler tube into it. we used a late 90s and put it into my moms old 76. she was gettin older and couldnt make the click and fill trick work. new nozzle/more flow/new technology
bk2life is offline   Reply With Quote
Old 10-14-2012, 07:31 AM   #29
jjzepplin
jjzepplin's Avatar
Is that because the tube has a larger diameter fill area or is it a larger venting tube?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-14-2012, 01:19 PM   #30
INSIDIOUS '86
INSIDIOUS '86's Avatar
I would assume this L shape we have on the filler hoses isn't exactly the greatest for high flow pumps.
Motorcycles have this little cup riser they use so pumps with vapor collecting nozzles work in the small tanks. Maybe it will work for us?
Btw gas is 4.13 here for 91ron e10. 4.22 for 91 ron pure gasoline this ethanol crap is starting to bug me. I can tell if my fuel is loaded with ethanol just by listening to it idle in gear. My tires know when it's real gas too
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-14-2012, 01:26 PM   #31
cory d
cory d's Avatar
76 seems to be the only ethanol free gas i can find. not all of them. i only use 2 gas stations because of ethanol adn i dont have problems with those pumps
cory d is offline   Reply With Quote
Old 10-14-2012, 04:19 PM   #32
INSIDIOUS '86
I get Safeway gas. It's either shell or bp fuel. The only two fuels there are
Old 10-15-2012, 03:20 PM   #33
JCampbell
Same thing on my '77. It was a ***** to fill the tanks. Eventually, I learned to turn the nozzle upside-down, but even that was hit-n-miss.
Ended up swapping over to an 80+ bed with fuel doors rather than the cap mounted to the bed design. Haven't had an issue since.
JCampbell is offline   Reply With Quote
Old 10-15-2012, 03:26 PM   #34
Firebirdjones
That would be a very small (restricted) opening for the unleaded fuel nozzles. Back in the day we would take a hammer/chisel and knock those out of certain vehicles so we could still pump leaded fuel in (when it was available)
Since I'm stuck in the vintage era, I couldn't bear to give up my large opening leaded filler necks on my 79
Thread Tools
Display Modes
